Engine stumbling when first starting in the morning - Mercedes Benz SLK Forum
#1 Old 07-06-2010
Vehicle: 2000 SLK230 Kompressor
Other Toys: 2001 Land Rover Disc., 2008 Land Rover LR2 , 2006 Pro-line 36' Sportfish, 1981 Piper Comanche Twin
I have a 2000 SLK230 and suddenly I've experienced trouble when first starting the car after it has sat overnight. The car used to start up smoothly on a high idle and then after letting it warm up, it would idle down and work fine.
Now when I start it, it stumbles on low idle and if I press the accelerator pedal, it simply stumbles worse until to stops running. I've had to work and work to get it going in the morning for the past several days, so I'm assuming that something has gone wrong. It's like the choke system is not working for some reason.
Any ideas what could have happened? Is this a fuse problem or do I have some kind of system component problem?
thanks
benzer101 is offline
#2 Old 07-06-2010
Durkatlon's Avatar
Vehicle: 2009 SLK55
Quoted: 190 Post(s)
I've had these symptoms with an old Ford Escort I used to drive when cylinders started conking out. This was ultimately traced to a leak in a seal, causing coolant to enter the engine block.
Durkatlon is offline
#3 Old 07-06-2010
Vehicle: 2006 SLK55
Does it still stumble once warmed up?
Any codes?
Did you check the intake system AFTER the MAF? Look for leaks, loose clamps.
Did you try cleaning the MAF. (CRC MAF cleaner)
Look for loose plug wires and/or cracked plugs too.
Todd157k is offline
#4 Old 07-06-2010
Quoted: 3557 Post(s)
benzer,
In addition, if you haven’t, please post your questions in the appropriate discussion forum for a quicker response.Be patient and a knowledgeable member or guest will address your question.
And finally, if you find something useful on your visit here today, perhaps something that saved you time or money, please consider becoming a donating member or make a one-time donation to offset development and operating costs. Even $5 is welcome! At the top of the page, click ‘Donate’ and then ‘Donate now’. Thanks!
Wavetrac LSD thread here:
#5 Old 05-28-2011
Vehicle: 2000 SLK 230
Send a message via Skype™ to westrava
I wish I could help, but I have the exact same problem on my 2000 with 70k miles on it.
If I start it up and drive right away the transmission kicks in first gear and again in second gear. Then it's fine the rest of the time.
If I start it up and wait for about a minute, I can drive off with no problems with the lower gears, smooth as could be.
If anyone else has had this problem, and a fix, I'd love to know.
Thanks.
--Randy
westrava is offline
#6 Old 05-28-2011
Vehicle: 2012 SLK55 AMG, Diamond White
Other Toys: 2010 TT Black Edition
Quoted: 82 Post(s)
Thanks.
--Randy
I also have this problem. I put it down to either a need for new transmission fluid or a sensor starting to wear out somewhere.
Captainrave is offline
#7 Old 05-28-2011
almost a year since the original poster asked his query.
#8 Old 05-28-2011
leapyfish's Avatar
Quoted: 33 Post(s)
Thanks.
--Randy
Its not a problem, its the way the ecu works
when the engines fluids etc are warmed up it lets you drive normally.
Vario roof
R170 & R171
SLK 230 320 32AMG
leapyfish is offline
#9 Old 06-15-2011
Vehicle: 2000 SLK 230 Kompresspr Conv
Same thing happened to me. Turned out to be the Injector Coils. They are located under the red cap on the engine. You dont necessarily need to buy both but there is no way of telling which one isnt working unless you hook the car up to the Computer. Buy them and replace them yourself. Really easy job. And the car is running like normal again
Juanbamf is offline
#10 Old 07-19-2011
Vehicle: 1999 slk 230 Kompressor
Other Toys: Morgan OI51 sailboat, formerly owned many airplanes as I owned an air freight operation
I have the same problem, and then my CEL comes on mabe ten miles later... I disconnected my battery for about 5 minutes and then the car started normal for about 2 days and of course went back to the rough start... Very annoying.. Don S.
don33764 is offline
#11 Old 08-06-2011
Thanks Juanbamf, my issue was with the injector coils too. I replaced the spark plugs, still had the stumbling problem when engine was cold. Found injector coils online for $57 each, brand new. Replaced both injector coils and tada, no engine problems.
--Randy
westrava is offline
#12 Old 08-06-2011
leapyfish's Avatar
Quoted: 33 Post(s)
If the CEL is on get the codes read!
Vario roof
R170 & R171
SLK 230 320 32AMG
#13 Old 08-09-2011
Fyrelight's Avatar
Vehicle: 2000 SLK 230 -- Designo Orange
Other Toys: No Toys, just Tools.
I learn a lot here . . . usually http://www.slkworld.com/images/smilies/smile.gif
Injector coils???? . . . never heard of such a thing . . . will put them on the list for replacing . . . new owner of an 11 year young SLK so looking for how to make it better
Fyrelight is offline
Human Verification
DIY - Engine mounts replacement for post facelift R170 Mantist SLK R170 class DIY 31 05-03-2016 12:23 AM
AMGPL: AMG 5.5-litre V8 biturbo engine Cold Shot AMGs 14 03-21-2010 10:11 AM
E 430 Amg dltslk Mercedes Benz Posers 4 04-02-2008 12:36 PM
Mercedes Benz DiesOtto Engine MarkR171 Off Topic 3 07-26-2007 09:05 PM
models and prices SLKman General Discussion 23 02-09-2007 05:02 AM
