| Senior SLK World Member Join Date: Aug 2006 Location: Toronto, Ontario
Vehicle: 2006 SLK 280
Country: Thanks: 36
| Hi guys!! So I've been going to the track quite a bit this year and I'm wondering what you guys think and any opinions you have on what I should do next in terms of handling. All I currently have are Eibach Pro-Kit springs and a set of R-Compounds. I started with 225/50/16 Toyo Proxes RA1 and now I'm on 235/40/17 Hankook Ventus (RSS?) Z211. I am thinking of Coils of some sort but I dunno what my options are. I know Bilstein and KW V3 coils exist. I dunno if I have any other (more affordable) options out there. Thinking of sways + struts but I dunno what options I have. ALL ADVICE WELCOME!! -Kelvin
__________________ 2006 SLK 280 6MT To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. |
Country: Thanks: 291
| Eibach and H&R are the cheapest springs and are quiet good from some while, If you are going to progress for something very dedicated go for the Carlsson/Bilstien Coiloversystem whilst at it you should compare with the Brabus coilovers and the offerings from MKB and Kleemann.
| SLK World Member Join Date: Oct 2006 Location: lexington
Vehicle: 2001 Stock SLK230 silver
| I have an R170 - but, I do have H&R Springs and Bilstein shocks. The mistake I did was get the setup before I actually tried to autocross my car. I was used to fun oversteer on the streets but the shocks and springs radically changed the characteristics of the vehicle - its all major understeer now. So it took some time getting used to but I don't think my times would have gone down to much had I not purchased the setup. I would suggest getting completely used to your cars existing handling traits (at least 10 events) then buy shocks, then springs and so on. If you have an SLK55AMG then I wouldn't worry about getting to much for the suspension as the car is excellent stock. |
| I see you have a 280 - get the real deal man, I would go for a full bilstein coilover kit BUT get rid of those tires man! Hankooks?!? no....stick with the following: Bridgestone Potenza RE01R Goodyear Eagle F1 GS-D3 Continental SportContact 2s Dunlop Direzza Series Your not in an import man in fast and the furious, toyo's and hankooks are typical import tires. Mercedes reccomends either dunlop, pirelli or continental and after extensive research I see why. The way the tires break at the limit is designed with the cars in mind so the cars suspension and tires are in sync. They both will give up at the same time basically. |
Vehicle: 2006 Slk 350
Country: Thanks: 3
| Michelin Pilot Sports. If you have the springs already, i would maybe spend the money on headers or something to make the car a little more muscley. I think your current suspension set up can handle the cars speed quite well right now. OR upgrade your brakes, to maybe something like the 350's brake system (which is just the brembo 335mm kit i believe), or even the AMG brakes (but you would need bigger rims for clearance, where as the 350 brakes work on 17's.) Just my 2 cents. |
Country: Thanks: 36
| Thanks guys. What do you guys think is better in terms of coilovers: Bilstein PSS9's vs. KW Variant 3? Also, as for tires...McFaisal, the ones you mentioned are all UHP aren't they? I'm lookin' at R-comps only and I still have to keep price in mind. Even the Potenzas are only semi-slick I believe. Am I wrong? I'm lookin' at the next set to be 235/40/17. Bridgestone Potenza RE01R Goodyear Eagle F1 GS-D3 Continental SportContact 2s Dunlop Direzza Series
Country: Thanks: 135
| I don't know anything about Bilstein but the KW's are adjustable to your track needs and I've only heard good things about it. Continental SportContact 2s are bad on the track, it's what I'm currently tracking with, they melt on a hot day and will make you slide around on the track, fun but not the fastest way around a road course. I thought I was the only person but found out on the bimmer forums that it's common for Conti's to melt on a very hot track.
| | #9 (permalink) |
Country: Thanks: 36
| Thx guys. I think I've decided to go with KW V3. Anyone know any sources for best pricing?? I have a source that said about $2400 CAD to include shipping as well. Is that high/low?
| | #10 (permalink) | |
| | #11 (permalink) | |
| Elite SLK World Member Join Date: Oct 2006 Location: Plano, TX
Country: Thanks: 39
Just went to Texas World Speedway on Goodyear Eagle F1 GS-D3. Handled nicely, but I was chewing rubber off of them like crazy (Still pulling off pieces of rubber from around the car). Outran two Ferrari's on racing slick's; but to be honest, I don't think they knew how to drive, one of them spun into a wall. I have run with BS Potenza RE-01Rs and like the performance on the track better and getting a set on for my track tires. But I need a better setup to stop nose-diving during hard braking on the track and to keep the car more even on the curves to keep up with those quick little Miata's / Lotus' that want to pass me. Anyone have experience with their shock / spring setups???? | |
| | #12 (permalink) | |
Country: Thanks: 39
Give the guys at Tire Rack a call. I have found them to be most helpful. They seem to have some Kumho slicks that are not too expensive. The Yoko's are very expensive. | |
| need an advice | mazeka | SLK R171 General Discussion | 9 | 4 Weeks Ago 09:31 AM |
| handling difference with roof open | songxu | General Discussion | 11 | 08-05-2008 03:53 AM |
| advice | mazeka | SLK R171 General Discussion | 7 | 06-18-2008 11:19 AM |
| Would you like to upgrade the handling of your SLK350/280? Selling my AMG suspension! | Addicted2Speed | SLK R171 General Discussion | 4 | 03-10-2008 12:43 PM |
| Handling the holidays. | Corkscrew | Off Topic | 6 | 12-10-2007 11:45 PM |
