Welcome to SLKWorld
Old 07-07-2006   #1 (permalink)
myslk230's Avatar
Vehicle: 1998 slk 230 kompressor
Other Toys: 98 jaguar xj8
Default air filter
what is the best air filter for an slk230 any suggestions?
View myslk230's Photo Album myslk230 is offline
Old 07-14-2006   #2 (permalink)
Vehicle: '05 SLK350
from the research i used to do for when i had my 230, best were the green filters followed by K&N. Reason for green filter was that it was less oily. If you do go with K&N, it was recommended to let it sit over night and drie a little. Since the MAS sensor is located at a perfect spot for the oil to drip on, it is the first sensor to go (which was an issue with some people)
How about an atmospheric bypass for that supercharger valve of yours?
I did it on my '00 SLK230... and it sounded amazing when you let off the gas.
If you do a search on Benzworld for all posts by my forum name in the R170 forums, you will find a bunch of threads on the setup.
This is not my setup... but i did mine in a similar way
http://www.benzworld.org/forums/atta...5457am.jpg?d=0
Old 07-14-2006   #3 (permalink)
myslk230's Avatar
yes i have done this but myu check engine light came on any suggestions?
Old 07-14-2006   #4 (permalink)
Vehicle: '05 SLK350
well if your car is running fine, no loss of power or anything. Then the silly light is just reading a code. I used to get them all the time for no reason what so ever. You can either have it cleared with an OBDII or just learn to ignor it.
I'm not sure if you know this already, but the car HAS TO BE OFF when you refuel. Else you get the light, the cap has to be on tight, else you get the light. There are a few things dealing with gas cap that can cause the check engine light to go on.
Old 07-14-2006   #5 (permalink)
myslk230's Avatar
well what did you use to make the air filter fit to the MAF
Old 07-14-2006   #6 (permalink)
Vehicle: '05 SLK350
I had a flange welded together at a local shop. It fit right onto the MAF and allowed me to hook up a cone filter.
However i thought i saw a flange similar to size and fit sold at AutoZone (local auto store - for those who are international)
Best way would be to use a custom made flange.
Old 07-15-2006   #7 (permalink)
bazzle's Avatar
Vehicle: slk230 1998
Well if you hooked it to the MAF you would nt have a supercharged car??
MAF is off the intercooler on other side of car to where supercharger and OE airfilter is.
I would just use standard paper filters in original housing. Many tests written, have shown not a lot is gained from changing anything in this area other than, less filtering, more noise, MAF problems.
Bazzle
Old 07-17-2006   #8 (permalink)
myslk230's Avatar
yea well i put the stock filter back on and i think im going to buy the pulley kit soon
Old 07-23-2006   #9 (permalink)
SLK World Junior Member
Hirashiki's Avatar
Vehicle: SLK KOMPRESSOR; E320 COUPE
I just changed the air, and cabin air filter. Both from the dealer. Put me back about 70 bucks..
View Hirashiki's Photo Album Hirashiki is offline
air filter location??? antony-r171 SLK R171 General Discussion 5 09-15-2008 04:29 PM
Anyone tried this air filter kit? MaKEuhigh SLK R171 General Discussion 1 08-29-2008 10:36 PM
air filter mikestelfox Performance MODS for the R170 5 06-04-2008 05:00 PM
saw this air filter on ebay... st2288 SLK R171 General Discussion 6 04-03-2008 05:16 PM
Cleaned Air Filter tai230k SLK R171 General Discussion 16 06-04-2007 01:34 AM
