| Register | SLK Products | Clubs | Garage | Blogs | Members List | Social Groups | Search | Today's Posts | Mark Forums Read |
| SLK World Member Join Date: Dec 2009 Location: San Jose, Ca
Vehicle: Looking to Purchase 2001 SLK320 next week
Chats: 0 | I have some picture I took before taking it out. please give me some advice. ![]() ![]() ![]() ![]() ![]() |
| Sponsored Links | |
| Don - Founding Member #4 Join Date: Jun 2006 Location: Virginia USA
Country: Thanks: 227
Chats: 0 | Sorry, too complex for me. Someone will be along to help.
__________________ To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. ----------------1----------------- --------SLK 55 ///AMG--------- 19s AND ALL THE GOOD STUFF |
| SLK World Junior Member Join Date: Feb 2010 Location: San Francisco, CA
Vehicle: '01 SLK 320 Bahama Blue
Chats: 0 | So do you have the head off or not? I think you need to tell us what you've done. From the pictures, it looks like you haven't done anything yet. Have you toouched the chain or tensioners? Before you go any further, get all the concepts down on how engines are timed! I haven't done tha slk but on most cars, you will see two timing marks, one on the crank shaft vibration damper and one on the cam. Both need to line up. If the crank lines up and the can doesn't you are one rotation off. Rule number 1! Before anyone starts a timing job on any car, TDC the engine! Don't worry. I'm sure you're OK as long as you didn't touch the chain. Damon |
| Sponsored Links | |
| "Sergeant At Arms" Join Date: Jun 2006 Location: Valrico, Florida
Vehicle: 2009 SLK 55 AMG
Country: Thanks: 167
Chats: 11 | designo? Welcome from Valrico, Florida! And welcome to this great forum! You might want to post an introduction in the ‘new members introduce yourself here’ section, if you haven’t already. If you haven’t, please use the 'search this forum' feature for your questions as they have probably been asked before. In addition, If you haven’t, please post your questions in the appropriate discussion forum for a quicker response. And finally, if you find something useful on your visit here today, please consider donating to offset development and operating costs. Even $5 is welcome! Thanks!
__________________ Jeff, Retired US Army Master Sergeant 2009 SLK 55 AMG Black/Black Premium 1, Multimedia, Lighting packages Clearshield Protective Film OEM MB Plexiglass Windscreen Tinted Clear Side Markers w/LED Bulbs LED License Plate and LED Parking Light Bulbs (SLK Store) Smarttop version 3.22 Kleyman 3rd Brake Light Flashing/Strobing Module V1.5 (Noregrets Custom Works) |
| Elite SLK World Member Join Date: Jan 2009 Location: Belguim
Vehicle: 2008 Slk 200k sport pack
Country: Thanks: 44
Chats: 1 | I just wanted to say, that I think the engine is markt from the factory out. Maybe its a good idea to get a work manual for your R170. I can't find a good link at the moment, but some one here maybe have one. |
| Sponsored Links | |
| | #6 (permalink) | |
| Founding Member #8 Join Date: Jun 2006 Location: Co. Durham, UK
Vehicle: SLK350 MT
Country: Thanks: 545
Chats: 1152 | Quote:
You will need to try and find a proper timing diagram for your year of engine.
__________________ To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. MB SLK 350 Andradite Green (6 speed manual] BMW K1200LT - 16 countries, 2 CONTINENTS & counting LandRover Freelander (LR2) 1974 Triumph Bonneville 750 T140V To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. | |
| Elite SLK World Member Join Date: Jun 2009 Location: Eugene,OR
Vehicle: 2008 SLK 55 AMG 030
Country: Thanks: 67
Chats: 0 | If this are pictures from prior to removing the head, and you have already reinstalled it without having removed the cams; one possible problem is a bend valve. If the engine you’re working on is a crusher (piston can interfere with the valves) you need to remove the head to make sure that there was no contact between a piston and a valve. Further, every engine assy. will have timing marks for the gears, you just need to find the marks and know the relation to each other in the assembly.
