DIY - R170 - Replace rearview mirror - Mercedes Benz SLK Forum
 14Likes
  • 1 Post By Gabus
  • 1 Post By beardoggie
  • 2 Post By djcdo
  • 4 Post By Carl Beck
  • 1 Post By Carl Beck
  • 3 Post By Alex 3
  • 1 Post By TheRman
  • 1 Post By AndyW
#1 Old 06-18-2008
Vehicle: 2002 SLK230 - Blk, 6 spd
My rearview mirror just developed a bubble type discoloration suddenly.
As this may have happened several days after spraying it lightly with a cleaner. Is it possible to dry it out? If not, I plan to replace it.
I have a 2002 SLK230 and will be looking for a excellent condition used mirror. However, I heard there may be a newer model there might be better to buy. Mine seems to have been made by Donnelly. Any comments about what model or where to purchase it would be appreciated.
Also I would very much like explicit directions as to how to remove it correctly.
Looking forward to your reply.
beardoggie is offline
#2 Old 06-19-2008
Vehicle: 96 SLK 230K
Other Toys: Samurai
Chats: 39
How to remove:
If you put your finger on the "foot" of the mirror - close to the windshield - you'll feel a little hole there.
If you push a 5mm- 1/5 inch -rod in that hole, and twist the whole mirror (with "foot") 90 degrees, you can remove the mirror from the gluepad
SL32guy likes this.
Gabus is offline
The Following User Says Thank You to Gabus For This Useful Post:
#3 Old 06-22-2008
Thank you Gabus for your info.
Now I'm simply trying to remove the section attached to the sunvisors so that I can reach the mirror.
So far:
I've put top down and removed 4 Phillips type screws that were holding the sunvisors on. The 5 foot top section does not want to slide off the windshield easily. It seems to be stuck near the center portion..
Do I need to remove the microphone cover? Pry it off?
Do I need to remove the overhead lens cover? Pry it off?
#4 Old 06-22-2008
rearview mirror
I was able to figure this out so no one needs to write back. Microphone cap and lens cap come off easily with a small pry screwdriver.
For those with a 2002 SLK, it is necessary to remove two screws underneath the overhead light lens, in order to pull off the 5 foot section that goes across the windshield.
This enables one to reach the mirror to twist it off like Gabus said. It takes quite a bit of force to remove it.
Thanks a bunch for this Mercedes site, as it has been very helpful.
Also helpful was a video showing the actual rearview mirror removal:
www.buellwinkle.com/r170/default.htm
Kuklaw likes this.
The Following 2 Users Say Thank You to beardoggie For This Useful Post:
#5 Old 10-30-2010
thank you for the info
slk32_amg is offline
#6 Old 11-03-2010
Vehicle: 2003 Yellow SLK230
Other Toys: 2014 Tesla Model S, 2013 Toyota Tacoma
Here's a thread on some of our recent experiences with the "lava lamp" rear-view mirror:
Inside Rear View Mirror not working
Hardest part for me was getting the new mirror on to the stud & rotating it into position. The strap wrench did the trick for me.
atebit is offline
#7 Old 11-04-2010
Vehicle: 2001 Silver SLK230
Chats: 2
Here's a link to a thread I just posted about my experience with the defective rear view mirror.
GusSLK is offline
#8 Old 09-16-2011
Vehicle: 1999 SLK230 - named Roxy
Send a message via Yahoo to jeffkallas
Rearview Mirror
Thanks for the great feedback on the mirror. I was able to remove mine by following your tips but also used a vise wrench on the mirror since I ws replacing the old one with a new mirror. It came off really easy that way!
I ended up buying a new one for @ $210 from the dealer versus going through a refurb process.
Thanks again for the forum responses!!
jeffkallas is offline
#9 Old 10-10-2011
BSK
SLKWorld User # 10,000
Vehicle: 00 SLK 230
Chats: 3
There is a company we use on the audi forums that sells refurbished ones for 90$
http://www.sybesmas.com/home.html
BSK is offline
#10 Old 08-18-2013
djcdo's Avatar
Vehicle: 2002 SLK 320 In great shape only 40K miles
Other Toys: Silverton 1997 402
KISS or keep it simple &^%$#*
If some of you are like me you tend to complicate things. Just thought I would add here that putting the rod in the hole to remove the mirror is only to get leverage to twist it off, and there is no magic button inside the mirror the rod is pushing on....just thought I would add that
gringott and theo3000 like this.
djcdo is offline
#11 Old 08-31-2013
Vehicle: 1999 SLK 230 "Sport"
Quoted: 24 Post(s)
DIY - How To With Pictures - 1999 SLK 230 Mirror Replacement
Thanks to everyone that contributed information and directions related to replacing the inside rear view mirror on our R170 SLK's. Certainly the written directions are clear enough for anyone with a little experience working on their own cars - to follow.
But then - there are lot people that have never attempted to take any part of a car's interior apart - and brief written instructions can leave them feeling - more than a little uncertain about their desire to do anything themselves.
For that reason - as I was in the process of changing-out my defective interior rear view mirror, for a new replacement - I took some more pictures of the process. Just so others can see how really easy it is to do it yourself.
I have put them up on my server at the following URL. When I learn how to get all this put up on the SLKWorld sight/server - I'll archive it there as well.
http://becksystems.com/SLKRearViewMi...ViewMirror.htm
If anyone sees any corrections that are needed - or has suggestions as to how to make it more clear or understandable - just let me know.
FWIW,
Carl B.
