Windrestrictor
Old 09-07-2006   #1 (permalink)
Vehicle: '05 SLK350
Arrow Piecha Exhaust Sound Clip
I know everyone has been curious about the Piecha Quad exhaust system for the SLK350 and 200.
I have been in contact with Marcus Piecha over the last week, and was able to get a video clip of the exhaust in action. Though in my opinion this is not the best clip, i have communicated to him some potential improvements on how to record the clip better.
Yes you heard it here first!
The Piecha SLK350 Quad Exhaust:
http://www.savefile.com/files/41823
Once i get more clips i will post them as they come in.
The SLK200 clip should be ready soon as well. So stay tuned and please post your feedback on this initial clip.
Old 09-07-2006   #2 (permalink)
Vehicle: Obsidian black SLK
Thank you,thta was very thoughtful .... Nowadays customers have to convince manufacturers on how to advertise their goods......
View ierax's Photo Album ierax is online now
Old 09-07-2006   #3 (permalink)
easty's Avatar
Vehicle: ///AMG
Donation Award
That does sound very nice. Sounds a little race garbled. You may want to get the ECU remapped to get the engine running on par with it.
Old 09-07-2006   #4 (permalink)
Vehicle: '05 SLK350
I like it as well.
Easty, how would they remap the 350 ECU? (Sorry for the lack of knowledge here) Or better what would they remap it to? Is the garble bad?
Got an email for Piecha. He said that they will make the new videos based on my suggestions.
1. Idle
2. Rev (random)
3. Rev Steady Curve (1000-4000+RPM)
Also perhaps a driveby, and fast start 0-60.
Will keep u posted
Old 09-07-2006   #5 (permalink)
easty's Avatar
Vehicle: ///AMG
Donation Award
I'm not 100% on this stuff just the info from when I used to set up bikes. The map contains the data for the Air/fuel ratio at different rev ranges. The car is set-up initially for the best performance obviously within certain regulations for Fuel efficiency and emissions controls. If you change anything on the vehicle that effects in how the engine works it really worth considering getting the ECU re-mapped for best performance. I'm sure Dan will be able to explain more and if it's possible and how easy it is.
On the bike I simply had a black box that plugged inline between the ECU and the injectors. I could plug this into a PC and upload various maps. With sports bikes most performance exhaust companies create specific maps and put them on the net for their customers. But on most modern fuel injected bikes it's really worth remapping even if you keep the bike stock as you can achive a little hp plus the power curve can be a lot smother which is very import on a bike.
Old 09-08-2006   #6 (permalink)
N4PWJ's Avatar
Vehicle: 2006,slk280,carlsson
Other Toys: Caterham
i have also been in touch with piecha about these exhausts. They claimed 15ps (i assume that is even to 15bhp) performance gains. Should I consider a remap once exhaust is fitted? will this affect fuel consumption/mpg?
I personally think the exhausts look fantastic and am sure they will sound excellent to. However I could spend more (nearly double) and get a full carlsson exhaust system which has better performance gains but only slightly.
oh and piecha sounds great in video!!!!
Old 09-08-2006   #7 (permalink)
N4PWJ 15PS - 14BHP I think that figure might be a little optimistic myself unless the whole exhaust system is replaced but i am sure some gains are to be made from the system
I have answered your Q about the mpg in the post about the ECU since i thought it makes more sense to do it as a single post
Old 09-08-2006   #8 (permalink)
noregret,
As easty says a repair is basically changing the A/F ratio for certain RPM ranges now in a car is becomes a little complex because the ECU will have various different maps and those maps will have more than one parameter for each entry in the map the reason for this is for fuel efficiency most of the time but performance maps are also included for when you are ragging the car.
The two maps you will have experienced for sure are the after start and smooth running entires the after start map is designed to get the cats up to temp fast so it will hold the RPM's at a higher rate than the smooth running map it also bases its information less on what the O2 sensors are reporting its primary sensors are the MAF for the volume of incoming air, the oil temp sensor for releasing the map to normal operation and to protect the engine and transmission from over-revving when they are cold and the intake air temp sensor used for working out a starting temperature during this stage the engine is running open-loop used values stored in the ECU and not what the O2 sensors are reporting back.
The smooth running map will be running in a closed-loop mode so it will be using the values reported by the O2 sensors to meter the A/F mixture it will also be using all of the engine and transmission sensors to help meter the mixture this basically means that there are almost limitless possibilities for each RPM segment however the system will have upper and lower limit values that it must adhere to based on what the major sensors are reporting back that way it cannot flood the cylinders with fuel or just fill them with air there will always be a good enough mix to allow for combustion.
The black box easty was talking about is placed on cars between the sensors and the ECU so the computer cannot detect its presence but the most common way of re-mapping an ECU is to reprogram it using a software program a good tuner will have an SDS machine that can download the map from the computer he will then offload it from the DAS into a program designed to do the actual remapping once that is done he will reload it into the DAS and that will then upload it to the ECU this is the exact same way we use when we are updating the software versions when a car come in for a service except the tuner will tweak the values a little.
