Welcome to SLKWorld
Old 05-19-2007   #1 (permalink)
SLK World Junior Member
Question HELP!!! Erratic instrument cluster gauges and continuous beeping…
The supercharger on my 1999 SLK230 stopped working and my OBD II reader showed P1235, P1236, P1420 and P1525 codes. Thanks to this and other forums I was able to narrow it down to K40 relay (THANKS, I REALLY APPRECIATE ALL THE VALUABLE INFO!!!).
Two days ago I disconnected the battery (negative terminal) and removed the K40 Relay. Sure enough I found a bad/burnt connection and re-soldered it. Today, I re-connected all plugs to the K40 relay and re-connected the battery. When I sat inside the car I noticed the lights illuminating the clock, mileage and outside temp being “ON” (please see attached pics) and heard a continuous “beeping” coming from the dash. Gas gauge and engine temp needles DO move and stay at different position every time.
I started the engine and it runs fine. No “Check engine light” and no fault codes on the OBD II reader. Air pump engaged right away and it stayed on for some time. No RPM gauge readings. I took the car for a ride and it seems to be running great – supercharger kicks in, even though I can’t tell at what RPMs. No speed reading either…
Any ideas? Is there anything I need to reset after I re-connect the battery? PLEASE HELP…
Ignition Key OFF, Ignition Key ON and ENGINE RUNNING:
View rangelo's Photo Album rangelo is offline
Old 05-20-2007   #2 (permalink)
OK logically this is probably going to be related to the work on the module so check back all the connections, look inside the unit check the new joints are all OK and not causing any shorts and that all fuses look good.
You could try a battery cycle to see if that fixes it but i doubt its that nothing that needs resetting should cause things like that to happen.
If you verify everything you worked on is OK then it could have been an electrical spike that has damaged something int hat case its best get the car to the dealer and they can pop it on the diagnostic even if the codes they get done make sense they will normally point out a bad module or two.
Old 05-20-2007   #3 (permalink)
Vehicle: 99 SLK230
Other Toys: TOO MANY TOYS
When you heated the terminal for resolder, did the solder on the back side run to another point? Not familiar with the relay but have seen solder run behind when heated and short to another terminal. A thought.... Good luck
View 412driver's Photo Album 412driver is offline
Why the beeping after starting the car? mobidutch SLK R171 General Discussion 31 4 Weeks Ago 12:47 AM
Dumb ? How do I set the clock in the instrument cluster xpcdoojk SLK R171 General Discussion 2 08-12-2008 02:51 PM
New updated instrument cluster installed w/ lap timer nmslk SLK R171 General Discussion 4 07-10-2008 04:58 PM
Heater fan erratic bazzle SLK R170 General Discussion 6 10-30-2007 08:31 PM
Change instrument cluster to display digital mph chris_m SLK R171 General Discussion 30 07-17-2006 05:02 PM
