SLK230 power loss, surge - Mercedes Benz SLK Forum
#1 Old 12-18-2012
Vehicle: '03 230SLK
Other Toys: 1967 MG Midget
Not clear if there is a connection between the two, but the engine surges around 300 rpm at rate of about once per 2 seconds when feathering the throttle, and seems to have a noticeable loss of power from about half to full throttle. Surges when idling in park about 600 - 1000 rpm for a while and then settles to 700 steady. Check engine light is on and coolant level light comes on intermittently. Odometer is now 105K. Any ideas as to whats going on here?
pmatocha is offline
#2 Old 12-20-2012
Other Toys: 1986 560SL, 2012 VW Tiguan, 2008 GMC Sierra slt
Quoted: 67 Post(s)
Pull the codes and post them here, maybe we can help.
#3 Old 12-20-2012
Birds's Avatar
Vehicle: 05 350
Bad gas, fuel filter?
Birds is offline
#4 Old 06-04-2013
Vehicle: 2003 SLK-230, Firemist metallic, 2012 GLK-350, Palladium
What did the problem turn out to be?
I've got exactly the same symptoms.
Surging while cruising. Like a "tug" every second or so.
Stumbling/surging at idle. 300-1K.
If I turn the engine off and restart, it will have gone away, so the dealership never sees it and can't fix it
I once got CEL with P0101.
Replaced the MAF, cleaned oil sep in compressor muffler (air intake).
No change.
It doesn't do it everyday. And never when it's at the dealership.
It's disconcerting/annoying on the highway.
When braking to a stop it feels errily/scary when it's tugging you as you come to a stop.
Then at idle, it will stutter to 300 and then surge to 1K, back and forth about once per second.
RicksterSLK is offline
#5 Old 06-04-2013
Quoted: 3701 Post(s)
RicksterSLK,
Want to post a picture? Start a new thread or make a post, click on the ‘paper clip’ or go to ‘advanced’ and then ‘manage attachments’ then ‘choose file’ then ‘upload’ and ‘submit’!
Wavetrac LSD thread here:
#6 Old 06-05-2013
Per ardua ad cineris.
Tolak's Avatar
Vehicle: SLK230 '99 R170
Other Toys: Clio Williams
No change.
Answer with a question; do these cars have an Exhaust Gas Recirculation Valve? These are used to cool teh exhaust gasses to reduce NOx emissions, and work under part throttle.
Typical effect is to cause a pause in acceleration as you pass 1500 revs, but if controlled erratically, would have the effect you describe.
Seems strange to use hot exhaust gasses to cool the exhaust gas flow; it actually puts inert nitrogen into the inlet manifold, so there is lots of gas but less oxygen to burn, so teh cylinder flame temp is decreased, and hence the NOx generation (which happens at high flame temps) is decreased.
Why is the exhaust gas only nitrogen? Because the right amount of fuel has been put in to burn all the oxygen in the previous cycle!
HTH.
Tolak is offline
#7 Old 03-26-2014
Vehicle: SLK 230 K R170 98
sorry for bringing up an old thread... what was the problem and did u find the solution in the end? does it have to do with the charcoal canister thing at the fuel line...?
bikz is offline
#8 Old 03-26-2014
bikz,
‘Usercp’ at the top left of page, then ‘edit your details’ on the left side, ‘additional information’ near the bottom, edit your ‘location’ and ‘vehicle’. Profile is NOT updated in your ‘garage’.
We’d like you to post an introduction in the ‘New members introduce yourself here’ section, if you haven’t already. http://www.slkworld.com/new-members-...yourself-here/
#9 Old 08-03-2014
Almost afraid to respond. It's been working well lately, probably will fail tomorrow
For a while, I continued to clean the maf once a month and all the other hoses with spray carb cleaner
One day I disconnected all the hoses with spay carb cleaner, including the short one from valve rockers (?) to intake manifold above the oil scavenger to make sure it was ok.
In the past, my blowing out of the tubes was just sticking the Small spray hose into the hose and giving it a **** until anything running out was clean.
This time I "sealed" the small hose in the hoses by wrapping with a tight corner of a rag. This pressurized and truly blasted the cleaner into/through the hose.
While blowing out all the hoses, I blasted a lot in the hose that goes down to oil dipstick.
Suddenly there was a "splorp" and a glop of oil came out the rocer manifold.
I'm guessing the check valve in the hose to dipstick was clogged -guessing.
If at check valve was clogged, the scavenged oil wouldn't drain. If it was stuck, oil would probably blast back up the hose. Both guesses old cause the probelem
Note that I don't actually see where ths check valve s, or I'd replace it...
I reassembled and haven't had a problem since.
Note. Had to replace that short hose. It was brittle and cracked while disconnecting.
I taped it up, but at next service, they noticed it and replaced it.
#10 Old 08-05-2014
Tolak's Avatar
Sounds like the MAF is the primary driver to cause this problem for you; similar for me.
You are now looking at the next stage of the oil scavenger system.
Many threads here, but in brief, the high flow scavenger is the obvious one beside the air filter; when the flow is fast enough, the swirl chanber gets the oil out of the air, and the fresh air goes into the (downstream of the filter) mixed airflow, and the oil drops down to teh sump. it is this tube that it sounds like you have cleared.
The low flow scavenger, with teh check vavle, is buried under the inlet manifold; there are two brass nozzles that allow the low flow to be sucked out of the head oil chambers, and then through the check valve to into teh manifold proper. Being limited to low flow by the nozzles, this often blocks, which results in teh high flow system coping with teh low flows, and having insuficient flow to work the centrifuge, the separation doesn't work, and the MAF gets oily.
As mentioned, many threads; once you get in there, change all the hoses under the manifold, since it's not a trivial task to get there to repeat the process.
Tolak is offline
#11 Old 09-10-2014
Clogged maf, p0101
I think my constantly fouling maf (p0101) was caused by a clogged check valve in the drain of the PVC oil scavenger. It drains into the oil dipstick tube.
Pull the large hose off the oil scavenger and flush with carb cleaner.
Plug with a wad of paper Owen and your finger to make it airtight and build up pressure as you spray.
Mine clicked a few times then I cloud clearly hear the sprat going into the oil dipstick.
Clean the maf and hopefully it won't come back.
#12 Old 03-09-2015
Vehicle: Obsidian Black SLK 350 2006 plus Silver SLK 350 2005
SLK Surge under light throttle
Well, well, well. Seems I am not the only one. We have been struggling for about a year 30 000km to find a solution. The MAF does get some oil on it, but cleaning does not ensure no surge, and an oily MAFdoes not mean it WILL surge. I have even had it surge with MAF disconnected electrically. Forget MAF. I will keep working with diagnostics expert who cannot identify even with laptop connected while driving the vehicle. Current possibility is the upstream sensor but a bit expensive to change just to test. I will post again if any progress is made or a solution found.
This is a R170 200 Kompressor, 2001 with 300 000 plus on the odor.
Good to know I am not alone.
JackEnden is offline
Human Verification
Help!!2001 slk230 Power Steering pipe googlem SLK R170 General Discussion 2 05-14-2012 06:26 AM
SLK230 Black Leather Heated and Power Adjustable Seats 1998-2004 slkparts SLK Parts For Sale 6 04-28-2012 04:01 PM
