SLK Hardtop / Windows Problem - Mercedes Benz SLK Forum
 3Likes
#1 Old 11-30-2010
Vehicle: 2002 Mercedes SLK230
Other Toys: BMW Z3
I recently purchased a used 2002 SLK230 in Miami... it drives great and the top worked fine when we tested it
However just a week ago I started have top issues... I live in FL and keep the SLK garaged so I often leave the top down
However now when I attempt to raise the hardtop it comes up and latches and the trunk lowers but then it stops... the back windows do not go up and when I drive it Beeps at me as if the top is not closed properly. Luckily it does go back down without any problem.
What can I do about this? Please Help!
Archangel_rmd is offline
#2 Old 11-30-2010
Quoted: 3855 Post(s)
check the switch that the trunk cover clicks into.
Wavetrac LSD thread here:
#3 Old 11-30-2010
Other Toys: BMW Z3
I checked that and it looks fine... it fact everything in the trunk looks fine... and as I mentioned the top goes up and down smoothly... it just doesn't finished the going up process and roll the windows up and since the button is red and beeps it even knows it's not done... what could cause it not to finish?
#4 Old 12-13-2010
Other Toys: BMW Z3
Here is my diagnostic... not totally sure how to check these things though... any help out there??
SLK
Rear side windows are not raised:
Vario roof "locked" limit switch (left rotary
tumbler) (S69/3)
Vario roof "locked" limit switch (right rotary
tumbler) (S69/2)
Trunk lid "open" limit switch (S69/9)
Left trunk lid "closed/locked" limit switch (S69/7)
Right trunk lid "closed/locked" limit switch
(S69/8)
Voltage supply for power windows
Multi-function control module (N10-3)
Hydraulic pump (A7/5)
Vario roof solenoid valve (A7/5y1)
#5 Old 12-14-2010
leapyfish's Avatar
Quoted: 33 Post(s)
leapyfish is offline
#6 Old 01-16-2012
Vehicle: 1998 SLK 230 Kompressor "Blue Demon"
Other Toys: BMW i235m and big black beauty BMW X5
hello ,
i have the same problem, back windows won't go up. how did you get your to go up please
offdepp is offline
#7 Old 01-16-2012
back windows are designed not to be up with top down. is that your issue?
#8 Old 01-17-2012
no my problem is the windows won't go up after the top is up and front windows are rolled up . they have only gone up once since i got the cute little car in july 2011.
please help
the closest dealer in hour away and they aren't any smarter then my kitten prissy
offdepp is offline
#9 Old 01-17-2012
what windows won't go up? the rear ones? you might have done this but after the front windows are up, double click the window switch again and see if they go up.
Scratcher09 likes this.
#10 Old 01-17-2012
Der Flieger's Avatar
Vehicle: silver/red 06 350
Quoted: 119 Post(s)
Are the trunk bumpers (screw adjusters to stop the trunk from vibrating when it is closed, at the leading/front edge) even? If not, the trunk may not be fully closed at the front.
FUN 4 2
Der Flieger is offline
#11 Old 01-18-2012
WOW i will check tonight
thanks you guys are great
offdepp is offline
#12 Old 04-26-2012
Trunk locks S69/8
Hey I was just going to see if you ever resolved the problem?
If so, what did you do? I am having the same issue with the trunk locking
New_Money is offline
#13 Old 04-26-2012
MrG
Vehicle: Black '02 SLK320
SLK
tumbler) (S69/3)
tumbler) (S69/2)
(S69/8)
Since the next function in the closing sequence is the rear windows raising after the trunk lid is closed and locked, I'd check these two switches first. The front windows go up a few seconds after the rears.