The limit in your car and every other NA car around is going to be the amount of air it has to breathe on now your new exhaust should be more free flowing than the OEM this should allow for the exhaust gases to escape faster and that means you can allow for a more fuel rich mixture some tuners will simply add fuel to the whole range but this is a pointless exercise since it does not matter how much fuel you add if you ain't got the correct amount of air to mix with it this can actually reduce performance this is why it pays to go to a good one they will allow for more ECU adaption and let the onboard brains do the work, the ECU can adapt to your driving style and to the operating condition of the engine very effectively in these cars so an actual remap where the fuel is altered is not really needed because the computer will sense the changes that will occur after the exhaust is fitted and adapt accordingly but the chances are it will reach a limit value and that is when a tuner comes in because they can re-map the ECU will wider limits allowing it to more fully compensate for the efficiency increase the effect that happens when the limits are reached can be found in my thread about the new fuel my car is running.
Mapping a car this way will also see less of an impact on the mpg since when you are at idle the computer will lean it off and at full throttle she will run rich so the chances are you wont really notice any difference in mpg that is worth mentioning also if you run your car on one type of fuel you can get the ECU told that that is the base value this will improve performance again as the car does not have to be able to compensate for lower quality fuels and this can actually improve your fuel economy.
I hope this explains things and any other questions just ask
Dan
Old 09-08-2006   #9 (permalink)
Vehicle: '05 SLK350
Thank you both for all the info I hope little by little i'll be able to gather enough knowledge on the subjects. Or at least up to par of my electrical counterpart.
If i do opt for the Piecha exhaust, i am hoping to put in new "sport" air filters such as discussed by other members. Strange though that the 350 has so few options for intake filters. You AMG guys get all goods!!- Just joking
Old 09-08-2006   #10 (permalink)
No worries about the info mate.
Just a quick question kinda un related so it will make it quick has anybody actually measured the internal diameters of the 350 airbox if memory serves me correct it should be the same as the 55's
Old 09-08-2006   #11 (permalink)
Vehicle: '05 SLK350
I have not actually sized it up, or heard of anyone that has. Weather permitting i may climb under and get a rough estimate this weekend.
The straight pipe idea is still floating around in my head... I'm not yet sold on the Piecha or other exhaust. With a straight pipe, (granted sound levels are acceptable) you can really make it look like anything you want at the tips. I'm imagining Quad Black Chrome tips with Silver Chrome trim line just at the edge
Old 09-08-2006   #12 (permalink)
It just pulls off so i would imagine it will take you all of 30 seconds to remove it.
That exhaust idea actually sounds kinda cool i gotta be honest with you mate.
Old 09-08-2006   #13 (permalink)
Vehicle: '05 SLK350
Hey Dan, What do you mean by "It just pulls off"
Old 09-08-2006   #14 (permalink)
Here's a link to a thread by jbanks15 on removing the air filter:
http://www.slkworld.com/slk-r171-gen...emoving+filter
Same procedure for the 280. Hmmm.. I'll have to get the dimensions for the 280 air filter and see if the ones for the 350 would fit. I imagine so. I'll check this weekend.
Old 09-08-2006   #15 (permalink)
The link etyu posted to jbanks15's instructions is correct
Just grab hold of the front edge of the airbox and pull up the box should sort of split in the middle once that it removed disconnect the hose then simply unfasten the latch and pull the box up from each corner it is held on by rubber feet hence my comment it just pulls off you literally grab the thing and pull.
Best do it on a cold engine so as not to toast your hands and also it allows the box to slide off the rubber easier
Old 09-15-2006   #16 (permalink)
Senior SLK World Member
Vehicle: SLK350
Hi noregret4life, I have been thinking of removing the resonator on my slk350 to make some louder sound on my car too! but I am still held back because I am scare that it will be too loud, warranty issues with MB or too much performance lost cause there will be less back pressure?
So yea... just wondering have anyone really done that yet and have sound clips of it?
Also refering back to what you posted before,
http://www.flowmastermufflers.com/pr...ex&cPath=1_163
I wonder what exactly this resonator does? Is it better than if I get a stainless steel pipe and weld it on after removing the resonator?
Can someone with experience or technical knwoledge answer my questions?
Thanks alot!
View Wallance's Photo Album Wallance is offline
Old 09-15-2006   #17 (permalink)
The SLK350 sound was good, but what about us with the small 1.8 litre 200?
Can it be possible to get some "race"-sound? Perhaps in combination with a sport air filter.
Hoping for some sound clips soon.
Bengt
View bejak's Photo Album bejak is offline
Exhaust Clip dsb SLK Videos 18 04-10-2008 05:29 AM
My Piecha exhaust N4PWJ General Modifications R171 62 02-04-2008 01:02 AM
