alarm keeps going off - Mercedes Benz SLK Forum
 3Likes
  • 1 Post By rdinky1
  • 2 Post By REB_TN_06
#1 Old 12-26-2012
Vehicle: 2001 slk320
Other Toys: john deere tractor
hi, I have an 01 slk320 and since it snowed yesterday, my alarm keeps going off.. the lights blink , but no sound.. also my tow light is on all the time.
I saw a thread relating to the battery inside the alarm horn , but i'm not sure if that's what is causing the alarm to go off.. I also had the rear tires replaced last week.. may be a coincidence.. or maybe not..
can someone help me out? thanks!
in the mean time is there a fuse I can pull to keep the alarm from going off ? right now i just have to keep the doors unlocked!
thanks in advance!
rdinky1 is offline
#2 Old 12-26-2012
Quoted: 3855 Post(s)
from leapyfish,
fuse locations
http://www.slkworld.com/r170/home.htm
go to component locations, then fuses
Wavetrac LSD thread here:
#3 Old 12-26-2012
got it #9! I pulled it .. no more dome light horn or trunk light... but i guess that's better than a dead battery tomorrow... now I got to find the root cause!
thanks for the post!
rdinky1 is offline
#4 Old 12-27-2012
im a little confused.. everything points to a bad alarm battery, but I read that the main car battery should still make the alarm go off...and sound the horn.. my lights flash but no sound.. does this mean the horn is bad all together ?i've also seen to check my pse pump...? I have a popping sound coming from the trunk.. it's been doing this for a while.
I just could never really locate the location... kinda sounds like fireworks at a distance...
could this be the issue ? the tow light stays on all the time....
also , when I lock the car .. the lights flash 3 times... is this normal? i always assumed it was.. it's been like that since I bought it in June...
thanks in advance!
rdinky1 is offline
#5 Old 12-27-2012
Firm's Avatar
Classic symptoms of a wet PSE pump. Search the forum for wet PSE pump threads and you'll find tons of info.
In the mean time, pull out the trunk carpeting, spare tire, jack kit, etc. On the right side you'll see a foam box, pull it out (carefully) and you'll find the PSE inside. Dry the trunk floor (I bet it's wet), dry the PSE pump out (I've had good luck just blowing on it with a warm hair dryer for awhile). Then make sure your trunk seal is installed correctly and the drains (in the trunk through and fuel fill areas) are clear and following well.
Then wrap the wires going into the PSE with some paper towel (keeps water from wicking down them onto the pump) and re-install everything. The foam box is a bit of a struggle to get back in place, so be patient.
Firm is offline
The Following 2 Users Say Thank You to Firm For This Useful Post:
#6 Old 12-27-2012
i plan on trying to do just that , I have the 6 cd changer in the back as well, do I need to remove that first to get to it ? or is it below ? it got dark and 20 degrees on me last night (in TX go figure) so I have not had a chance to look.
also , since my alarm siren does not seem to be working , what is a good place to buy one of those aside from the dealer ?
rdinky1 is offline
#7 Old 12-27-2012
http://www.mercedespartscenter.com/p...?siteid=215720
#8 Old 12-27-2012
A1718202526 auto siren part 250
replaced by a2198203226
The Following 2 Users Say Thank You to jbanks15 For This Useful Post:
#9 Old 12-27-2012
ahaha.. you again !! well , I looked at the other link you had sent me and they had the part for $132 .. a quick internet search showed that that was a good price , so I bought it ... i see now that this iste has it a little cheaper .. oh well it's already done !!!
my next step will be to tear down the trunk and find the rest of the goodies that could cause the problem ....
I'm no mechanic , but I do have a degree in Electronics, so I should be able to figure out that part ...
hopefully she will get all fixed up and be back 100%
my car is an 01 slk 320 , I bought it back this summer with 39k miles on it ... it spent most of it's life in California , then the rest in south Texas ... so this is the first time it's ever seen snow or cold weather ....
all kind of little problems are surfacing ... it also has small valve cover leaks forming it seems .... that and the "popping" faint "fireworks " sound once in a while ....
almost forgot to mention the lock for the gas door is also missing .. maybe that's what is popping once in a while trying to close (I guess it's vacuum operated too)...
I don't even know how to gt to that either.... !!
what a learning experience !!!
rdinky1 is offline
#10 Old 12-27-2012
if you need some part numbers, post your vin so we can get the exact part number
#11 Old 12-28-2012
Firm's Avatar
No need to remove the CD changer to access the PSE, it's below.
Firm is offline
#12 Old 12-28-2012
REB_TN_06's Avatar
Vehicle: '06 SLK 280
Other Toys: Taylor 814ce
You should probably sign up for the Electronic Parts Catalog (EPC). Mercedes will give you access to the same screens that their Parts people use - put in your VIN# and it will show you most of the parts in your car.
Go to STARTekInfo.com and sign up. They will ask for a credit card # but the service is free for people located in the US. This thread shows you how.
How to get a Datacard from EPCnet!
jbanks15 and leapyfish like this.
Gene
REB_TN_06 is offline
#13 Old 12-31-2014
El_Toro_33809's Avatar
Quoted: 86 Post(s)
Our alarm was doing the same thing. Read about the PSE pump and checked it.... It was dry. Pulled the alarm and replaced it, problem solved.
El_Toro_33809 is offline
Human Verification
Help! My alarm keeps going off randomly lombrozo SLK R170 General Discussion 6 05-09-2012 05:52 PM
230 slk Alarm went off now, it keeps going off. ryan2022 SLK R170 General Discussion 0 09-25-2011 02:16 PM
