Welcome to SLKWorld
Old 12-29-2007   #1 (permalink)
SLK World Junior Member
Vehicle: 98 SLK 230
Default Climate control fan quit working
Went to start the car and notice my fan isn't working I check the fuse and they were all good. Can't thigure out the problem.
View hellfire's Photo Album hellfire is offline
Old 12-30-2007   #2 (permalink)
Gabus's Avatar
Vehicle: 96 SLK 230K
Other Toys: Volvo L3314N
Hi Hellfire
Have you measured the fuse? Sometimes you can't see they're gone
Otherwise it could be the regulator, motor, bad contact, or as simple as something stuck in the fan.
Here's a link, in german, with piturs, that describe how you can get the fan with regulator out. You start in the foot well on the passenger side on a "normal" car (not the GB version)
http://tinyurl.com/2rnkvm
Gabus
Old 01-13-2008   #3 (permalink)
Hi.
Same sort of thing happened to me a few weeks ago.
The fan wouldn't work, but occasionally it would spontaneously burst into life for a few seconds before going off again.
Turns out it was the rheostat under the passenger side dash!!
Had it replaced and all is now well.
Incidentally, have recently replaced the battery as the old one was the original and all the funny little electrical anomolies that were manifesting, have all gone! Car even goes better as the ignition system is now working wioth a good stable voltage once more!!
Later.
View Dan F's Photo Album Dan F is offline
Old 02-24-2008   #4 (permalink)
Vehicle: 98 SLK 230
Originally Posted by Dan F View Post
Hi.
Later.
That happend to me I check the fuse with a test light got power. Then found the ground connector broke which cause a bad contact on the fan.
DIY: Digital Climate Control & Lower Tray Compartment Installation dsb General Modifications R171 35 4 Weeks Ago 01:51 AM
Does my car have climate control? bjohnson Ask DansSLK 3 04-30-2008 02:50 PM
Climate Control for SLK350 BiigJiim SLK R171 General Discussion 15 12-04-2007 09:49 AM
Climate Control phatchink SLK R171 General Discussion 22 08-24-2007 08:16 AM
Automatic Volume Control Working?? Driller Ask DansSLK 11 03-13-2007 03:29 PM
