| SLK World Junior Member Join Date: Nov 2007
| I want to tune my car which is a Slk 55 amg from this year and i would like to know where can i get the best results, what can i do with this "Antena" on the car (what replacement are possible) i tried the Sl antena but the radio signal is very poor. Ive got the sport package in it if it will help. |
Country: Thanks: 377
| If you update your location, members from your area may be able to suggest something. You'll need to use an AUX ANT in the rear bumper if you want to continue with the SL antenna. Check out posts by Zeiser50 (Michel).
| Link to Zeiser50"s modification: http://www.slkworld.com/general-modi...extension.html Other links: for removing rear center paneling: http://www.slkworld.com/slk-r171-gen...r-section.html removing trunk side paneling: http://www.slkworld.com/slk-r171-gen...-paneling.html removing rear bumper cover: http://www.slkworld.com/slk-r171-gen...ar-bumper.html
| | #6 (permalink) | |
One simple mod is to change the OEM air filters to Green Air Filters, this will improve the hp and torque slightly as well as improve the fuel economy. Link: http://www.slkworld.com/general-disc...ut-inside.html Check this site for performance mods (under build your own) http://www.gmbhmotorsports.com/index.cfm
Country: Thanks: 96
| For performance then air filters are a good and cheap mod. For bigger results then think about exhaust cat's and headers. Also camshafts are good mod.
| | #8 (permalink) |
Country: Thanks: 135
| I've had good results with the r170 short stubby antenna, some members say the reception is bad, I used the radio a lot and can't tell the difference, only problem is if you have the roof module the key fob distance is bad, but that doesn't bother me. Plenty of mods for the SLK55, much more than the SLK350. Bolt on mods are very expensive and give very little hp gain. The best value for the money is a supercharger, not cheap but if you add all the bolt-on parts, it's half of the supercharger with little gain. Check out B55's Brabus mods. http://www.slkworld.com/vbgarage.php?do=view&id=26 jliu has renntech supercharger, maybe give him a PM addictedtospeed has the Kleemann supercharger, several others have the Kleemann SC on mbworld.org Good luck.
| 2007 SLK55 AMG or 2008 SLK 350 (Facelift) | Twisted | SLK R171 General Discussion | 42 | 09-14-2008 11:46 AM |
| AMG Power - July 2008 | Tslick | AMGs | 3 | 08-23-2008 12:04 AM |
| 2008 SLK55 AMG Brakes | MDLSLK55 | AMGs | 184 | 03-09-2008 10:30 PM |
| New 2008 SLK55 AMG! | MDLSLK55 | AMGs | 38 | 09-03-2007 08:47 PM |
| 2008 Slk55 Amg | tr2501968 | AMGs | 31 | 05-05-2007 12:36 PM |
