Charging problem - Mercedes Benz SLK Forum
#1 Old 03-19-2011
Vehicle: 1998 SLK 230
Charging problem
My 1998 SLK 230 tried to die in traffic when I was running all accessories on a stormy night (wipers, fan, defogger, headlamps, radio). I limped to a parking lot and came back with a new battery.
After testing the alternator and seeing only 12V while running, I changed out the voltage regulator. No change: still only 12V (11.5 under medium load). I removed the alternator and had it bench tested. 14V + . Put it back on the car. 12V. Revved up the engine. No change. 12V (11.5 under medium load).
The car starts and drives fine and all electrical accessories function but I just know it's going to strand me again when the battery is unable to keep up with demand.
Anyone run into this before? Why the hell does the alt work fine outside the car but not in it?
Ernie
erniel2 is offline
#2 Old 03-19-2011
Other Toys: 1986 560SL, 2012 VW Tiguan, 2008 GMC Sierra slt
Quoted: 73 Post(s)
Welcome from New Hampshire
#3 Old 03-19-2011
Quoted: 4096 Post(s)
erniel2,
If you wish to PM (Private Message) someone, you need 15 posts. To get those 15 posts quickly, just go to the ‘new members introduce yourself here’ section and welcome enough new members to obtain your needed posts to PM.
Wavetrac LSD thread here:
#4 Old 03-19-2011
Vehicle: 2005 SLK 350
Other Toys: Several R170's
Quoted: 413 Post(s)
Hmm... I'd check the cables, and the grounds between the engine and body. What's your VIN, I'll look up where these are.
efair is offline
#5 Old 03-19-2011
Vehicle: I like it a lot
Other Toys: slk55
Quoted: 11 Post(s)
check the electrical connections such as the ground, battery terminals and alternator itself.
Also highly possible that the alternator is on its way out. They tend to fail in stages, and not all at once. You could try seeing if the battery holds a charge overnight to see if the battery is the culprit.
rya96797 is offline
#6 Old 03-25-2011
Not sure where to post this so I'll continue the dialogue here.
Replaced Alt, battery, and K56 crach seperation relay. Alt is charging 19V at the gen post of the relay but the battery side of the relay only sees 12V (less under load).
So I know for a fact the alt is working and the battery is known good. What would cause the brand new relay to fail to pass the charge along to the battery?
erniel2 is offline
#7 Old 06-25-2011
Voltage regulator 1998 SLK230
I did go to Autozone & the voltage regulator is bad. Where do you get one?? Link or phone number to a vendor that actully has one. What are part numbers. People that look on these forums are here because someone has sucessfully done this job, are you out there - I need voltage regulator part number that can be purchased - found plenty of links to vendors that after you get to their site do not have any for my car. Number on the old regulator returns nothing in searching on the net. Who knows where to get a voltage regulator for a 1998 SLK230, help! Part number on my current Bosch voltage regular is 1197311533 - can not find it or a replacement part number.
mkressgold is offline
#8 Old 06-25-2011
mkresgold,
Thank you,
Founding Member/Sergeant-at-Arms/Moderator
Human Verification
99 SLK 230 Charging Problem Nanner General Discussion 1 07-30-2010 04:11 PM
Dead battery and auto gearbox problem... kole301 SLK R170 General Discussion 9 07-21-2010 09:48 AM
