Welcome to SLKWorld
Old 10-01-2007   #1 (permalink)
SLK World Junior Member
Default SLK Roof will not operate.
Hi All.
Bit of a funny one this, haven't operated the roof for a few weeks, and come to do it today and the roof will not move at all.
When you operate the switch not a thing happens. No noise from the hydraulics, no red light (flashing or otherwise) on the switch either.
Also the normal double click of the switch in either direction to make both windows go up or down in unison, doesn't work.
To me it is either a relay, fuse or (most likely I think) the interior switch itself.
I cannot find the relay or the fuse, so as yet haven't checked them.
The roof operated flawlessly until I tried it today. Don't think it is a mechanical problem, as there is no sounds no lights, nothing.
I don't know if this is related either, but bizarrely, the indicators don't appear to be operating as normal either. They seem to flash quicker, almost like a bulb is gone, but they are all working.
I might be going mad on that point, but it is strange I notice both these things at the same time.
All other electrics etc are working perfectly.
Anyway, if anyone has any ideas or things to try/tips re the roof problem, I am eager to hear them.
Thanks in advance all,
Dan.
View Dan F's Photo Album Dan F is offline
Old 10-01-2007   #2 (permalink)
Vehicle: Obsidian black SLK
You will need to run it through diagnostics to see what's the matter.I was tempted to ask whether your battery was in a good state ,since the car will not allow for certain operations if it is not sure on whether there is enough current to do so. I presume you have tried recycling the boot separator in the open/closed positions just in case...
View ierax's Photo Album ierax is offline
Old 10-01-2007   #3 (permalink)
Hi.
Thanks for your reply.
Yeah, I tried the seperator but that didn't change anything. Mind you if you do forget to pull the seperator in the boot out, then the switch normally flashes at you and nothing happens. The switch doesn't flash now.
Will the battery being a bit ropey stop the roof from working even when the engine is running?
I think it is the original battery and the car is now 5 years old, so maybe that is it?
Any more pointers before she goes to the shop tonight will be welcome.
Cheers,
Dan.
Old 10-01-2007   #4 (permalink)
Sounds to me like you have a water problem mate.
Old 10-01-2007   #5 (permalink)
Hi.
Thanks for your input.
So this water problem, can you please elaborate?
I checked the things I have read about, namely the pump and the module in the boot and both are dry as a bone.
The car has been parked outside in all weathers since I bought it a year and a half ago, and the roof has operated flawlessly until between now and 3 weeks ago.
Is there any where else I should be checking re water ingress?
Cheers.
Old 10-01-2007   #6 (permalink)
Vehicle: SLK32 AMG
**** electrical problems ....
The fuse and relay boxes should be on the left side looking forward toward the fire wall and the covers should point to the fuse / relay.
I believe the owners manual will point out the locations and positions.
Edit, You used the word boot, so the fuse and relay box may be on the other side....
Edit, one of the smilies is so offensive that it turned into ****
Old 10-02-2007   #7 (permalink)
Thanks for the pointers.
LOL. Yeah, sorry.
Boot = Trunk
Bonnet = Hood
Cheers,
Dan.
Old 10-02-2007   #8 (permalink)
Hi all.
Turns out it WAs a fuse, but I checked all the ones in the 2 fuse boxes listed in the manual and drew a blank as they were all intact.
Guy at the garage says that it may have been an inline fuse that isn't in the fuse boxes, but I will speak to the tech tonight when I pick her up and see what they story is.
Main thing is though, it is sorted!! Have to find out why they think the fuse went in the first place.
Cheers.
Old 10-02-2007   #9 (permalink)
Hi All.
Turns out it was fuse no 7! It is only a 5A fuse and strangely it hadn't gone in the usual place, so at a glance, it looked intact.
Very bizarre, but I am happy it is fixed.
Any one any clues as to why that fuse may have gone in the first place?
Cheers,
Dan.
Old 10-02-2007   #10 (permalink)
Probably an old fuse, I'd be concerned only if it happens again on the same fuse.
Old 12-22-2007   #11 (permalink)
Default indicators stoped flashing
hi guys first post on here and surprise its a help slk 230,i know some of you have come across this one before ,my indicators have lost the relay (they just light up and stick on) what relays that are in the car i have swapped about with no joy,i do suspect the relay is part of the clocks but not sure,anyone help with this teeth grinding problem cheers cal
View cal550's Photo Album cal550 is offline
Old 12-23-2007   #12 (permalink)
Gabus's Avatar
Vehicle: 96 SLK 230K
Other Toys: Volvo L3314N
Hi cal
Welcome here.
Does the warning light flash - if so it's not the relay.....
The relay sits on a circuit board in the black box next to the battery. There is a history with bad contact, burned contact points.
Flashrelay is the third from left ( open one)
Gabus
Old 12-23-2007   #13 (permalink)
thanks ,i will operate tomorrow and let you know
'09 SLK 350 Roof and window function vincent007 SLK R171 General Discussion 30 4 Days Ago 04:36 PM
New Roof! goldie Where to get R170 SLK Items 5 07-15-2008 06:17 AM
Slk Panaramic Roof RedDevil07 General Discussion 21 03-01-2008 12:23 PM
Need some help with roof. cyberdrakon SLK R171 General Discussion 5 06-29-2007 12:54 PM
New SLK roof module supplier benz--man General Modifications R171 18 09-20-2006 12:39 AM
