Wheel Clearance Event Promo
Old 06-07-2008   #1 (permalink)
SLK World Junior Member
Question Recommendation for 200k engine tuning
hi, what is the best engine tuning for a 200 k slk? i'm interested in a ecu remaping, if you can change the pulley in order to obtain more power... what other modifications can i do to this engine to get more hp? thx
View alexx's Photo Album alexx is offline   http://www.slkworld.com/Boss Key
Old 06-26-2008   #2 (permalink)
B55
B55's Avatar
Vehicle: Formerly "Beleriand"
Other Toys: Porsche Turbo (997TT)
Donation Level 3
There is really no economic way to upgrade a 200. Non-AMG Mercedes cars have a very high compression engine so there is not a whole lot that can be done with the stock block. An ECU might allow a better fuel to air mixture but without a new exhaust you will lose most of the advantage. If money is no object for you and you don't want to move on to an AMG, then ECU and exhaust are a good place to start. But I would not want to drop $10K or more on an ECU tune and an exhaust just to gain 10-15 hp on a 2.0 liter engine. You will never recoup it on resale and no tuner will warrant the work. Don't touch the internals. You can always try race gas!
Keep in mind that an under-drive pulley won't add power. It will merely reduce the parasitic effect that the pulley has when transferring power from the engine to the wheel thereby allowing you to maximize brake horsepower from the flywheel. A smaller and lighter pulley wheel combined with a bit shorter serpentine belt may help the engine spool up a bit faster as well. I have an under-drive pulley on my Porsche Turbo and I think it has made the car a bit more peppy.
View B55's Photo Album B55 is offline   Boss Key
The Following User Says Thank You to B55 For This Useful Post:
Old 06-26-2008   #3 (permalink)
alroumi's Avatar
I have a friedn who did the K4 Brabus on his C200K it increased power from 163-198hp for about 5,000 dollars with installation and exhaust system.
06 Porsche Cayenne S
07 Jaguar XKR Coupe'
Old 06-28-2008   #4 (permalink)
i've searched a few offers myself and as it turns out as B55 said, there is no economic way to tune up this engine... all the things you can do to this engine are somehow expensive if you consider the money spent for the extra hp you get. thx
View alexx's Photo Album alexx is offline   Boss Key
Tags
slk 200k engine tuning, slk 200k increase power
Lifetime of 200K engine? SLK_Cyprus SLK R171 General Discussion 5 01-23-2008 07:44 AM
Recommendation.... RacerCub68 SLK R170 General Discussion 9 09-21-2007 05:58 PM
Need tuning advise Banned Ask DansSLK 20 06-07-2007 09:49 AM
Tiptronic 230K or Manual 200K? jonathan SLK R170 General Discussion 8 03-25-2007 08:02 AM
Alarm Recommendation joss SLK R170 General Discussion 4 10-28-2006 01:18 PM
