| | LinkBack (1) | Thread Tools |
#1 (permalink)
| Elite SLK World Member Join Date: Aug 2006 Location: Long Beach, Ca
Vehicle: SLK32 AMG
Country: Thanks: 74
| I was cruising through the crossfire forum and came across this tidbit. Anyone notice rust at the bottom of the door. The crossfire is based on the R170 platform and the door seal looks the same. |
| Elite SLK World Member Join Date: Sep 2006 Location: Kaiserslautern, Germany
Vehicle: 2000 Designo SLK230
Country: Thanks: 92
| Yuck. Maybe its got something to do with being on the coast? Mine came from FL. I'll give it a good going over once it gets here. Thanks for the post!
__________________ Kevin An American in Germany... To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. '00 SLK230 Designo copper, '06 Saturn Vue, Cessna 172 (pilot) |
Vehicle: SLK32 AMG
Country: Thanks: 74
| No Kevin, I don't think it's from being close to the coast. You have to live right on the beach for salt air affect. I believe it's from washing the car. I've noticed a lot of water under the door seal when drying. Shut the door after drying and re-open and there's more water to dry off. People that live in areas of the world that rain and snow frequently should check behind the door seals because they are dealing with road grit and salt. |
Country: Thanks: 92
| Well if it's from washing the car, I shouldn't have to worry too much than. But now that I'm in the land of regular rain (Vegas was not!) I'll have to keep an eye on it. I imagine I'll find out soon enough how the roof seals are too!
| Elite SLK World Member Join Date: Jun 2006 Location: Melbourne Australia
Vehicle: slk230 1998
| Good link, thanks So I pulled my seals, luckily no rust BUT soap residue and both sides were damp. Wiped them out with a damp rag, seals too, allowed to dry and sprayed Powerplus dewatering fluid in the recess (Powerplus leaves a light brown residue behind that doesnt seem to evaporate like CRC, WD40 kero based stuff). Hopefully it wont hurt the seal but they will be easier to replace than to fix rust later. Popped the seals back in. Bazzle |
| | #8 (permalink) |
| SLK World Member Join Date: Nov 2006 Location: Co. Durham
Vehicle: SLK 230 1998
| I've checked this and i've no rust there thankfully, although this winter has revealed much more visable rust (I suspect due to the incredulous amount of road salt my local council is using). I have a small amount of rust appearing on the passenger side door, right at the edge (Where the paint is thinest) - See below (The picture disguises it somewhat, but it is definetly there); ![]() This brings me onto a related subject and a couple of questions I have; 1) Can any North East, England users recommend anyone to sort this problem out. I'm heavilly waxing to protect from further erosion in the mean time. 2) All members; Long Term - maybe back end of the year / next year I am considering a full respray; a) Will this increase or devalue the car. Would this depend if I stayed with the original colour or changed completely (I'd quite like to see me SLK in Caspian Blue). I would get this done professionally so no orange peel/flaky paint. b) Would you recommend it Cheers Elwood |
LinkBacks (?)
LinkBack to this Thread: http://www.slkworld.com/slk-r170-general-discussion/1669-any-door-rust.html | ||||
| Door Seal corrosion - Benzworld.org - Mercedes Benz Discussion Forum | This thread | Pingback | 01-28-2007 02:53 AM | |
| Door Leather | Baron7700 | Caring for your SLK | 17 | 1 Hour Ago 03:56 AM |
| Scissor door? | 053GMN | General Modifications R170 | 13 | 1 Week Ago 04:20 PM |
| Drop down door... | reallife | General Discussion | 8 | 12-16-2007 08:07 PM |
| Roof rust | bejak | SLK R171 General Discussion | 17 | 09-11-2007 09:47 PM |
| door pins | pimpslk | Ask DansSLK | 3 | 07-21-2007 08:13 PM |
