fuse box diagram - Mercedes Benz SLK Forum
 3Likes
  • 3 Post By Dull Witch
#1 Old 04-11-2010
tristansbenz's Avatar
Vehicle: 2001 SLK 230 Black
fuse box diagram
hello i was wondering if anyone had a fuse box diagram they could email me or post iv been having problems with my 2001 SLK 230 for some reason when i turn my car off not everything turns off with it i don't no what it is but it will kill my battery if i leave it hooked up i just check the battery and it is good so i no its not that but from this point i don't no where to go so some help would be greatly appreciated my email is tristansbenz@yahoo.com thanks
tristansbenz is offline
#2 Old 04-11-2010
Quoted: 3855 Post(s)
have you checked your owners manual for the fuse box diagram?
Wavetrac LSD thread here:
#3 Old 04-11-2010
yes i have it was just a small piece of paper in the fuse box on the drivers side but it has seemed to have disappeared
#4 Old 04-11-2010
so you did or did not find the picture of the fuse diagram in the manual?
http://www.mbusa.com/mercedes/#/servPrtsOwnersManuals/
check 2000 and 2002 manuals for fuse box
the fuse diagram is also located in the vehicle tool kit
#5 Old 04-11-2010
i did not i dont believe there is one inside the manual
#6 Old 04-11-2010
i'm searching google now
#7 Old 04-11-2010
i was doing that for about an hour and a half today
#8 Old 04-11-2010
this is from r171 not r170 but maybe it will get you close
http://www.billsden.org/fileadmin/me..._locations.pdf
The Following 2 Users Say Thank You to jbanks15 For This Useful Post:
#9 Old 04-11-2010
idk that one isent going to work it looks nothing like my fuse boxs
#10 Old 04-11-2010
and you checked in the trunk for the vehicle repair kit?
#11 Old 04-11-2010
there should be a fuse box diagram in the trunk in the vehicle repair tool kit
#12 Old 04-11-2010
i dont have a vehicle repair tool kit the car dident come with one
#13 Old 04-11-2010
Vehicle: SLK32
Try this...
Tslick is offline
The Following 10 Users Say Thank You to Tslick For This Useful Post:
#14 Old 04-11-2010
thank u so much it is greatly appreciated
#15 Old 04-12-2010
paultalb's Avatar
Vehicle: '04 SLK32 //AMG
Other Toys: Tundra, Mini All4
Chats: 7
Originally Posted by Tslick View Post
Try this...
Been looking for that as well, thanks..
paultalb is offline
#16 Old 04-12-2010
Vehicle: 2006 SLK55
Here's a pic of mine. Although not as clean, or any better than the one above, it does show a part number in the corner so you could order one.
Todd157k is offline
The Following User Says Thank You to Todd157k For This Useful Post:
#17 Old 04-18-2010
Donor Conversion
Vehicle: Lovely Black SLK32
Chats: 7
Hi
... no better than TSlick or Todd's, but for completeness here's a GB version from a 2000 SLK 32AMG
Kind regards,
Jonathan
jonathan is offline
The Following 2 Users Say Thank You to jonathan For This Useful Post:
#18 Old 08-03-2011
Vehicle: 1998 230 SLK
Other Toys: 1966 Jaguar E-Type FHC
I have this chart in my car in the fuse box in the engine compartment. The problem is that none of these call out anything for the interior fan. I pulled 36, the 30 amp labeled Tempmatic, but it was not burned through. There was a little black below the plastic, but the main metal inside the fuse was solid.
jsc6546 is offline
#19 Old 08-06-2011
Veloman's Avatar
Vehicle: 2004 230SLK
If your interior heating/cooling fan runs after you shut down it's probably because you have the heater control in recirculate position. If you go to rest off your fan should stop.
Veloman is offline
#20 Old 01-12-2017
Vehicle: 2002 SLK32
Other Toys: 280SL Pagoda, RR Evoque, Smart Fortwo
Love this place
My son just put both of our windows down and up again to clear some snow. They went almost all the way up before stopping and not then doing anything. Quick search on here, fuse 19, 40amp. Swapped it out in the snow under the light of my phone and all is good with the world once more.
jbanks15, savcom and ndicroce like this.
Dull Witch is offline
Human Verification
SmartTop Roof module Install for the R171 etyu SLK R171 Class DIY 12 4 Weeks Ago 09:04 PM
Why Does my Interior Dome Light Fuse Keep blowing? DashingDaryl SLK R170 General Discussion 4 07-21-2011 12:17 AM
Fuse box in trunk/boot jmeredith SLK R171 General Discussion 6 07-28-2010 02:14 AM
LASER JAMMER Install editor58 Performance MODS for the R171 23 09-22-2008 05:45 AM
