R170 Steering Not Self Centering - Mercedes Benz SLK Forum
 10Likes
#1 Old 06-16-2016
Vehicle: SLK 200 Kompressor (R170) 2002
Hi everyone. I just got my R170 SLK 200 about 2 months ago and there is a slight issue with the steering. At low speeds less than 10 - 15 mph coming out of my drive or in a car park for example, the steering is not self centering after I make a right angle turn. It's not a huge problem but it is slightly annoying as I have never driven a car with this issue.
I had to get the front tires replaced because the insides were worn and my neighbour suggested that I should get a wheel alignment which I did. The engineer said the alignment was OK but when he was test driving the car it was pulling slightly to the left. I have only noticed this under fairly hard braking. However, the non self centering issue is happening with both left and right turns to an equal degree.
I recently had the car serviced and a ball joint was replaced on the front driver's side (Right - I'm in the UK). I had another mechanic check the rest of the car while he was inspecting an oil leak and he didn't notice anything odd with the steering components. Also the car has just passed the MOT (yearly UK government car safety inspection) and nothing was mentioned about the steering components.
Anyway, I just posted so I could get some suggestions as to why this steering issue is happening and what I need to do to correct it. Could this have anything to do with the steering damper?
Thanks a lot.
Silverado77 is offline
#2 Old 06-16-2016
Quoted: 3968 Post(s)
4 wheel alignment or 2 wheel alignment or tire balance?
slk320chick likes this.
Wavetrac LSD thread here:
#3 Old 06-16-2016
Delucas's Avatar
Vehicle: MERCEDES SLK R171 -2009- MERCEDES - BENZ SLK 170 2000 -- MERCEDES A 170
Other Toys: ALFA ROMEO SPIDER 2000cc - VAUXHALL CORSA SR - LEGO STAR WARS 1791 X WING
Quoted: 538 Post(s)
Steering damper ( shock absorber ) maybe worn
And if ball joints have been replaced after req 4 wheel alignment again .
Delucas is offline
#4 Old 06-16-2016
murat orhan's Avatar
Vehicle: 2000 SLK 200K FL 6M
Other Toys: Yamaha 60HP/15ft
Quoted: 12 Post(s)
have the caster angle checked.
murat orhan is online now
#5 Old 06-16-2016
I got wheel alignment when getting the front tyres replaced. I had the rear tyres replaced 4 weeks later.
#6 Old 06-16-2016
my question is, was it a 4 wheel alignment?
for you or others
#7 Old 06-16-2016
So is the steering damper a cheap fix?
Do I go for an original Mercedes part or is there a third party company that makes a damper that has been improved beyond the original?
#8 Old 06-16-2016
for you or others
https://www.youtube.com/watch?v=F6ZZ_U_Fl1Y
Yes, it was 2 wheel alignment on the front from my understanding, which as I'm sure you can gather, is very limited. Balancing was included with the tire change.
I had the rear tires replaced a month later when I had the money.
I think I will take it to another tire company for a 2nd opinion on the wheel alignment.
#9 Old 06-16-2016
Get a 4 wheel alignment check out video if u haven't, covers steering wheel centering and all the symptoms u have
#10 Old 06-16-2016
Thanks, I'll do that.
#11 Old 06-16-2016
Thanks for the video Jeff, good info.
#12 Old 06-16-2016
Murat, I see you have the same car as me; have you ever experienced the steering not self centering at low speeds as I have described above?
#13 Old 06-16-2016
Delucas, have you ever experienced the steering issue I have described on your R170?
#14 Old 06-16-2016
Yes D, tell us about that R170 of yours
what model again was it? hmmmm?
Delucas likes this.
#15 Old 06-16-2016
Delucas's Avatar
Quoted: 538 Post(s)
Nope never on my cars
But before 4 wheel alignment
You need to check the whole car suspension joints
Tyres
Pressures
Coil springs
Shockabsorbers are all good
And the steering damper is not worn / weak etc
Correct alloys to not aftermarket ones .
2 wheel alignment is no good and believe you need a spacer bar placed on front wheel on the 170 to do tracking correctly.
Delucas is offline
#16 Old 06-16-2016
Delucas's Avatar
Quoted: 538 Post(s)
Mr Banks
You need to watch your rear end
Ha
Sadly my trusty 170 i sold
But its still in ink format on here .
Delucas is offline
#17 Old 06-16-2016
Funny Jeff. Go easy on the newbie, eh? Never set foot inside a Mercedes before 2 months ago.
#18 Old 06-16-2016
Comments pointed at Delucas, not you, who as he knows is not a newbie!
#19 Old 06-16-2016
Tyres
Pressures
Coil springs
Thanks D, I'll follow your advice.
#20 Old 06-16-2016
see my post above yours or your pm
Tags
slk 200, slk r170 steering problem
Human Verification
Advice on steering wheel/airbag R170 clown General Modifications R170 6 12-02-2015 01:03 PM
Steering damper replacement/change (R170) JaysonM SLK R170 class DIY 13 07-16-2014 12:17 AM
WTB: Telescopic steering lever for '98 R170 billas slk SLK Parts Wanted 1 01-19-2013 02:55 PM
DIY - Instrument cluster removal for R170 without telescoping steering Mantist SLK R170 class DIY 14 09-09-2011 02:45 AM
