Key won't turn in ignition switch - Mercedes Benz SLK Forum
 4Likes
#1 Old 05-26-2011
Vehicle: 2003 SLK320 Silver,
May 26, 2011
SLK320 2003 45,000 MILES
Been having this problem on and off for awhile. Key won't turn in ignition switch. Doesn't matter whether the wheels are turned or straight on. I have to turn the wheel until it locks and then struggle to turn the steering wheel until it frees up. One time I had to call road service I was so tired of trying to turn the wheel. Dealer has replaced the ignition switch but to no avail. I currently am having the dealer "research" this problem (over a week now) because I don't want to leave the car their while they "try" various things. My Indi has no idea what it can be. He says he has never run across this. I discovered a member who had this problem in Sept 2010 but don't know what the resolution was. Sorry to be so wordy.
HELP.
jafco is offline
#2 Old 05-26-2011
Pharm230's Avatar
Vehicle: 2000 SLK230 Kompressor
Mine does this sometimes too. But if I gently turn the wheel to the right just a bit (moving it only an inches) the key then turns. Wish I could offer a permanent solution.
Pharm230 is offline
#3 Old 05-26-2011
RUHROH's Avatar
Vehicle: 2007 SLK 55 AMG- Silver
Other Toys: FJ Cruiser & a Few Guitars
I had a 2006 R171 that did that. What I had to do was to insert the key in the ignition and while in the ignition press the lock button and the unlock button on the key (I assume that you have the electronic key). Sometimes more than once. It resets the key. Try it and see if that works.
Godspeed..
RUHROH is offline
#4 Old 05-26-2011
Godspeed..
Thanks for your prompt reply. R170's have mechanical keys. The electronic keys came in with the 171's in 2004.
Thanks again.
jafco is offline
#5 Old 05-27-2011
RUHROH's Avatar
Thanks again.
I wasn't sure if the R170's had the electronic key or not. Hope you can get the problem fixed. Good luck.
RUHROH is offline
#6 Old 08-17-2011
same problem
I know you posted this a while ago. Have you fixed the problem? If so, what was the fix?
I am having this same problem. I have a 2004 SLK230. I have to struggle to get the key to turn. The only luck I have is when I turn the wheel to lock and then jiggle the key alot. Today, it took me about 10 minutes to crank the car. The problem seems to be getting worse. I called a parts manager I know at mercedes, and he said it might be that the tumbler needs replacing?
ck-slk230 is offline
#7 Old 08-17-2011
Quoted: 3557 Post(s)
ck-slk320,
Thank you,
Founding Member/Moderator
Wavetrac LSD thread here:
#8 Old 08-18-2011
morpheusRO's Avatar
Vehicle: SLK 200 Kompressor R170 (2002)
Same problem occurred for me a few days ago. Any ideas? If the ignition switch needs replacement, the old key will still be usable?
morpheusRO is offline
#9 Old 08-18-2011
Vehicle: 2002 SLK230 black; ASP crank pulley; LED taillights; Black HID projector headlights
Yes, the old keys still work. Should replace the lock housing and the tumbler, not just the ignition switch at the end of the lock housing. The new lock housing comes with a new ignition switch. Follow the correct installation procedure if you are doing it yourself.
Mantist is offline
The Following User Says Thank You to Mantist For This Useful Post:
#10 Old 08-18-2011
morpheusRO's Avatar
Ok. Thank you!
#11 Old 08-22-2011
Vehicle: 2000 slk 230 kompressor
Other Toys: cars
ignition tumbler problems
Hi everyone:
Had exactly the same problem and finally solved it by removing the tumbler switch assembly. I took it to a key shop locally and they performed some magic on the tumbler. Re-installed the unit on the car and have never had the problem again.
I asked the shop technician why it happened and he explained that the tumblers will sometimes need to be readjusted. He filed the tumblers to match the key, which is why he requested a key that showed little or no wear.
He also warned me that it must be fixed or it will get to the point where the key will not rotate the tumbler lock, which is really big trouble, especially if you happen to be in a remote location.
Good luck and best regards. Chuck
cirvingjohnson is offline
#12 Old 09-03-2013
Vehicle: 2003 SLK-230, Firemist metallic, 2012 GLK-350, Palladium
Originally Posted by cirvingjohnson View Post
Hi everyone:
Mine is getting to the point where I have to jimmy the key five or siz times.
Sometimes I flip the key over and try again.
My wife refuses to drive the car.
