Throttle response problem - Mercedes Benz SLK Forum
#1 Old 04-19-2017
Vehicle: SLK 200 Kompressor (R170) 2002
Hi everyone,
Bit of a problem with my SLK 200 (2002) (manual).
My mechanic installed a new sump gasket and gave it an oil change. Apparently to get access to the sump he had to lower the engine off it's mounts, disconnect the exhaust (intake manifold I assume?), disconnect the anti-rollbar etc.
He later performed a weld on an exhaust bracket under the car and the battery was disconnected for a while.
Then when the the new gasket and oil change was done, he took the car for a 10 minute drive and everything was fine. But when he was driving back into the workshop the car started revving up and down on it's own and the throttle pedal no longer has any effect when pushed in, so the car is no longer driveable.
He says there is an engine management light on and when the car is started up it idles at about 1500 rpm and then revs up and down on it's own.
He is going to try his diagnostic tool, but he is not a Mercedes mechanic so I don't know if his tool/ software will yield any useful results.
The oil we put in was the correct type for the car.
Does anyone know what the fault might be?
Silverado77 is offline
#2 Old 04-19-2017
UPDATE - The mechanic is getting the diagnostics code P0638
Car is revving up and down of it's own volition between 1500 and 2000 RPM
#3 Old 04-19-2017
WoZ53's Avatar
Vehicle: 2006 280 SLK Caspian Blue Metallic
Quoted: 241 Post(s)
https://www.engine-codes.com/p0638.html
Welcome to the forum
Where search is your friend
and the info never ends
Tim Wozny/ WoZ
Eureka,CA
WoZ53 is offline
The Following User Says Thank You to WoZ53 For This Useful Post:
#4 Old 04-19-2017
Vehicle: 2002 R170 SLK 230 Kompressor. Silver. Black Leather. 67k Miles
Other Toys: I also have a 320CDI Estate, Silver,Black Leather, 61k Miles TWIN of SLK & 2013 Smart Car in Blue.
Quoted: 18 Post(s)
I would go over the Wiring Connectors under the Bonett with a "fine tooth comb". Remove and reconnect all of them.
When the Engine has been disturbed that much, wires may have been put under stress and it only takes a fraction of a mm to lose connection.
Mike
ixion is offline
The Following User Says Thank You to ixion For This Useful Post:
#5 Old 04-19-2017
Thanks Mike,
Do you know if there is a throttle sensor somewhere near the exhaust manifold?
#6 Old 04-20-2017
Quoted: 18 Post(s)
It is built into the throttle pedal.
ixion is offline
#7 Old 04-21-2017
My mechanic said his diagnostic tool gave him the option to reset the throttle. The car has been driving trouble free so far for 60 miles. I will continue to monitor it throughout the coming week.
Human Verification
SLK R171 not starting duncanadamsxxx SLK R171 General Discussion 12 04-06-2017 04:53 AM
Acceleration problem SPIDEY CY SLK R170 General Discussion 3 07-17-2016 05:19 PM
Intermittent Starting Problem edzed SLK R171 General Discussion 32 01-05-2016 06:21 AM
Conductor Plate Problem; shady service rep... What to do? Th3120ck General Discussion 35 02-12-2012 04:41 PM
