Go Back   Mercedes Benz SLK World Forum > Mercedes Benz R170 SLK Class Cars > SLK R170 General Discussion
Old 03-17-2010   #1 (permalink)
Vehicle: 1999 model SLK 200 (136 HP)
Default Engine temperature gauge and instrument cluster lamps..!
In normal circumstances the engine temperature gauge is or was showing 80-90 degrees after a drive of 3-5 kilometers or 5 minutes of drive and stabilizing there... I remarked lately that the same temperature is reached almost immediately without even a warm engine... At the same time some lights of the instrument panel are off (gas gauge and left side of thes speed gauge: area of 40-60 km)... Is this can be a faulty connection problem affecting the lamps and the engine temperature gauge..? Any solution or what are the elements to be checked..?
View kole301's Photo Album kole301 is offline
Powered by vBulletin Version 3.8.5
SLKWorld 2006-2010
Design by Fife Web Solutions
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135