MrG is offline
#14 Old 04-30-2012
back windows
i haven't fixed it but i have figured out a trick to get the windows up. after the top is up i would press on the driver side of the trunk then push the top button again and all the windows go up. i am sure it is a micro switch on the drive side but i haven't had time to play with it. it is easier just to get out of the car press lightly on the trunk and hit the top button again. let me know if that helps.
offdepp is offline
The Following User Says Thank You to offdepp For This Useful Post:
#15 Old 06-17-2012
Vehicle: 2000 Mercedes SLK230 Sport
Quoted: 7 Post(s)
My 2000 Mercedes SLK230 side windows would not go up during top closing
I just ran into the same problems as Archangel with my 2000 Mercedes SLk230 where the windows would not go up during
the closing operation. My Mercedes would get to Step 4 and the small windows would not go up and you could hear
the motor running but nothing. The door windows would not go up during the operation, only manually.
I ended tearing the Mercedes apart and first ohmed out the left/right trunk lid limit switches (S69/7 & S69/8) and
they both ohmed out good. Then ohmed out the Vario roof limit switches using the yellow connector in the trunk right
side area and it turned out to be my problem. The circuit had an open and I was lucky to have another
S69/2 &S69/3 circuit to replace it with and now works just fine. Unfortunately when I took out the left trunk lid limit
switch, the cable came off the bottom of the rear actuator and the trunk lid would not unlock during the open
sequence but again thanks for others having issues it led me to the problem.
I have to say thanks for this forum otherwise I would not been able to fix my car on my own. It has become an
incredible place to go to learn more about your own personal car. A couple of months ago my front locking actuator
began leaking really bad and I used the forum to learn how to take the car apart and fixing my front locking
actuator and putting back in. Still had to replace the headliner ($203 ouch).
If anybody has run into the same problems and needs some assistance, let me know?
Archangel, did you ever fix your problem with your Mercedes?
Lanny
lannylord2000 is offline
The Following 2 Users Say Thank You to lannylord2000 For This Useful Post:
#16 Old 06-18-2012
Wizard of ID
tcrankwa's Avatar
Quoted: 20 Post(s)
These guys are great aren't they?
Lord knows they've saved me a ton of time and money!
Sportlich, Leicht und Kurz
Margie and Terry
tcrankwa is offline
#17 Old 06-27-2012
Vehicle: '02 slk32
Other Toys: Time RXRS,Moots Rigormootis, Colnago C40, Lotus Elise
an obscure but tricky problem I had is the trunk switch actuator levers on the trunk had come loose and would cause error codes, beeping and switch light staying on. have to stop the roof at mid point of opening or closing to be able to check it. this caused me grief for 4 months until I found it.
bruco1 is offline
The Following User Says Thank You to bruco1 For This Useful Post:
#18 Old 12-16-2012
Red face Hard top trunk will no close when UP!!.
Lanny
Hey lannylord2000
I'm having the same problem SLK 230,
leaking top cylinder was fixed and everything works but trunk will not close once the top is UP and locked!! will go down and lock the trunk but when up will not close the trunk!!
any help will be greatly appreciated!
also the plastic rod that align the roof where broken last time the roof was raised manually!! Anyone know if the black plastic rods coming out the latches on the top of the roof need to be in one piece for the roof to actually finish closing and put the little windows up??
thanks everyone in advance!
lito420 is offline
#19 Old 12-16-2012
lito,
Thank you,
Moderator/Founding Member
#20 Old 12-17-2012
Quoted: 7 Post(s)
Hardtop operation: Trunk won't go down
lito420, I believe without checking further on the steps of the hardtop operation, it is the microswitch in the upper right top hole of the windshield. The little black aligning rod sets the microswitch so that steps knows to let your trunk down. If you find the step chart, it might helps to assist.
Lanny
Human Verification
2001 SLK Manual gear selection problem JasonB SLK R170 General Discussion 1 03-12-2010 05:17 PM
Rear Windows - problem? garylight SLK R171 General Discussion 10 03-19-2009 08:37 AM
SLK 200 Kompressor owner! small problem! T24 New Members Introduce Yourself Here 17 03-01-2009 05:57 PM
