Welcome to SLKWorld
LinkBack (1) Thread Tools
Old 02-15-2007   1 links from elsewhere to this Post. Click to view. #1 (permalink)
Vehicle: 2004 SLK320 Special Edition
Other Toys: 1967 VW Microbus, Custom 2003 Mustang GT, Gulfstream BT Cruiser
Unhappy How to remove door panel?
I posted this on another forum but haven't gotten any replies. I dropped my door lock pin down into the door. Is there any special trick to loosen the bottom of the door panel so I can reach in there and get it? Or, does it just pop out like some American cars, then pop back in? I'm worried about damaging the fasteners.
Thanks,
Dr. T
View doctort's Photo Album doctort is offline
Old 02-15-2007   #2 (permalink)
bazzle's Avatar
Vehicle: slk230 1998
It does but there is plastic film inside over panel.
Undo black metal corner cap on top of door end, pull out SRS badge on panel , remove screw behind.
Pop trim using a wooden or plastic wedge. Can use your fingers if you want.
The plastic trees "may" pull thru the panel. easy ro reglue in.
If you want to remove whole panel pull off cover over interior handle and remove screw there and door handle too.
Bazzle
Old 02-15-2007   #3 (permalink)
Default Thanks
Thanks for the info, Bassle. I think all I'll need to do is be able to get into the bottom of it to get out the door lock pin. Dumb thing to let it slip through like that. Oh well
Old 02-17-2007   #4 (permalink)
bazzle's Avatar
Use a bit of fine fencing wire with a tight "U" on the end and fish it out thru the top hole..
BAzzle
Old 02-19-2007   #5 (permalink)
Actually, I don't think I'd be able to do that. What happened is that, when I tried to screw the new chrome lock pin onto the the treaded shaft inside the hole, I missed getting it down over the shaft because it was sitting over at the edge of the hole. So, the lock pin passed next to it as I slid it down to screw it on and slipped on down into the hole and then fell on down into the inner area of the door. I'm guessing it's sitting down there in the bottom of the door now. In the mean time, I screwed the black plastic one back on. I tried to remove the door panel, but I'm not sure how to get the cover off the arm rest (there seems to be screws under it because that area of the door panel won't pull out after I unsnapped the bottom of it.
Old 09-10-2007   #6 (permalink)
SLK World Junior Member
Hi
Can some one please tell me how to completly remove the door card? Car is a 2001 SLK230 and had airbags in the door card.
View audi-a2-al's Photo Album audi-a2-al is offline
Old 09-10-2007   #7 (permalink)
Gabus's Avatar
Vehicle: 96 SLK 230K
Other Toys: Volvo L3314N
Here are some piturs. http://tinyurl.com/3ykc73
It's in german........ but there's not soooo much text
Schrauben = screws
Gabus
Old 09-15-2007   #8 (permalink)
Cheers hopefully ill have time to see what the problem is on sunday
LinkBacks (?)
LinkBack to this Thread: http://www.slkworld.com/slk-r170-general-discussion/1874-how-remove-door-panel.html
Posted By For Type Date
Remove Slk Door Panel: Basic Facts, News, Articles, Reviews, Images, Videos and more This thread Refback 3 Weeks Ago 12:08 PM
SLK230K door panel Elvis Shmelvis Help and Support 1 04-17-2008 11:12 PM
Broken B pillar panel cover Zut SLK R171 General Discussion 20 10-23-2007 08:16 AM
Does anyone know how to remove the door handles etc? aquascape General Modifications R171 5 07-27-2007 02:50 PM
Remove door panel trim ssoji Ask DansSLK 1 09-13-2006 12:16 PM
How do you remove the shift knob? How do you remove the little badge on cyberdrakon General Modifications R171 5 08-28-2006 04:01 PM
