Mysterious oil leak-camshaft sensor - Page 2 - Mercedes Benz SLK World Forum
Go Back   Mercedes Benz SLK World Forum > Mercedes Benz R170 SLK Class Cars > SLK R170 General Discussion
SLKWorld.com is the premier Mercedes-Benz SLK Forum on the internet. Registered Users do not see the above ads.
Old 02-19-2012   #21 (permalink)
SLK World
Vehicle: 1999 slk 230
Originally Posted by markwade View Post
Latest sit-rep, all is now well, the main oil leak turned out to be coming from the oil level sensor which lives on the side of the sump, what was confusing the issue was that a small amount of oil was coming from above the sensor which I believe was coming from the cam adj solenoid, as mentioned before I have resealed the cam adj sol and fitted a new level sensor @ approx £48......sorted!
I have similar leak in my 99 slk. How did you change oil level sensor? Is it easy process? Just remove the bolts and put a new sensor in? DO you have to drain oil?
View slimsol's Photo Album slimsol is offline   Reply With Quote
Old 02-20-2012   #22 (permalink)
Vehicle: SLK 200 2001
Other Toys: Triumph Speed triple
Hi Slimsol,
Yes, the oil level sensor is an easy job. On my post face lift car I removed the engine undertray, drained the oil, removed the sensor and fitted the replacement unit.
View markwade's Photo Album markwade is offline   Reply With Quote
Old 02-20-2012   #23 (permalink)
SLK World
Vehicle: a black SLK 230, 2001 model
Other Toys: Too many....
Do anybody know the partno of the cam adjuster on a facelifted 230 SLK 2001?
View Dontino's Photo Album Dontino is offline   Reply With Quote
Old 10-08-2012   #24 (permalink)
SLK World Junior Member
Vehicle: 2003 SLK230
Just wanted to thank you guys for the great info you provide. Was looking up oil leak recall on slk230 due to cam adjuster selenoid and there you have it. Pictures, explanations, you name it. I don't know if my car has the problem yet, but at least I know where to look.
View drakeslk's Photo Album drakeslk is offline   Reply With Quote
Old 10-08-2012   #25 (permalink)
Gbarringer100's Avatar
Vehicle: 2007 SLK350 BLK/BLK
Other Toys: 2011 Jetta Sportwagen TDI
Suggest you go to dealer and have them check it and they might install the wire patch free of charge to prevent any future leak from entering the wire loom. Can not hurt giving it a shot.
View Gbarringer100's Photo Album Gbarringer100 is offline   Reply With Quote
Old 10-08-2012   #26 (permalink)
Bradley61496's Avatar
Other Toys: Cessna 140(dads)
Is this leak a recall? That would be nice, 2 weeks ago i noticed mine was leaking too, i bought the 3.00 o-ring to change it out but it never came when they delivered my other stuff from Mercedes dealership.
View Bradley61496's Photo Album Bradley61496 is offline   Reply With Quote
Old 10-08-2012   #27 (permalink)
it is a like a recall but no notice is sent out. When car is taken in to a dealer they will do the repair and install a wire patch. See below
SERVICE: GROUP 00 OF SERVICE INFORMATION BINDER
PARTS: GROUP I OF INFORMATION _ PARTS & ACCESSORIES BINDER
Campaign No. 2009100001, December 2009
TO: ALL MERCEDES-BENZ CENTERS
SUBJECT:
Models 170/203, Model Years 2001 - 2004 / 2002 - 2004
Replace the Camshaft Adjustment Solenoid(s) and Install Adapter Harness(es)
Revision Date Purposea 12/15/09 Inclusion of reimbursement information- 12/04/09 Initial issue
This Service Campaign has been initiated because Daimler AG (DAG), the manufacturer of Mercedes-Benz vehicles, has determined that due to the settling properties of the seal of the camshaft adjustment solenoid specification, oil may enter the engine wiring harness (es) through the electrical connection of the camshaft adjustment solenoid from capillary action. Dealers will replace the camshaft adjustment solenoid(s) and install an additional adapter connector harness (es) at the next workshop visit.
Prior to performing this Service Campaign:
^Please check VMI to determine if the vehicle is involved in the Campaign and if it has been previously repaired.
^Please review the entire Service Campaign bulletin and follow the repair procedure exactly as described.
Please note that Recall and Service Campaigns do not expire and may also be performed on a vehicle with a vehicle status indicator.
Approximately 66,113 vehicles are affected.
Old 10-08-2012   #28 (permalink)
So this is the problem with the oil leak? So if i take it to a Mercedes dealership, they may replace it free of charge if they choose to?
Old 10-08-2012   #29 (permalink)
shoot :/ its only on facelift models right?
Old 10-08-2012   #30 (permalink)
I would check with dealer and see what they will do. Nothing ventured nothing gained as the saying goes. Can not charge you for just checking.
Old 10-08-2012   #31 (permalink)
Lol, my dad says that a lot. Thank-you, i will check ASAP
DIY: How to change the oil on Mercedes Benz 2008 SLK 280 eshahwan DIY Section 2 03-28-2011 12:03 PM
check engine light on - oxygen sensors out? benz_bolek General Discussion 12 07-27-2010 10:19 AM
Oil leak after camshaft soleniod has been replaced? whatda Help and Support 2 07-13-2010 06:09 PM
camshaft magnet oil leak decky General Discussion 3 08-18-2009 09:22 AM
Blackstone Lab oil report - 2005 SLK350 fgwinn SLK R171 General Discussion 12 08-10-2009 06:11 PM
Powered by vBulletin Version 3.8.6
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SLKWorld 2006-2010
Design by Fife Web Solutions
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226
