Visit Autogeek.net
Old 05-18-2008   #1 (permalink)
Vehicle: SLK280
Other Toys: BMW Motorcycle, 32'power boat
Default K&N or GREEN filter ruining the MAF?
I was going to get a K&N filter but I heard that the MAF gets dirty from the oil and also allows dirt particles through so a replacement MAF is needed, so I decided to get the GREEN filter but it also uses oil for filtration! So what is the real story does the
microscopic amount of oil, and or dirt that gets sucked in, does it actually destroy the MAF?
View gknight8's Photo Album gknight8 is offline   http://www.slkworld.com/Boss Key
Old 05-18-2008   #2 (permalink)
Super Moderator
This has been covered quite a few times, as far as i am aware nobody on this site has suffered damage to the MAF or any other component from using Green filters.
I can't speak for any of the other brand's because I've never tested them but i do know that K&N uses a lot of oil so that is probably what causes the issue.
View DansSlk's Photo Album DansSlk is online now   Boss Key
Old 05-18-2008   #3 (permalink)
Vehicle: SLK280
That's what I thought since I have had K&N in my other car for 5 years now with no issues, I was just wondering if the MAF on the MB was just more fragile. Thanks for the heads up
View gknight8's Photo Album gknight8 is offline   Boss Key
Old 05-18-2008   #4 (permalink)
Super Moderator
The MAF's are very sensitive, the way i see it Green's are used in WRC and while they inspect and care for the engines way more than any standard road car is used to they get one hell of a beating when they are running and I'm sure no self respecting engineer would spec a filter that he/she thought would be detrimental to the car.
When you consider what they get subjected to that does give me confidence in them.
I think perhaps some super strong sticky tape test's behind the filters in the airbox and a borescope inspection of the intake manifold would be interesting to have along with some out of engine tests of the filter's capabilities, then we might have something sticky worth.
Old 05-19-2008   #5 (permalink)
Unless you have quad air filter set-up like this pix :
Link: http://www.slkworld.com/amgs/5750-quad-air-filters.html
Seriously speaking (I can only say from personal experience): The Green Air Filters look dry and less "oily" coming from the factory, ergo, less chance for fouling the MAF sensors. I've had them for more than one year in the prior 280 and around 9 months on the 55. So far so good (knock on wood), not to mention fuel cost savings of 2 mpg
Old 05-19-2008   #6 (permalink)
alroumi's Avatar
I have the Green filters installed on my car for two years now, I've never changed it and knock on wood nothing wrong has happened so far.
06 Porsche Cayenne S
07 Jaguar XKR Coupe'
Old 05-19-2008   #7 (permalink)
Senior SLK World Member
Vehicle: SLK 350 6M + SKN chip tuning & K&N air filters
Other Toys: Motorcycles
I have to say that i have K&N on my car, for around 4000 km now, and have to say that everything is OK.
K&N is really a well known established brand, and I doubt that they would produce filters which damage the MAF sensors...
View SuzaFan's Photo Album SuzaFan is offline   Boss Key
Old 05-19-2008   #8 (permalink)
Banned For Life....
Bill T's Avatar
Vehicle: Porsche Turbo
Send a message via MSN to Bill T
its not the filter that does the damage its the oil on the filter
If it needs instructions, there's room for improvement.
I give users what they actually want, not what they say they want. And whatever I do, I will not give them new features just because other benz sites have them!
View Bill T's Photo Album Bill T is offline   Boss Key
Old 05-19-2008   #9 (permalink)
alroumi's Avatar
Yes, thats very true and K&N uses oil excessively.
Old 05-19-2008   #10 (permalink)
Yes, I know it is the oil, but wouldn't they (people in K&N) notice that in all those years and put less oil...??
Old 05-19-2008   #11 (permalink)
Vehicle: '05 SLK55
I thought the issues mentioned wtih K&N were not the factory delivered oil levels but the amount of oil on the filter after being cleaned and re-oiled by the consumers. If I recall it says to let the filters dry out (in the sun) after re-oiling to dry out the excess oil.
nmslk
View nmslk's Photo Album nmslk is offline   Boss Key
Old 05-19-2008   #12 (permalink)
Banned For Life....
Bill T's Avatar
I have purchased and installed many K&N filters over the years, I would say 3/4 of them were over oiled right out of the box. My fix for this issue was to clean and re-oil then let them sit and dry in the sun for a day then give them a good wipedown before installing.
I have had both brands side by side and I think the greens have a better filter material. (very noticable when there is no oil on the filters)
Old 05-19-2008   #13 (permalink)
Gayle280's Avatar
Vehicle: 2006 SLK280 Pewter,heating package,comfort package,satellite radio
I have no experience with K&N or Green on my SLK,however I have used K&N for 15 years on my Sentra 1993 SER (Several Mods and I do at least one 7,500 RPM shift when I take it out) and never have had any trouble with the MAF or performance. I know about the tendency to over oil so I have two and when I change out I have a clean oiled filter that has several weeks or months of drying before use. I havent made the switch yet on my SLK though.
View Gayle280's Photo Album Gayle280 is online now   Boss Key
Old 05-22-2008   #14 (permalink)
i have green filters (purchased from the slk store ofcourse!) for some time now on my '05 slk350 with zero problems so far. speaking of which, how much mileage/time is recommended before cleaning them and respraying them?
View algrensan's Photo Album algrensan is offline   Boss Key
Old 05-23-2008   #15 (permalink)
From Green Air Filter: they recommend between 30K to 50K
Old 05-23-2008   #16 (permalink)
Vehicle: 2009 SLK 55 AMG
just received my green from slk store, but since car is only 3 days old i want to be able to distinquish the sound from stock so i am waiting a bit.
Premium 1, Multimedia, Lighting packages
Clearshield Protective Film
OEM MB Plexiglass Windscreen
Eurolight Clear Side Markers
Kleyman 3rd Brake Light Flashing/Strobing Module V1.5 (Noregrets Custom Works)
View jbanks15's Photo Album jbanks15 is offline   Boss Key
Old 06-04-2008   #17 (permalink)
hey guys.. while reading this thread, i was wondering does the green filter improve the muffler sound of the car? is it noticable? i have chnaged my resonator with x pipe
View barnabas's Photo Album barnabas is offline   Boss Key
Old 06-13-2008   #18 (permalink)
does anyone knows where to get the green filter?
Old 06-13-2008   #19 (permalink)
alroumi's Avatar
euroteckmotorsporsts
Old 06-13-2008   #20 (permalink)
i saw many people sayign the buy from the slk store. and then slkworld but i couldnt find it in this slkworld.com. any idea? thx
