HELP 2001 Mercedes SLk230 problems P0705 "Transmission Range Sensor Circuit Malfunction (PRNDL Input)" - Mercedes Benz SLK Forum
 3Likes
  • 3 Post By slkrider123
#1 Old 04-01-2013
slkrider123's Avatar
Vehicle: 2001 Bahama Blue SLK230
Have a 2001 SLK230 that won't shift out of second gear. Check engine light is on and getting code P0705 "Transmission Range Sensor Circuit Malfunction (PRNDL Input)"
Have to shut off the car to put the car in reverse or park. This is an automatic transmission. Any ideas what is wrong? Could low trans fluid be the problem?
slkrider123 is offline
#2 Old 04-01-2013
Quoted: 3855 Post(s)
from a google search:
The defective part is the gear shift assembly module that's under the shifter.
Wavetrac LSD thread here:
#3 Old 04-02-2013
Ok thanks, I didn't spill anything under it though, I am going to let the car sit for a few days and see what happens, it was right after it rained when I drove it, maybe something got shorted, hopefully not
#4 Old 04-02-2013
hope that is the easy fix
#5 Old 04-02-2013
REB_TN_06's Avatar
Vehicle: '06 SLK 280
Other Toys: Taylor 814ce
Jeff,
Can you "Reboot" an R170? (Disconnect the battery and wait 30 minutes. Reset the Window travel limits. )
That's a common answer for an R171, anyway.
Gene
REB_TN_06 is offline
#6 Old 04-07-2013
Chris_R's Avatar
Vehicle: 2001 SLK 230
I had the same problem... waited several days, never cleared up - well not until I dropped about a grand on it.
Chris_R is offline
#7 Old 06-06-2013
Other Toys: 1996 Acura NSX-T
Our 2001 SLK320 w/ "one-touch shift" refused to come out of Park & the check engine light came on today when my wife was out shopping. I checked it out with my OBD code reader and it was a P0705.
To get the car home, I cleared the code with the ODB scanner and was able to get the car into Reverse, then into Drive. The CEL light came on again and once home and turned off, the car would not come out of Park again.
The STAR Service CD covers removal & disassembly of the "Not with one-touch shift" (AR27.60-P-0920B). Does anyone know if there is a similar document on the CD for the one-touch shift?
Document GF27.10-P-0001-04GB shows the components of the one touch shift, but has no disassembly instructions. It shows a S16/5 Electronic selector lever control module, but a search on that didn't reveal any further documents on the CD.
I can lift the gear display cover (with the summer/winter switch) and see the circuit board. I'm first going to try to clean that using a cotton swab and electronic circuit board cleaner. If that fails, I'll try removing the entire unit.
Frank
ftuhy is offline
#8 Old 06-06-2013
Minion
slk320chick's Avatar
Quoted: 143 Post(s)
This is the thread Chris is referring to:
Transmission (module?) trouble
slk320chick is offline
#9 Old 06-06-2013
Minion
Quoted: 143 Post(s)
I've been googling..
What does this mean? OBD Code P0705refers to
The park/neutral position (PNP) switch includes a transmission range switch. The transmission range switch detects the selector lever position when the shift lever is in the N or P shift position and sends a signal to the Transmission Control Module (TCM).
Symptoms
Possible sumptoms of OBD code P0705
- Engine Light ON (or Service Engine Soon Warning Light)
Causes
Possible causes of OBD code P0705
- Open or short park/neutral position switch circuit - Poor park/neutral position switch circuit connection - Misadjusted park/neutral position switch - Park/neutral position switch may be faulty The Error code is generally activated on detection of the following conditions: The transmission range switch detects the selector lever position and sends a signal to the TCM.
Another googler said he spilled coffee over it:
So, I took apart the top of the shifter(wood/plastic trim) and I took off the WS(winter summer mode) switch...blew it off with some canned air and let sit. It's now working. On top of that, I cleared out the codes and no more errors...we'll see what happens later. You really should clean the corrosion off the board. Use a little isopropyl alcohol on a Q-tip.
#10 Old 06-07-2013
Thanks everyone, forgot to check in, bought a used shifter off ebay and installed it and it worked!
In the installation I found out why it broke ... the shifter litterarly sits on the floor .. you can SEE the floor when you take the shifter out, so I concluded it was because I drove through a big puddle which fried the shifter, yes if you drive through a big enough puddle, water will touch the shifter and fry it .. pretty bad design but I shouldn't have driven over the big puddle anyways ...
Shifter is installed, car works perfect! thanks for everyones help!
jbanks15, JaysonM and slk320chick like this.
#11 Old 12-15-2014
longship's Avatar
Vehicle: 2001 SLK230 Sport
I had a drink sitting above the gear box and condensation went into the tran control module. Gauges went all wacky and the CEL light is on. A buddy towed it home for me on a trailer and I pushed it into the garage. After sitting over night I removed the gear knob, trim and cover to the TCM. Then I took a hair dryer to heat it up a little bit. Low and behold it started and shifted beautifully on my drive to pick my son up from school. It was getting dark so I put the headlights on and guess what? It wouldn't come out of first gear. I pulled over to the side of the road and turned my lights off. Started out again and it shifted fine.
I'm assuming I will still need to replace the TCM but is there another issue that connects the lights to the TCM? Seems really odd.
I'm going to try to find my ODBII scanner and see what codes it is throwing.
longship is offline
#12 Old 12-18-2014
longship's Avatar
Getting code P0705. Runs fine with the lights off. Turned lights on and it threw the code again and was stuck in LHM, 5th gear.
longship is offline
#13 Old 04-02-2016
Vehicle: 2002 SLK 230 and wife has 2009 ML350
Other Toys: 1964 Corvette Convertible, 1955 Chevy Nomad wagon, 1967 Chevy El Camino, 1965 Piper Twin Commanche
02 slk 230 transmission and heat problems
On occasion after start the transmission will not shift out of low. If I shut it off and start it again, it works as intended. A second problem is that the temperature selector for the climate control seems to fail and I get heat only, no matter the position of the dials. Any help would be appreciated. No check engine light associated with either.
tiffbus is offline
#14 Old 04-02-2016
ichris93's Avatar
Quoted: 89 Post(s)
If the vehicle is cold it delays shifting to heat up the car faster. Catalytic converters have to be warm to work so they do it for emission reasons.
It's likely the heater valve under the hood that has failed.
ichris93 is offline
#15 Old 04-04-2016
Hi Chris and thanks for the suggestions. I intend to check voltage to the duo valve soon. I also think I have discovered a possible clue to the no shift situation. It could be a low voltage problem since a large part of the times it has occurred was after a dead battery. The car has sat in the garage for most of the winter and yesterday the battery was dead after only sitting overnight. I intend to check that out as soon as the weather improves. (little spring snowstorm here)
tiffbus is offline
#16 Old 04-04-2016
ichris93's Avatar
Quoted: 89 Post(s)
The duo valves are fairly common to lock up.
ichris93 is offline
Human Verification
First Time owner of a mercedes - 2001 SLK230 Kompressor W/sport Pkg Buxieda New Members Introduce Yourself Here 27 04-24-2010 08:39 PM