__________________ To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. My Black Beauty |
| | #8 (permalink) |
| SLK World Member Join Date: Nov 2009 Location: Lebanon
Vehicle: 2001 Silver SLK230
Country: Thanks: 9
Chats: 0 | Did you actually remove or touch the chain? As far as I know, the head doesn't interfere with the timing (correct me if I'm wrong guys). From the pics and what you said, I understood that you didn't touch the chain, and if you're changing the head gasket, you actually shouldn't. (Again, that's my understanding). |
| | #9 (permalink) | |
Vehicle: SLK350 MT
| The Following User Says Thank You to Woolly For This Useful Post: |
| | #10 (permalink) |
Chats: 0 | Don't freak him out. All is not lost as long as he didn't try to turn over the engine mechnically or with the starter. Be gentle. The worst case is that he will need new gaskets if he has everything back together and hasn't turned the motor. My suggestion is to get a manual and read it. Ask questions for concepts that you do not understand. Disassemble everything and start over. Detail is important. Timing and tightening head bolts are very specific! You cannot just tighten the head bolts. It must usually be done in stages and in a specific pattern. If you do start over, use new gaskets and do not use the ones you just put on! Do not get this wrong, your engine could be damaged severely. This is really not rocket science. Don't worry. By the way, if you are just only using the write-up provided in your thread from Benzworld, you are missing alot! I'm not knocking the effort for the write-up, but you should know that he mentions that his write up is pictorial support for Alldata documentation. Please be more detailed on what step of the process you are at and more importantly, did you turn over the engine? Damon |
| The Following User Says Thank You to designo? For This Useful Post: |
| Sponsored Links | |
| | #11 (permalink) | |
Country: Thanks: 67
Chats: 0 | Quote:
__________________ To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. My Black Beauty | |
| | #13 (permalink) |
Chats: 0 | Thanks for all the reply guys. I've actually took the head out all ready. The head is being repair because there is a small crack that lets coolant into the oil. anyways everything was taken apart. now I can see the piston. I got some help from members at the slkworld. here are the diagram for the marking. Dose it make sense to you guys? ![]() |
| | #14 (permalink) |
Chats: 0 | Seems to make sense to me. There appears to be a cam lock tool. It looks like they are implying that 20 deg. is TDC. |
| | #15 (permalink) |
Country: Thanks: 67
Chats: 0 | Make sure the timing is performed with the correct cylinder at 20° off TDC; most likely its No.1
| Sponsored Links | |
| | #16 (permalink) |
Chats: 0 | here is how I understand it. Cylinder number 1 is 20* off TDC means the piston is almost at it highest point in the cylinder. Cylinder # 1 is the most forward one. Am I close, or is that way off? I need to turn the biggest pulley counter clockwise(???) and align it at 20* TDC(the mark) |
| | #17 (permalink) |
Vehicle: SLK350 MT
Chats: 1152 | Unfortunately, you cant guess - you need to know exactly which timing marks are where, and how to line them up properly to set your valve timing. At best, if you get it wrong, it won't start, at worst if you get it wrong (and in the real world) you'll end up with broken valves and holed pistons. - you must find a valve timing drawing that you can relate to and understand.
| | #18 (permalink) |
Chats: 0 | Yes, you will have to time the crankshaft and the cams before assembling. I cannot verify the validity of the image that you posted but you're on the right track. Everything must be timed before you reassemble. If 20 deg. is TDC then that is where the crank needs to be. Only turn the crank in the direction of rotation and make sure it lines up perfectly and only do this with the head off because you've already messed up the timing. There usually is a tool to lock the crank on most cars before you start but I assume you you're past that. When reassembling make sure NOTHING MOVES! Note that the timing chain usually needs to be threaded in one direction. On some cars one tooth off and it could be bad news. Take your time. Concept: The crank rotates twice for every one revolution of the cam. Since you have the head off, you can time the cams off the engine without damage but make sure both cams are timed. Then use the cam lock tool to hold it for installation. From your images, I cannot dicern where the cam timing marks are but I believe that was their intent. I will have to look at WIS to get you better information. Do not put the head on without getting proper headbolt torquing procedures. Make sure everything is clean on the mating surfaces. Are you using new headbolts? People chime in if I've missed anything. Please note that I have never worked on the head of an SLK. Everything I've commented on above is based on basic engine timing principles. Good Luck! Damon |
| | #19 (permalink) |
Country: Thanks: 44
Chats: 1 | this is not wat you want to hear but if one of the pistons is at top death point cant he figure out the time from that piston out on howe the valves need to be standing in thair time line, then again this is far from accurate. Never mind my post, sorry |
| | #20 (permalink) |
| SLK World Member Join Date: Mar 2009 Location: BluePoint NY
Vehicle: 2005 SLK 350
Country: Thanks: 3
Chats: 0 | In reference to desino? post. Once he gets the heads installed no covers ect. Can he rotate engine with no plugs slowly through the fire order. Are there is a problem with timing that is variable? I've changed timing belts, the best was a mitsubishi eclipse. It had four gears and the marks would not line up no matter how many times I rotated the motor. So I made my own marks at tdc # 1 cylinder. From that point on I always make my own marks with the engines marks. |
| Sponsored Links | |
| Bookmarks |
| Would you be worried about oil seepage? | Brian_74 | Ask DansSLK | 14 | 09-20-2009 04:14 PM |
| Mercedes have screwed up my order - what to do? | mcat | SLK R171 General Discussion | 46 | 08-04-2008 06:43 AM |
