Visit Autogeek.net
Old 04-19-2008   #1 (permalink)
MDS
MDS's Avatar
Vehicle: SLK 55
Default Help With Green Filter Install!!
I must be blind or dumb... or both cause i've read every possible post on green filter install and that its basically easy , but I don't have a clue how to do it in my slk55.
basically i've taken off the air hose tube thats connected to the front of the car, and i've removed the front engine cover part. (the part that has the mb logo on it) i know exactly where the filter goes in cause i can see it once i removed the air pipe. .... but how the heck do you remove those 8 screws that are installed underneath. i can barely put my finger on some of them never mind a torx driver.... or am i seeing this wrong.
does anyone have pics or a step by step.... because i'm stuck at trying to take out the screws.... if those are even the screws to take off.
View MDS's Photo Album MDS is offline   http://www.slkworld.com/Boss Key
Old 04-19-2008   #2 (permalink)
alroumi's Avatar
Hey there, well I am here to the rescue and I think it will be easier with this guideline as I've followed it and everything went A okay.
http://euroteckmotorsports.com/index...5928&pageid=84
06 Porsche Cayenne S
07 Jaguar XKR Coupe'
Old 04-19-2008   #3 (permalink)
MDS
MDS's Avatar
Vehicle: SLK 55
Alroumi You Are A Life Saver!!!!!!!!!!!! Thanks Dude
View MDS's Photo Album MDS is offline   Boss Key
Old 04-19-2008   #4 (permalink)
alroumi's Avatar
Hey brother, its not a problem at all then again were here to help each other at the end of the day.
Have fun and enjoy the slk for me will you. If you put it in N and slightly hit the throttle, you'll hear the filters working with a sucking like sound " chakuk "and it sounds very good especially with the top down. Not only that it sounds good but also improves mpg and adds a couple of horses for you to enjoy and lasts longer than the oem filters which are basically the same on the 500 v8's and on our improved and faster 55's so changing them makes a marginal difference.
Enjoy it and good luck with the install.
Old 04-19-2008   #5 (permalink)
Vehicle: 2007 SLK350 6M with AMG pkg
I finally installed my Green filter after the service A. It did take me one hour because I spent half an hour running to Home Depot to get the Torx screwdriver because I lost the Torx bit I used to have.
I can tell you that after the Greens, I felt the throttle less restrictive (less tight).
View toySLK's Photo Album toySLK is offline   Boss Key
Old 06-17-2008   #6 (permalink)
SLK World Junior Member
Very helpful! I would like to buy the green filter for the SLK 55, but not sure where can I find them, I head people say that you can buy them here at SLK world but not sure where? I remember seeing the link once before but I dont see it anymore.
Can someone send me a link where I can buy them in US?
BTW Alroumi that link was very helpful, that was exactly what I was looking for, now I feel more comfortable buying the green filters.
Eri
Also how many filters do you need, only one? I remember when I saw the green filters on SLK world they said that you need two... Any reason why you need two?
Also do they have some model # so I will know what I am getting?
View exclusiveCT's Photo Album exclusiveCT is offline   Boss Key
Old 06-17-2008   #7 (permalink)
Eri
GreenFilterUSA.com. Part No. 2247, this fits the 55, 350 and 280 or 300. You'll need one pair (i.e., 2 Green Air Filters). Sometimes they have free ground shipping.
On the SLK 55, there's a plastic tie at the back of the airbox that holds a protected wire harness. Make sure you have some 12inch plastic ties handy.
1. Remove the two rounded air ducts first. Each duct leads to an air filter on their respective side. Ergo, you need two air filters.
2. Then the front decorative piece. Be careful to lift the front just enough to release the front clip, then the side slowly upward or risk breaking the side clips, then slide towards front of vehicle by an inch or two.
3. Carefully cut the plastic tie at the rear of the remaining air box.
4. Lift the main air box upward (held down by 4 clips).
Follow the instructions on the link above to remove the air filters.
Don't forget to place a new plastic tie to secure the rear wire harness.
Old 06-17-2008   #8 (permalink)
Some links to read before attempting Green Air Filter install:
http://www.slkworld.com/performance-...r-install.html
http://www.slkworld.com/amgs/4227-bo...oke-clips.html
http://www.slkworld.com/general-modi...slk-280-a.html
Old 06-17-2008   #9 (permalink)
Eddy, you are the man! Thank you so much for the quick respond and for the advice, I will purchase them and I will make sure I follow your instructions.
Thanks again.
Eri
Old 06-17-2008   #10 (permalink)
Eddy, one more questions. Do I need to add 2 (quantity) "2247 Replacement Filter" to my shopping cart? Or automatically comes as a pair? I remember here at SLK world they coasted about $100. and at GreenFilterUSA.com its $49.44.
Let me know.
Tanks,
Eri
Old 06-17-2008   #11 (permalink)
Cold Shot's Avatar
Vehicle: 2007 SLK55 AMG
Other Toys: 2007 ML 350
Donation Level 6
The plastic ties are sometimes referred to as "cable ties or zip ties", as electricians use them to bundle wire and cable. You can get a huge assortment pack of them at home improvement stores of varying lengths and widths for less than $10. I use a slightly slimmer version of the MB tie that is roughly 8" in length. They come in handy for lots of things. I use them also to route and control the visibilty of the mess behind my home theater (except fiber optic cables that you do NOT want to bend severely).
Make sure before you snug (zip) the cable tie around the harness housing (looks like a hose) and through the anchoring clip above the rear of the manifold that you have the "loose tail" pointing up. This will make it easier to cut off the excess as well as to remove it the next time you go to clean the filters.
I recommend cleaning the airboxes of debris every 2,500 to 3,000 miles. More often if you live in an area with a lot of deciduous debris on the streets that can get sucked in and restrict air flow.
Don't forget to tell the MB dealership NOT to replace your lifetime Greens at regular service intervals. That would be a waste and make you very angry.
2007 Black/Black SLK55 AMG (Green Filters, SmartTop V1, Eurolight Clear Side Markers, R170 Modded Antenna)
2007 Pewter/Black ML350
19xx White/Blonde Wife (Lmtd Edition Model)
View Cold Shot's Photo Album Cold Shot is offline   Boss Key
Old 06-17-2008   #12 (permalink)
Cold Shot's Avatar
Donation Level 6
Let me know.
Tanks,
Eri
You need a quantity of 2 filters. $100 total seems about right. Actually, a few bucks less than I paid for two.
Old 06-17-2008   #13 (permalink)
Cold Shot's Avatar
Donation Level 6
Eddy is the man! Having had the pleasure of meeting him, and receiving some help from him on a number of issues/topics, I can tell you he has definately earned his moniker of "Ambassador of Good Will".
Right on, Eddy!!!
Green filter install Ynot Performance MODS for the R171 95 06-19-2008 07:19 PM
Green Filter Orders WhiteRabbit SLK R171 General Discussion 42 07-03-2007 08:11 PM
Question on green filter install bob44 SLK R171 General Discussion 6 07-01-2007 02:30 PM
Green Filter Elwood SLK R170 General Discussion 3 04-22-2007 04:27 AM
KN Filter/Green Filter jfsully SLK R171 General Discussion 1 01-28-2007 10:10 PM
