Welcome to SLKWorld
LinkBack (4) Thread Tools
Old 08-30-2007   4 links from elsewhere to this Post. Click to view. #1 (permalink)
Vehicle: '07 SLK55 AMG
Other Toys: Honda motorcycle
Default What to look for in a Dyno?
I want to dyno the car when it gets to 2k miles before I start adding things like the greens, etc.
What type of dyno here in the states should I be looking for, and the quirks of dyno equipment?
Is there anything I need to do except enable engineering mode beforehand?
-Doug
Old 08-30-2007   #2 (permalink)
alroumi's Avatar
Around 300 to the wheels, you should try both 3rd gear and 4th gear attempts.
06 Porsche Cayenne S
07 Jaguar XKR Coupe'
Old 08-30-2007   #3 (permalink)
cool, thanks!
Old 08-30-2007   #4 (permalink)
alroumi's Avatar
No problem hope you exceed 300hp, I am betting around 302hp to the wheels.
Old 08-30-2007   #5 (permalink)
Lol, we should start a pool!
"Pick the HP"
Old 08-31-2007   #6 (permalink)
Default 4th
it should be in 4th gear. I don't know why you would try 3rd ...
Also in terms of the Dyno place make sure they have a LARGE fan and plan on using this same place over and over. No point in switching between dyno shops. if you do the different dynos and also different configurations will make them totally inaccurate against each other.
If you are on a Dynojet my pick is 300 rwhp.
View jliu's Photo Album jliu is offline
Old 08-31-2007   #7 (permalink)
Vehicle: 2005 SLK55
I tried 3rd and 4th. Just run 4th. Much smoother curve as 3rd went by really quick and kindof spiked. So 3rd had a higher number but then fell off.
I sortof wished I had pulled the airbox off on one of the runs to see how much difference it made as I am sure the box was really hot.
View VitaminT's Photo Album VitaminT is offline
Old 08-31-2007   #8 (permalink)
I was thinking about bringing the greens with me and install them while on/at the dyno.
I haven't installed them before, does that sound realistic?
Old 08-31-2007   #9 (permalink)
Ynot's Avatar
That's a good idea, a lot of people do it that way, just to see how much they gain, or if they gain anything at all.
I would practice installing it first at home, so you'll know what tool is needed, and how to do it beforehand. When you are there, you will not waste anyone's time. It's really simple, can be done quickly.
Good luck.
Old 08-31-2007   #10 (permalink)
Vehicle: 2006 Slk 350
Other Toys: Lots of ATV's
mo, you sound like youve done it before
Old 08-31-2007   #11 (permalink)
easty's Avatar
Vehicle: ///AMG
Donation Award
Mine at about 10k to compare. Completely stock track raced from 500miles. a guy at the same dyno had 305hp/307tq
Old 08-31-2007   #12 (permalink)
Vehicle: 2005 SLK55
Just remember the airbox is super hot to handle coming off a hot motor. You can try to but that would be the only problem I see.
Old 08-31-2007   #13 (permalink)
Just watch out if you remove the airbox, its really not recommended to run the engine without it we even use them on the test stands that are fully air-conditioned.
Doug, if i where you mate i would only do the install at ambient temp mate while the install is super easy the box gets real hot and contains a lot of rubber parts just like the filters, you might end up damaging something without even touching it from pinched seals and so on.
Old 08-31-2007   #14 (permalink)
Don't feed the trolls...
FishtailnZ's Avatar
Donation Award
There are several types of chassis dyno's out there - "Dynojet" being the most common. Another couple common ones are "Mustang" and "DynoDynamics". Both the latter tend to read lower than Dynojet; doesn't mean the car is making less power, just a characteristic of those dyno types. Another good base line to get while your car is stock, and a good supplement to dyno testing, is to run the car in the 1/4. Trap speed (don't worry about ET so much, that's more a driver dependant item ) are fairly consistent, all else being equal.
Re what gear to use, dyno operators like to use the gear that gives (or closest to) 1:1 ratio (has something to do with minimizing built in errors in the way HP is calculated) ,which in the SLK55 is actually 5th gear. But I'm sure your dyno operator will know best what works with his particular setup.
I'm also planning to get on the dyno next week if all goes to schedule.
- Bill
Waiting on a 2009 C63 Opal Fire Red/Alpaca Grey
R.I.P. 2006 SLK55 Caspian Blue/Beige
Stock 1/4 mile results: ET 12.72, trap 110.80, 60' 1.80
View FishtailnZ's Photo Album FishtailnZ is offline
LinkBacks (?)
LinkBack to this Thread: http://www.slkworld.com/performance-mods-r171/3718-what-look-dyno.html
Posted By For Type Date
Any SLK55s located near Costa Mesa?!?! - MBWorld.org Forums This thread Refback 06-06-2008 07:43 AM
Any SLK55s located near Costa Mesa?!?! - MBWorld.org Forums This thread Refback 06-06-2008 12:30 AM
Any SLK55s located near Costa Mesa?!?! - MBWorld.org Forums This thread Refback 06-06-2008 12:09 AM
Any SLK55s located near Costa Mesa?!?! - MBWorld.org Forums This thread Refback 06-06-2008 12:00 AM
$13 Dyno! dsb Off Topic 2 09-04-2008 09:46 AM
Surprised dyno of IS-F at dealer Lizard Off Topic 5 06-08-2008 06:01 PM
SLK55 dyno, topspeed ! alroumi SLK Videos 4 07-01-2007 06:04 PM
How to dyno '55 Hakaze SLK R171 General Discussion 21 06-11-2007 11:06 AM
Discounted Dyno in SoCAL Sid General Discussion 9 04-14-2007 01:17 PM
