Wiper water leak? - Mercedes Benz SLK Forum
#1 Old 12-26-2009
Vehicle: SLK-230
Other Toys: Z4 M Coupe, Alfa Spider, Lancia Scorpion
Send a message via AIM to ecohen2 Send a message via Skype™ to ecohen2
Wiper water leak?
Hey everyone,
My fiance has 1998 SLK-230 that appears to have two possibly related issues. The first is when you fill the washer fluid, it starts coming out from just behind the passenger side wheel well. The tank seems to be located somewhere inside the body of the car. Is this just an overflow or is the bottle cracked.
The second issue is that the inside windshield seems to fog up unusually fast for some reason. I made sure that the compressor was on and that the vents were open, but after the engine gets warm, it begins to fog.
Is it possible the wiper fluid is dripping into where the heater core is and steaming up?
I don't have a shop manual so I don't know where stuff is yet on this car, but any thoughts would be helpful.
Ed
ecohen2 is offline
#2 Old 12-26-2009
Quoted: 3557 Post(s)
And finally, if you find something useful on your visit here today, please consider donating for hosting and licensing fees to the site. Even $5 is welcome! Thanks!
Wavetrac LSD thread here:
#3 Old 12-26-2009
use the 2000 manual here until someone gives u a link:
http://www.mbusa.com/mercedes/#/servPrtsOwnersManuals/
#4 Old 12-26-2009
Vehicle: SLK-230
Info filled out, donation made...
The manual doesn't go into any detail about whether or not there is an overflow or how to get access to the tank itself, but I do appreciate the link...
Thanks,
Ed
ecohen2 is offline
#5 Old 12-26-2009
the r170 experts will chime in shortly if they r not drunk on eggnog. thanks for the donation!
#6 Old 12-26-2009
see if this helps at all:
Window washer reservoir
#7 Old 12-26-2009
Vehicle: SLK32
Not sure where the leak could be but here's a PL breakout for the wiper/washer system which includes the headlight nozzles. It may help you track it down. By the way, your chassis is a 170.447.
Tslick is offline
#8 Old 12-27-2009
Las VegasCop's Avatar
Vehicle: 2001 SLK 230 Auto
The steam is probably it...steam. That can only come from one place and that's your coolant. It is more likely coming from the heater, specifically the heater core, something corroded or broke, it will be a b@$* to get into and replace. I had that happen to one of my "american" made cars but not on the MB or BMW. Do you know if you are using Mercedes coolant or is it the regular "Preston" that someone replaced it with?
Ski
Las VegasCop is offline
#9 Old 12-27-2009
frogfoot's Avatar
Vehicle: 2005 slk 350 6spd manual designo
Other Toys: Fiesta 1.6tdci work Hack /very large snap-on tool chest very handy
Quoted: 95 Post(s)
if the matrix is leaking in the dash can you smell antifreeze when you get in.?
If yea as a short term fix you could disconect the water pipes going to the matrix in the engine bay.Then join them together with a pipe conector and clips.top up water and run to temp and check for leaks.
You will have no heating but it will stop water getting into the car untill you get the matrix replaced.
No idea what a matrix is like to do on a slk but most i have done are big jobs
Anyone else know?.
p.s how cold is it at the mo the washer bottle could of froze at the bottom and the expandig ice may of broken the seal around the pump.
when it thaws it may fix its self
cheers pete
Its never Dull in Hull
not when you have a 350 MT
frogfoot is offline
#10 Old 12-27-2009
Vehicle: SLK-230
I don't smell any antifreeze with or without the steam. The steam does occur after the engine is warmed up, which is why I thought it might relate to water or something getting into the vent.
The car has always been garage kept, so the drain hoses look really clean. I am going to blow some compressed air through them, but I don't think that is the issue.
She has always had dealers fill everything, so the coolant and wiper fluid is from the dealer. I don't trust the one dealer she has been taking the car to, which is why I decided to do a once over myself.
Thanks for the diagram of the wiper fluid piece, now I know what part to order.
Ed
ecohen2 is offline
#11 Old 12-28-2009
320 dreamer's Avatar
Chats: 5
before you order the part try this. use the fluid. the top of the container is designed to have a gap so that under expansion the fluid will come out the top and not crack the bottle. most likely the dealer overfilled it
320 dreamer is offline
#12 Old 01-17-2010
This is my first posts at this site. I've been a W140 owner for 7 years and my wife has had an SLK 230 for about 4 years now.
Anyway, your leaking problem is exactly what I had last month. I took the right front wheel off, and opened up the panel in the wheel well and noticed on the washer fluid tank that there is a plug in the middle (half way up). This plug appears to be for some other feature not used on this car. I guess it develops a leak on occasion. I temporairly stopped the leak by wrapping the rubber stopper with plastic kitchen wrap. It seemed to have worked and now I'm looking for a replacement.
Slats58 is offline
#13 Old 04-28-2010
Vehicle: SLK320
Just replaced a washer bottle on a 2000 320. The plastic had become brittle and was cracking resulting in leaks through the walls of the bottle. In Australia so not cracked from freezing. About $100 US for a new bottle over here.
Crash is offline
#14 Old 04-29-2010
Vehicle: 2001 MBZ SLK320 Red
Other Toys: 2003 Beaver Motorcoach, 2011 MBZ E550
Just replaced mine at an independent shop. As I was having a major service done, the owner did not charge me labor, but the washer container was less than $90.00. He had to remove the right front wheel and go through the fender well.
sgt770 is offline
#15 Old 05-01-2010
Vehicle: 2002 SLK 320
Tslick......I can not access the PL breakout for washer/wiper. Any other way I can find this? Thanks.
Leezee is offline
Human Verification
Water leak in to the boot ivanslk SLK R171 General Discussion 26 11-22-2010 05:07 PM
weird water damage/problems... 99999 General Discussion 34 06-17-2008 09:46 AM
Carwash Water Leak Tummy SLK R171 General Discussion 10 06-10-2008 09:05 AM
Passenger window water leak...need help slk230r170 SLK R170 General Discussion 6 03-05-2007 10:15 PM
Need Help - Trunk full of water mcat SLK R171 General Discussion 31 07-20-2006 09:11 PM
