Automatic Trans gets stuck in park! - Mercedes Benz SLK Forum
  • 1 Post By krazymaan
#1 Old 05-11-2012
Vehicle: SLK320 sport
Hey,
So this started happening last week and it's very odd. The gear shifter (it's an auto) gets stuck in Park. it's as if you aren't holding the brake when you try to shift out of Park. Yet I am.
The only way to release the gear shifter is to use the "tow truckers" method, which is to stick in a long device into the slot right below the P R N D and press in the release switch. We use a flat head screw driver.
Anyways, I want to know what's going on! This happened out of no where and hoping I can fix it myself. Any ideas? It's getting a little ghetto putting my Mercedes into Drive or Reverse using a screw driver
mattmintun is offline
#2 Old 05-12-2012
krazymaan's Avatar
Vehicle: 2000 SLK SPORT
Other Toys: More cars and diesels
back to the are you applying the brake pedal. When pressing the brake pedal do you hear/feel a click that allows you to move your lever out of park. if your hand is on the gear shifter, you should feel a click. If not the solenoid is probably bad or a blown fuse. Start there.
brawls likes this.
krazymaan is offline
#3 Old 05-13-2012
WOW good point, I remember always hearing and feeling that click but never registered that I stopped feeling it. I'll test it out one more time to be sure. Thanks so much for getting to me! I'll update once I check!
#4 Old 05-14-2012
Any ideas what fuse would be the culprit (if it is a blown fuse). I just checked and there is no audible click or physical "click" when I push the brake pedal in.
I found this fuse rundown of all fuses in each block. I can't find anything that looks like it'd deal with the brake.. help!
#5 Old 05-14-2012
Okay, seems like it might be the switch (after looking at many other posts). Is this the right part to order?
Brake Light Switch
#6 Old 01-14-2013
It happens to our SLK320 last week, shift gear stuck in "P" and we cannot reverse the car to be out of our garage. We called MB roadside assistence service and they sent someone who knows how to pull a car out without 4 wheels rolling, MB dealer inpected the program and told me the brake stop lamp switch was bad, they replaced it and it is running again now.
debbiefu is offline
#7 Old 01-14-2013
Quoted: 4092 Post(s)
debbiefu,
Moderator/Founding Member
Wavetrac LSD thread here:
#8 Old 02-26-2014
Vehicle: SLK320
Other Toys: SLK230
I have same problem. I replaced the brake light switch. Still stuck in park. Where is the solenoid or fuse that could be the problem?
brawls is offline
#9 Old 02-26-2014
brawls,
#10 Old 02-26-2014
Vehicle: SLK320
Other Toys: SLK230
Where are the solenoid or fuse that you are referring to? My slk320 has same problem. I replaced the brake light switch under dash but it's still stuck in park.
brawls is offline
Human Verification
Seats will not adjust / transmission stuck in park (both seemingly random) Goldstartaxidriver SLK R170 General Discussion 6 03-27-2012 05:53 PM
SLK320 stuck in park billy s SLK R170 General Discussion 4 10-09-2010 05:00 PM
Auto trans shift problem Reidmart1 SLK R171 General Discussion 5 08-14-2009 04:22 PM
trans service reveals defective trans control unit jameslk55 SLK R171 General Discussion 0 08-13-2009 07:03 PM
