Brake wear indicator still on after changing rotors and pads? - Mercedes Benz SLK Forum
 3Likes
  • 1 Post By JonB
  • 1 Post By SamuraiSpirit
  • 1 Post By JonB
#1 Old 09-16-2012
Vehicle: Silver 2002 SLK320 6 sped manual
Hey all,
I just changed my front rotors and pads as well as the brake pad wear sensors. The brake pad wear indicator lamp was on on the dash and I expected it to go out after replacing everything.
After I started the car the wear indicator lamp is still on. Is there anything I need to do to reset it?
I tried turning the steering wheel all the way left, all the way right and then back to center while the car was running, but no change. I also disconnected the negative battery terminal for a few minutes and nothing...
Any ideas?
Thanks for your help!
wasatchmountains is offline
#2 Old 09-16-2012
Bradley61496's Avatar
Other Toys: Cessna 140(dads)
I have a couple new ebc sensors if needed, Try disconnecting the battery!
Bradley61496 is offline
#3 Old 09-16-2012
Other Toys: 1986 560SL, 2012 VW Tiguan, 2008 GMC Sierra slt
Quoted: 73 Post(s)
There's nothing to reset on them, it could be a bad sensor, dirty contact or a bad connection. Unplug it and try again.
#4 Old 09-16-2012
There is a similar thread on here today. The cause was the sensor wire being trapped I think Run a search
JonB is offline
#5 Old 09-16-2012
JonB is offline
The Following User Says Thank You to JonB For This Useful Post:
#6 Old 09-17-2012
sokoloff's Avatar
Chats: 3
Quoted: 63 Post(s)
I assume you changed the sensors and installed new ones. I haven't had to do my rear brakes yet on the SLK, but is there a wear sensor back there too? One of my other cars has three sensors, two in front and one in the rear.
Len
2003 SLK320 36,000 miles
1959 220S Cabriolet - for sale -
1999 E300D 206,000 miles
2014 Smart electric 9500 miles
sokoloff is offline
#7 Old 09-18-2012
Vehicle: SLK R171 200k 2005
You should also change the sensor and clear the error if necessary.
The sensor on mine is situated on the front right wheel.
I have heard that they put the sensor on the wheel which is close to the hard shoulder (kerb) as this pad wears faster but I don't have proof for that.
SamuraiSpirit is offline
#8 Old 09-18-2012
I have heard that they put the sensor on the wheel which is close to the hard shoulder (kerb) - left for the UK but I don't have proof for that.
Mine are on the drivers side wheels UK right side. Another poor cost cutting effort by MB they should be on all four wheels. When my pads were changed after the light came on the left ( nearside) were almost on the metal because there is no warning sensor. I have said it before. The best sensors were on my old Camaro where a bit of spring steel was built into the pads. As soon as that started touching the disc you couldnt ignore it. Cheap and very effective as the sound was a bit like your fingernails down a blackboard
JonB is offline
#9 Old 09-18-2012
A couple of months ago I replaced my rear pads as I started hearing a whistle from the rear left wheel. I thought that such spring steel was the reason for the whistle but it occurred that the pads were just old and worn.
JonB likes this.
#10 Old 09-18-2012
love my SLK ( if its possible to love an inanimate object) but there are things about it I find a bit "cheap" considering the class of vehicle
JonB is offline
#11 Old 09-18-2012
My current pain is the rear window pillars. I have decided to cover them with carbon fibre but I am thinking to wait until the end of the winter season after they completely peel from the cold and snow.
#12 Old 09-18-2012
Mine are fine touch wood ( taps head) but if the did start to peel I would use "Carbon Fibre " sheet to cover them with without removing them from the car. I covered my laptop front where your hands rest with it as I had worn through the silver surface. Even if you had to replace every year or so its still got to be a cheaper and easier option than buying new panels
SamuraiSpirit likes this.
JonB is offline
#13 Old 09-18-2012
sokoloff's Avatar
Chats: 3
Quoted: 63 Post(s)
You made me check the EPC. Looks like my 170 chassis has two brake wear indicators, front left and front right. None on the back, but the rear brakes ought to last to 100,000 miles or more in most cases. Several comments above point out the need for every A and B service to be done whether it's a DIY job or taken into a service facility. Every B service has on it a requirement to both the pads and the rotors. As I have often said, Mercedes automobiles are not appreciative of deferred maintenance.
Len
sokoloff is offline
#14 Old 10-13-2016
Delucas's Avatar
Vehicle: MERCEDES SLK R171 -2009- MERCEDES - BENZ SLK 170 2000 -- MERCEDES A 170
Other Toys: ALFA ROMEO SPIDER 2000cc - VAUXHALL CORSA SR - LEGO STAR WARS 1791 X WING
Quoted: 538 Post(s)
Rear brake pads should last 100.000 miles or more ???
Are you sure .
Delucas is offline
Human Verification
DIY Brake job dsb SLK R171 Class DIY 39 01-17-2015 06:01 PM
Replace ROTORS and PADS 05 SLK mrdougie SLK R171 Class DIY 27 01-11-2015 10:49 AM
SLK 350 replacement Brake pads & rotors SuzaFan Performance MODS for the R171 12 04-14-2014 06:20 PM
'07 SLK 280 brake rec's: pads, rotors robster SLK R171 General Discussion 2 01-29-2011 01:10 AM
