Go Back   Mercedes Benz SLK World Forum > Mercedes Benz R170 SLK Class Cars > SLK R170 General Discussion
Old 02-06-2010   #1 (permalink)
Vehicle: 2001 Slk 320 v6 6speed manual Black
Question Tow away alarm, red light stays on
hi everyone,
my car is siting in the driveway and the alarm sounds, i use the keyfab and it stops. then i notice the tow away button red light is on solid. then about 10 min later the alarm sounds again? i cant turn off the solid red light on the tow away button and alarm keeps going off every 10min. so i pull the batterycable and call it a night any ideas what why
View garagegods's Photo Album garagegods is offline
Old 02-06-2010   #2 (permalink)
aka John
Vehicle: RHD Jasper Blue C200K Coupe, RHD Jasper Blue SLK55, LHD Black SLK350
Donation Level 7
Chats: 1142
Originally Posted by garagegods View Post
hi everyone,
If it was an R171, I'd say check the tow sensor in the rear electronics panel. I'm assuming the R170 has one as well, but don't know enough about it to tell you where it is..
Life is good - enjoy it with the top down!
View UK-C200's Photo Album UK-C200 is online now
Old 02-06-2010   #3 (permalink)
Thanks its an R170 SLK 320 2001 weather has been damp raining past few days i am hearing about something in the trunk near the spare tire gets damp?
Old 02-07-2010   #4 (permalink)
320 dreamer's Avatar
Vehicle: 2002 slk32 black w/18" oz bottecellis!
Chats: 5
you thinking pse but do this first. under the front engine cowl is the siren. it has a sep. battery. check it and replace if bad. this will set the alarm off when the battery goes bad
View 320 dreamer's Photo Album 320 dreamer is offline
The Following User Says Thank You to 320 dreamer For This Useful Post:
Old 02-07-2010   #5 (permalink)
will check it but what about the tow alarm light lit solid red and wont go out could the battery also cause this?
Old 02-07-2010   #6 (permalink)
Unhappy think i just opened a can of worms
so i opened the trunk and found the PSE pulled it from that foam cover and found a few drops of water not sure where it came from. left it out of the foam and just sitting in the trunk till i make sure its dry.
i tried to get to the alarm horn but cant get windshied wipers off??? screw cam off but they dont budge??? i assume you need to take them off to get to the horn to replace battery? gave up on that till get further info put it all together again except for the pse just sitting in trunk for now.
hook up car battery again after removing it to shut up the alarm and now the tow alarm red solid light is off but now i am getting a ESP/BAS error light in the dash and esp bypass wont do anything
also my stock radio was asking me for a code and i got car used and have no idea what code is? so i entered 1111 and now it just says wait
so like i said i just opened a can of worms think its time to take it in to mechanic not sure what else i can screw up
Old 02-07-2010   #7 (permalink)
Donation Level 8
IIRC on the R170 radio (from reading prior posts) may take some time before it is accepted (up to 1 hour, may be even longer).
Pewter(cubanite silber)/Beige, PIII package, Airscarf, Hands-Free Communication System, Lighting package
Bill T), SmartTop v1.0, Kleyman 3BFM (NoRegret Custom), Green Air Filters, Modified R170 ant., Clear sidemarkers & parking lamps w/error-free LEDs, chromed front & rear turn indicator lamps, bilateral rear fog lamps enabled, steel mesh at battery bay cover & cabin air intake.
Old 02-07-2010   #8 (permalink)
Chats: 5
relax bro!!
you will need a tool to properly remove the wipers. no big deal. any auto parts house
bas/esp lite . eazy peazy! turn the steering wheel lock to lock left then right then back to center. lite goes out.
radio code. bigger problem. if you dont have the code you have to go to the dealer with the vin to get it. the wait signal will go out after 20 mins. then enter the proper code and set it.
if you have the owners manual and case there should be a card in the face of the booklet holder (like a credit card) with the radio code. its a 5 digit code
Old 02-07-2010   #9 (permalink)
Thumbs up
relax bro!!
