Cruise Control & Tire size - Mercedes Benz SLK Forum
 3Likes
  • 1 Post By jvelecky
  • 1 Post By Padgett
  • 1 Post By Gbarringer100
#1 Old 1 Week Ago
Vehicle: 1999 SLK 230 37,000 K
I have read many forums regarding cruise control cutting out at speeds over 100KPH and improper tire size. As I was having this problem with my new tires I discovered that my front tire are actually 205/50/16 not 205/55/16 as called for. Will this size be the source of my cruise control issue? There was a great online tire size calculator posted at once time but since I need to check the calculation I can no longer locate it. Thanks!
jvelecky is offline
#2 Old 1 Week Ago
Moderator & Minion
Quoted: 921 Post(s)
Mercedes Benz SLK Forum - Search Results for SLKWORLD.COM tyre size cruise control
http://www.mbusa.com/mercedes/servic...lass=SLK-Class
Rad- und Reifenkombinationen | Service & Zubehör | Mercedes-Benz Pkw
Tire Recommendations
Smartop : Cubby Holder : Cree fronts : Both rear fogs.
EVERYWHERE IS LOCAL IN A
55
And nowhere is too far on a VFR
#3 Old 1 Week Ago
Chuck 07 350
Gbarringer100's Avatar
Vehicle: 2007 SLK350 BLK/BLK
Other Toys: 2016 GLA250
Quoted: 60 Post(s)
You did not state the size of the rear tires.
YOu can use this website and compare two different sizes. If it is more than 3% difference you will have problem with the cruise control working.
Custom rims, wheel tire packages for your ride - RIMSnTIRES.com
Compare the rear tire size to the front tire size. The SLK has different sizes for the front and the rear.
Gbarringer100 is offline
#4 Old 1 Week Ago
Chuck 07 350
Quoted: 60 Post(s)
Custom wheels, rim tire packages for your ride - RIMSnTIRES.com
#5 Old 1 Week Ago
6007.us
Padgett's Avatar
Vehicle: '06 SLK350 with 7 speed.
Other Toys: R170-clone with 6 speed, too many others. See web page.
Quoted: 93 Post(s)
Cruise control just maintains a speed, does not care what the speed is. Why would it care about tire size ?
Hui Sweetcheong likes this.
Padgett is offline
#6 Old 1 Week Ago
Moderator & Minion
Quoted: 921 Post(s)
I guess the speed sensors don't like it.
Perhaps the ECU does a comparison, not liking the outcome and plays safe with a slower cruise control speed.
But several members have reported the tyre size/ cruise control issue so looks like it does.
55
#7 Old 1 Week Ago
Pictor's Avatar
Vehicle: 2001 SLK320 , 98 SLK230
Quoted: 76 Post(s)
It could be a safety policy.
If car detects different tyre sizes, either wrong tyres fitted or a spare of a different size. So therefore not safe to be
on cruise control over a certain speed.
I am ofcourse just making up this argument as I go along, but put yourself in the shoes of the safety Engineers.....
The inflatable spare inflates to different size and therefore rolling radius at different pressures, so car sensor could
be programmed to assume a spare is fitted,,,,,, or chains.
Pictor is offline
#8 Old 1 Week Ago
Vehicle: 2005 SLK350 Auto Caspian Blue/Beige Trim ,Heating, Lighting, Comfort, Premium, Entertainment w/Nav
Other Toys: 1967 Chevrolet El Camino
Quoted: 184 Post(s)
If anything causes a fault in ESP/BAS/Antilock, it can stop cruise from working.
Pioneer4x4 is offline
#9 Old 1 Week Ago
Chuck 07 350
Quoted: 60 Post(s)
Yes as others have stated it is a safety feature. The car has anti skid and traction control and so forth. If it detects that a tire is turning faster than other tires it shuts of the cruise control. It allows for a 3% difference. One example would be a wheel hits a puddle in the road could slow down and if it is a driving wheel the cruise control would speed up to maintain speed, then the wheel hit dry payment the car then could speed off or go out of control.
Idiot101 likes this.
#10 Old 5 Days Ago
I'm running at about 3.3% over so I guess it is the size of the tires. Thanks!
jvelecky is offline
#11 Old 5 Days Ago
6007.us
Padgett's Avatar
Quoted: 93 Post(s)
Guess that is verification I can't run a 26" rear tire, 245x45x17 is it. (25.7", 2.8% over the 25" fronts). Am surprised it is set to such a low differential, would expect more like 10% slip
Padgett is offline
Human Verification
Cruise Control Indication Mad Mark SLK R170 General Discussion 2 05-05-2015 02:07 PM
Cruise control Skinless SLK R172 General Discussion 21 03-21-2014 09:46 AM
Adding cruise control to a manual '99 never2late99 SLK R170 General Discussion 5 11-08-2013 10:00 PM
19' tire size??? sno1123 SLK R171 General Discussion 0 03-19-2012 11:09 PM
Speedtronic to limit valet drivers speed? nmslk General Discussion 9 01-03-2008 07:27 PM