Carl Beck is offline
The Following 7 Users Say Thank You to Carl Beck For This Useful Post:
#12 Old 08-31-2013
curro101's Avatar
Vehicle: Slk 200K 2004 r171
Other Toys: Astra 1.9 Twintop
Quoted: 470 Post(s)
Thanks for taking the time and effort for writing this up , I'm sure it will be of great use to others !!
curro101 is offline
#13 Old 08-31-2013
Minion
slk320chick's Avatar
Quoted: 143 Post(s)
FYI this thread is 5 years old
Glad it helped.
slk320chick is offline
#14 Old 09-01-2013
Quoted: 24 Post(s)
Thanks for the FYI - but to tell you the truth - I was fully aware of that, as it is clearly marked on the First Post.
While this thread was started 5 years ago - I think the dates of "Most Recent Posts" are more important when you are looking for more current data/information. The latest Posts to this Discussion Thread were only a week ago - and this Thread was proposed as a STICKY. So I felt that the original start date was pretty much irrelevant.
Glad it helped.
It did - as well as reading hundreds of other Posts in the following Discussion Threads. None of which had clear pictures of exactly what was being done.
- - - - Previous Threads Started Over The Years - - - - -
R170 rear view mirror
GusSLK
11-04-2010 to 12-31-2011
Leaky Rearview Mirror Replacement
DesignoSLK -
10-28-2006 to 04-15-2010
This was a reference hyper-link to benzworld.org. A discussion some 16 Pages long.
DIY - R170 rear view mirror replacement
Atebit
09-06-2010 to 04-15-2010
DIY: R170 rear view rearview mirror replacement
This was a better title for the subject - so the search function would take anyone to the info. they were seeking. It redirected me to "DIY - Replace rearview replace"
beardoggie
06-18-2008 to 10-10-2011 {then last week and today}
Sticky: DIY - Replace rearview replace
http://www.slkworld.com/slk-r170-cla...html#post74139
FWIW,
Carl B.
The Following 2 Users Say Thank You to Carl Beck For This Useful Post:
#15 Old 10-11-2013
Vehicle: CLA45 AMG had 2014 R172
Other Toys: Traded them all!!
Quoted: 52 Post(s)
FWIW,
Carl B.
I read this excellent procedure and followed it quite well but found a couple of things slightly different on the 2001 SLK 320 when all was completed.
It is necessary to remove the four screws holding the sun visors but you do not have to remove the windshield header molding on the 2001 model. The interior light is different and offers good access.
If you pull the lens off the map lights it comes away quite easily and there are two screws under the lens that must come out.
Removing all 6 screws allows the trim molding to flex in the middle of the windshield at the bottom.
Pull on the driver's side end of the lamp housing and it will come out easily. Slide it slightly to the left (driver's door) and the connector will clear leaving a large hole.
In the hole the wire for the mirror is easily located simple by pulling the bottom of the trim away from the windshield and wiggling the mirror wire.
There does not appear to be any cable clamp in this model where Carl's picture shows it.
Pull the connector through the hole and carefully disconnect it by sliding a small flat screwdriver down to the hole where the pin is and pull the pin past the hole as Carl describes.
Pull the mirror wire back towards the windshield while holding the molding away from the glass. 1/4-1/2" is easy to achieve and is plenty of clearance.
Remove the mirror as Carl describes it.
Reverse the process to re-install the mirror. You may have to fish the wire from the mirror into the lamp hole but if you have smaller hands you can reach in and grab it. Worked good for me.
As a footnote, Sybesmas does not have a replacement swap out mirror in stock at this time so I must send mine in for rebuild. At $97 including return shipping it is far cheaper than most used ones on the market and is guaranteed to work. The only risk is they could damage the case.
Alex 3 is offline
#16 Old 02-20-2014
Quoted: 52 Post(s)
I got the replacement from Sybesmas in about 2 weeks from the day I sent it and it came back great.
When I put the visors and header back after removing the mirror for shipment, I left the wire exposed so all I had to do was put the mirror back in place, connect the wire and tuck it back up behind the header. No screws, visors or lights to remove It took all of 5 minutes to do. Glad to have it back for sure. Driving without it is freaky.
Alex 3 is offline
#17 Old 04-11-2014
Vehicle: 2001 320 SLK
All this info was perfect
I not only had a bad mirror on my 2001 320 but the wind shield had to be replaced....two chips right in front of the drives view. I followed the directions mentioned here...it was a breeze to un install the mirror. Sent it to Frisco Texas and for $99 they fixed it. The installers who replaced the wind shield replaced the mirror button on the glass and when I went to re-install it....just like factory.
Now we have a sparkling windshield and a auto dimming mirror without liquid goo half way up it.
Had it not been for all the great info posted here I would have still been scratching my head wondering how to fix this...
Thanks a lot!
RMan in San Antonio
curro101 likes this.
TheRman is offline
#18 Old 12-31-2014
AndyW's Avatar
Other Toys: 2008 335i
Thx all for this thread! Very helpful.
Carl Beck likes this.
AndyW is offline
#19 Old 02-21-2017
Other Toys: can am spyder motorcycle , pontoon boat, slk 320
Thank you so much. Great pictures
rgands is offline
Human Verification
DIY - Engine mounts replacement for post facelift R170 Mantist SLK R170 class DIY 31 05-02-2016 11:23 PM
DIY - Instrument cluster removal for R170 without telescoping steering Mantist SLK R170 class DIY 14 09-09-2011 02:45 AM
DIY: R170 rear view rearview mirror replacement atebit SLK R170 class DIY 1 09-06-2010 03:13 PM