Thanks you have been such a huge help
i will try the steering trick tomarrow to remove the error light. what is the wiper removal tool called, is it called a wiper removal tool as for the radio i have almost everything except that code card i did find a dealers card with some numbers written on back, no i couldnt be that lucky anyway would have run into these things sooner than later
I guess its all about getting to know my car better,sorry for all the basic questions but when it comes to working on cars im not the sharpest tool in the shed
Old 02-08-2010   #10 (permalink)
Update:
just did the turning wheel left to right worked! Now ESP is back to normal. I lucked out with the radio number on back of dealers business card was the magic number radio is back. Still have the solid red light on the tow alarm? If I replace battery in horn near wipers will this solve alarm problem? For now till I get a chance to pull off wipers will try locking the car and not setting alarm to avoid going off every 10 min
thanks for all the help!
Old 02-08-2010   #11 (permalink)
Chats: 5
you may need to go for a drive to reset the tow alarm. just a thought
Old 02-09-2010   #12 (permalink)
Thanks! Yesterday car sits all day locked manualu no alarm set, at 7pm alarm goes off again? Disconnected battery to **** it up.
Went to Keagan auto parts to look for a wiper blade remover and they have no idea what one is,and I'm not sure what tool to remove wipers to replace battery in horn?
Thanks again
Old 02-09-2010   #13 (permalink)
Senior SLK World Member
Silver Supporter
notanumber's Avatar
Vehicle: 2000 SLK 230
You shouldn't need a tool (other than a spanner to undo the nuts )to remove the wipers ,they should come off by wiggling them about .If they're really tight maybe a small gear puller is what you need .
View notanumber's Photo Album notanumber is offline
Old 02-09-2010   #14 (permalink)
Update :
so I found the wiper pulled me and good ol wd40 what a pain in the a-- got one off that way the other I used a puller borrowed from my dad. I went to mechanic and tol him about the alarm and he pointed me in the same direction the horn as the culprit. So after pulling out the horn not sure if it's worth putting back?
You need a tiny tool to take the horn apart I don't have what kind of battery is it a weird obscure german one?
Again thanks
the tow alarm red light was out I drove the car all seemed good after pulling the horn it's back on solid?
Old 02-09-2010   #15 (permalink)
DJC013's Avatar
Vehicle: 2001 SLK 320 Auto Linarite Blue / Black Leather
Other Toys: 2004 Scenic 1.9 dCi, 1999 Honda CBR600F-X
Hello, can you post a picture of the battery ? regards Damian.
View DJC013's Photo Album DJC013 is offline
The Following User Says Thank You to DJC013 For This Useful Post:
Old 02-09-2010   #16 (permalink)
Wink
Once I get the bugger out will do best to post picture of battery
Old 02-09-2010   #17 (permalink)
DJC013's Avatar
Thumbs up
Ok, no worries, will see if i can help when you post the picture, regards Damian.
Old 02-12-2010   #18 (permalink)
Question what kind of battery does alarm horn use
Here are some pictures of the battery that came out of the alarm horn
any help would be appriciated
Old 02-12-2010   #19 (permalink)
Vehicle: 2001 Silver SLK230
Chats: 2
These look like 6 x 1.2 Volts, Nickel Metal Hydride (NiMH) rechargeable batteries, soldered together to give the 7.2V. Don't know if it's possible to get a similar assembled battery, or you would have to buy the batteries and solder them. You would probably have to cut the wrapper to be able to see what's inside!
View GusSLK's Photo Album GusSLK is online now
The Following User Says Thank You to GusSLK For This Useful Post:
Old 02-12-2010   #20 (permalink)
Founding Member #8
Vehicle: SLK350 MT
Donation Level 3
Chats: 1276
You can find the Varta cells that went to make up the battery HERE - have a 'root through' to get the correct size, then get the part no. and do a search for suppliers in the US.
MB SLK 350 Andradite Green (6 speed manual]
BMW K1200LT - 16 countries, 2 CONTINENTS & counting
LandRover Freelander (LR2)
1974 Triumph Bonneville 750
T140V
View Woolly's Photo Album Woolly is online now
coolant light plachkoff Ask DansSLK 7 01-07-2010 03:59 PM
interior light timer relay/switch hubbo1 Ask DansSLK 6 01-01-2010 01:50 PM
Mercedes Color Codes : SLK R171 : 2004-2009 UK-C200 SLK R171 General Discussion 7 02-08-2009 08:50 PM
How PC can you get ? Woolly Off Topic 1 02-28-2007 08:05 PM
Blinking alarm light? Sid Ask DansSLK 3 02-22-2007 10:49 AM
Powered by vBulletin Version 3.8.5
SLKWorld 2006-2010
Design by Fife Web Solutions
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135
