Go Back   SLK World Forum > Mercedes Benz R170 SLK Class Cars > SLK R170 General Discussion
Wheel Clearance Event Promo
Old 05-17-2008   #1 (permalink)
SLK World Junior Member
Question 98 SLK230 Vibration
I have a 98 SLK230 with just over 100k miles on it now.
The car has started vibrating recently and has progressively got worst. We resently had a tune up done with all the plugs changed and so on hoping that would stop it, but nothing...
I am tring to keep from having to go to the dealer, but I am getting to the point where I don't think I will have any other choice.
I think it may be a broken motor mount, but I am unsure on how to check that. It vibrates the worst while backing up and almost as bad while idling at a light. Also the convertable light comes on now for no reason and starts alarming while driving even though the top is down. So I think the vibrations have messed up the sensor for the top as well.
There is nothing in managment systems saying there is anything wrong, I had it checked at 3 different places.
I would like to know if anyone has had similar problems, and if so what did you find to be the problem?
Also if there is a way to check the motor mounts?
And/Or if someone has some ideas as to what may be causing it?
Any help would be greatly appreciated
AJ
View AJExtreme's Photo Album AJExtreme is offline   http://www.slkworld.com/Boss Key
Old 05-17-2008   #2 (permalink)
Senior SLK World Member
Vehicle: 2002 slk230K 2008 Honda CRV
Sounds like motor mounts. Have a look at them, they are oil filled you may see them leaking which means they need to be replaced.
View livefreeordie's Photo Album livefreeordie is offline   Boss Key
Old 05-20-2008   #3 (permalink)
DesignoSLK's Avatar
Vehicle: 2000 Designo SLK230
Donation Level 3
Welcome to SLKWorld AJ! Glad to see another 170!
You should post your question in the "AskDanSLK" section. You might get a few other options to consider. No offense livefreeordie.
View DesignoSLK's Photo Album DesignoSLK is offline   Boss Key
Old 05-30-2008   #4 (permalink)
Thanks for the replies. It turned out to be the mounts both trans. and motor.
AJ
View AJExtreme's Photo Album AJExtreme is offline   Boss Key
Old 05-30-2008   #5 (permalink)
Its all good.
Steering Wheel Vibration ellimb SLK R171 General Discussion 6 01-22-2008 07:11 PM
SLK230 vs. SLK320 MCFaisal General Discussion 3 03-22-2007 10:41 PM
how do you do burnouts in the slk230 MCFaisal SLK R170 General Discussion 10 02-21-2007 01:24 AM
R170 2K rpm vibration DesignoSLK Ask DansSLK 9 11-07-2006 06:50 PM
Will this grill fit my '99 SLK230 pablosal General Modifications R170 0 10-18-2006 01:12 AM
Advertisement System V2.5 By   Branden
