which switch - Mercedes Benz SLK Forum
 5Likes
  • 1 Post By ardo
  • 1 Post By jbanks15
  • 1 Post By mchild
  • 1 Post By LeonardoDaBenz
  • 1 Post By ardo
#1 Old 2 Weeks Ago
Vehicle: 1999 slk 230
Other Toys: zx11 ninja, zx10 ninja zrx1100, sv83 Suzuki
Quoted: 11 Post(s)
which switch
Hi all, on my 99 230, had good working roof, this year I used it once worked fin, now the button blinks, when I pull the button, deck lid opens windows go down, and that's it and I have a blinking red light and every now and then warning sound comes, any suggestion? thank you in advance
ardo is offline
#2 Old 2 Weeks Ago
Quoted: 3968 Post(s)
you check out these threads yet?
DIY R170 Vario roof button blinking
Vario Roof Troubleshooting Tree - R170 Courtesy of Leapyfish
vario Roof Diagnostic aid
Wavetrac LSD thread here:
#3 Old 1 Week Ago
Quoted: 11 Post(s)
Hi all, sorry to bring this up, about Vario roof switches, looks like the problem I have begins when the trunk lid is open widows are down roof does not move, If I am understanding correctly the switches that I need to check are the ones in the quarter panels, because when I try to close the trunk lid; it closes but I get flashing red light on the roof switch. if I need to buy new switches; do I go to a dealer or are they available from on line parts stores. I apologize if I read previous posts about the roof and I did not understand, I appreciates any suggestion that help me resolve my problem.
PS. I checked the curtain switch, I think it works because the process starts the lid opens up, I read somewhere to re adjust the latch, I did, nothing happened, from everything I read, if I understand points to the in panel switches, hope someone has had this and knows the solution.
ardo is offline
#4 Old 1 Week Ago
DAS/STAR Registered Owner
Quoted: 300 Post(s)
The next step in the roof lower process is for the roof to separate from the top of the windshield. I suggest you check and make sure the two latches are being released and if so are the two switches/sensors functioning to tell the system that the roof is properly unlatched and ready to be retracted.
TerryT likes this.
mchild is offline
#5 Old 1 Week Ago
Quoted: 11 Post(s)
roof latch
thank you for your reply, I hear the function in the headliner, the problem is; even if I give up and re close the deck lid, after all the windows go up the light blinks, this is why I am guessing are the switches in the trunk, to access do I have to undo all the inside panels? or what. thank you again for reply
ardo is offline
#6 Old 1 Week Ago
Quoted: 300 Post(s)
If you think the front of the roof is operating properly then the next step would be to check that the switch/sensor that indicates the trunk lid is open would be the one to check. Follow the trouble shooting guide that is part of one of the posts that jbanks posted. To get to the sensor you will need to pull the cover panels off. Here is a link that will show/tell you where all of the switches/sensors are located. Component Locations
mchild is offline
#7 Old 1 Week Ago
Quoted: 11 Post(s)
thank you very much, on the roof switches, to make them work good I cut the vinyl caps that cover the switch, should I do the same to the rest of the switches?
ardo is offline
#8 Old 1 Week Ago
LeonardoDaBenz's Avatar
Vehicle: 2012 SLK55 AMG obsidian black on black anthracite-->Just call me "SCHWARZIE"
Other Toys: Magnum RT (the "Gray Ghost" with the baby Hemi
Quoted: 343 Post(s)
Send a message via Skype™ to LeonardoDaBenz
I know nothing but I offer: did you try the battery reset? If it was working fine one day and not the next, maybe the "sequence" for it to complete the cycle is out of whack?
disconnect the neg cable for a minimum of 30 minutes
reconnect cable
reset clock
try roof operation
This really seems to fix a lot of electro issues.
LEN
LeonardoDaBenz is offline
#9 Old 1 Week Ago
Moderator & Minion
Quoted: 921 Post(s)
As a battery could be the issue,
how old is it?
How often do you use the car and is it short or longer trips?
Could be the battery does not have enough power to complete the sequence.
Smartop : Cubby Holder : Cree fronts : Both rear fogs.
EVERYWHERE IS LOCAL IN A
55
And nowhere is too far on a VFR
#10 Old 1 Week Ago
Quoted: 300 Post(s)
Not sure what issue you were trying to correct by removing the cap but MB has them on there for a reason. I will be inclined to not remove.
mchild is offline
#11 Old 1 Week Ago
Quoted: 11 Post(s)
caps
Trust me, many of us has done it, and it resolve your roof switch problem in the headliner, if you find Bazzels stickies youll see it works.
ardo is offline
#12 Old 1 Week Ago
Quoted: 300 Post(s)
I don't have an R170, so I'm not familiar with those work around solutions. Good if they work.
mchild is offline
#13 Old 1 Week Ago
Quoted: 11 Post(s)
how old is it?
when I am not driving the car, battery tender is connected to the battery to keep it fresh.
ardo is offline
Human Verification
Removing & Replacing the Brake Light Switch on the R170 Series sckothmann SLK R170 class DIY 11 1 Week Ago 02:38 PM
ignition switch FYI 04slk230 SLK R170 General Discussion 2 01-21-2017 08:30 PM
Electronic Stability Control Switch Non-Functioning gregorywilliams100 SLK R172 General Discussion 4 09-25-2015 12:47 PM
Brake light Switch replacement foreign freak SLK R170 class DIY 0 07-03-2011 12:27 AM