Both my everyday key, and the spare that's hardly ever been used do it.
Can you point me to instructions on how to remove the tumbler?
Do I need to replace the tumbler?
Do you know what the "magic" is called so I can find someone who knows what to do?
Thanks.
RicksterSLK is offline
#13 Old 09-03-2013
Minion
slk320chick's Avatar
Quoted: 143 Post(s)
**note: this was the result of a google search - I have not personally completed this replacement
From justanswer.com
Customer:
from your drawings i assume this can only be completed by using sleeve 011?
eurotec :
The sleeve has a rubber insert and grips the outer ring, it sure helps to have the tool.
eurotec :
You might be able to make a tool or grip the ring with pliers but you will damage the ring.
eurotec :
It is not easy to turn the outer ring without the tool.
Customer:
is the part number below the drawing a mercedes part number
eurotec :
Yes it is, you should be able to Google the tool and find a supplier.
JaysonM likes this.
slk320chick is offline
#14 Old 07-23-2014
peas myth
Guest
Posts: n/a
Chats:
Quoted: Post(s)
New tumbler sticking in my r170
I've just replaced the tumbler in my 2004 r170 SLK after the key started to get a bit stiff to put in and take out of the old one. Taking the old tumbler out and putting a new one in is unbelievably easy once you know the simple steps of how its done.
Both my old key and a new key blade I bought with this genuine MB tumbler now go in and out of the ignition nice and smoothly. However unlike the old one, this tumbler sticks so I can't actually turn the key to start the car. I've found that if I deliberately lock the steering wheel, then rock both the wheel and jiggle the key simultaneously, after a few seconds it releases and I can turn the key and start the car. The key will then turn from position 0 to start and back, as many times as I like, without sticking at all. It's only once you remove the key and reinsert it that its sticks and you have to go through the lock steering, jiggle wheel and key process all over again. Looking at it with the covers off it appears to be the little white plastic part on the tumbler not releasing from behind a plastic part on the right side of the barrel, but I can't see or figure out why. It's especially puzzling as the old tumbler turns fine, I only replaced it because the key was stiff to put in and take out. Can anyone offer any suggestions.
#15 Old 04-25-2015
Vehicle: SLK 200K 2003
From justanswer.com
Customer:
eurotec :
eurotec :
eurotec :
Customer:
eurotec :
Exactly the same problem !
2003 SLK 170
Anyone know the replacement part for the whole assembly?
Can you make the tool 202 589 00 14 00 ? I have a lathe...
Frau_S is offline
#16 Old 04-25-2015
2003 SLK 170
#17 Old 04-25-2015
Professional Troublemaker
MikeWest's Avatar
Vehicle: 2004 SLK 200 Kompressor (R170)
Quoted: 15 Post(s)
Same Same
I'm having the exact same problem and I finally decided to fix it. I think the correct part (cylinder & key) is 2024601104 this site has a diagram.
I also need to get the proper tool (202589001400). At $132.50 that is an ouch. It beats not being able to reliably start the car though.
cliveandstella likes this.
Fun in the rain or sun!
MikeWest is offline
#18 Old 04-26-2015
Thanks, that was a useful pic.
I have dismantled it all, eventually, and can now drive the car with a screwdriver in the ignition switch and the key suspended in the coil with a molegrip. I am sourcing a replacement lock (that's what's jammed) from ebay (£90) and also a tool (£20) although I don't think the tool is necessary since you can twist the ring with molegrips once you get the trim and the coil off. The barrel 2024601104 is not the problem.
I'll let you know how I get on...
Frau_S is offline
The Following User Says Thank You to Frau_S For This Useful Post:
#19 Old 04-26-2015
Don't forget your intro thread please:
#20 Old 04-28-2015
MikeWest's Avatar
Quoted: 15 Post(s)
Ok, looks like the cylinder & key isn't enough, I need to replace the entire assembly (part 10 on the diagram). According to this site (diagram & parts list included), the part number is 2024600904. I'll post more when the parts arrive. As of now, my car is stuck at the office Looks like if I can't get lucky and convince it to start and get it back home I will be doing the swap in the parking lot sometime soon.
MikeWest is offline
Human Verification
Smart key (ignition key) El Barco SLK R171 General Discussion 26 11-28-2012 08:51 AM
Ignition switch connections..? kole301 SLK R170 General Discussion 2 03-23-2010 07:40 AM
Good battery, turn key no start mrdougie General Discussion 10 02-13-2010 11:02 PM
