Vehicle: '06 slk55
Country: Thanks: 67
| I just had my car serviced and they measured the front pads at 5mm and the rears at 8mm. So, I'm now looking into replacing the pads. I'd like to get something that performs as well as stock but preferably with less dust. I know there's a lot of reputable companies that offer such brake pads. My question is what do you all recommend? Also, is there another Mercedes Benz vehicle that shares the same brakes as the '05-'07 SLK55? I got to believe there is. It would be easier to search, say a C55, for brake pads vs the fairly new SLK55.
__________________ SOLD! 06 Mercedes Benz SLK55 Caspian Blue / Black & Ash To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. |
Country: Thanks: 135
| I haven't change mine but slktyperice said that he uses Porterfield Brake Pads, he said it doesn't fade and has minimum brake dust. Here's what I got from formymercedes.com, they sell pads for both the SLK350 and SLK55. Porterfield R4-S Carbon/Kevlar Street Brake pads offer these advantages: * 90% Less Dust than OEM * Light Pedal Effort * Rotor Friendly * High Friction, Hot or Cold * Low Wear Rate * Fastest Stopping Road Pad Available! * Friction Coefficient: OEM: Between .2 and .3 Porterfield: .4 * Temperature Tolearance: OEM: 500-700 degrees F Porterfield: 1,100 degrees F Here's the link. http://www.formymercedes.com/porterfield.asp
| Senior SLK World Member Join Date: Jul 2006
| Actually, I went the ceramic route with my first set of new pads with Akebono pads I got from Tirerack. I need to change again, and I'm definitely going Porterfield. I recommend Porterfield if you want the best for your SLK and don't want to gamble about fitment. |
Vehicle: '06 slk55
Country: Thanks: 67
| I looked into the Porterfield's a while back. Jerry (FMM) gave me some good info but there isn't a pad specifically made for the SLK55. Here's is some copied information from Jerry: The Porterfield pads would be essentiall hand made. They do not have the "factory metal" backing plate, so they will make one from another large pad. So we can discuss how you feel about having or not having wear sensor connectivity.... Porterfield tells me the pads are cut from a 6 piston GT3 porche racing pad. So the puck is molded on, not riveted. The pads are huge.... Since there is a slot in the Porshe pads for wear sensor connection, I think your sensors will work. What I'm going to do, is send the Mercedes Benz sensors to Porterfield so they can see if wear sensors can be connected for this application. That way they'll know what diameter hole to drill into the pad material, and depth. That is the last communication I had with him 4 months ago. I guess I should contact him again and try out the front pads. I was just hoping there would be a direct replacement (same size)
| Elite SLK World Member Join Date: Aug 2006 Location: Long Beach, Ca
Vehicle: SLK32 AMG
Country: Thanks: 74
| Doesn't brake fade have to do with overheating hydraulic (brake) fluid. Going back to the 2008 AMG brake issue, reducing the surface area of the piston(s) causes the temperature of the hydraulic fluid to increase due to increased PSI required to achieve equivalent force. |
Country: Thanks: 96
| Thats one type yeah it and it normally produces the mushy feel on the pedal. You then have glazing that occurs after active braking and a cooling period where the resin tends to solidify over the pad face in a slick form, the other primary type and common root cause is triggered by the pads overheating and being forced to work outside of the recommended temperature range they then start to lose performance rapidly this itself does not cause a weird feeling in the pedal so can creep up on you but because its temp related it also tends to cause the fluid to boil and give you a warning.
| | #9 (permalink) |
Country: Thanks: 96
| mushy pads? thats a new one mate sorry. Just telling it like its been told me i was taught that brake fade is a term given to anything that reduces brake stopping power. MB give the main 3 - Fluid boiling and releasing compressible gas into the system that gives a mushy pedal. Pad's glazing after a session of hard driving. And the loss of performance as they overheat during hard driving. Just how I've been taught but as always open to corrections.
| | #10 (permalink) |
| Elite SLK World Member Join Date: Oct 2006 Location: Plano, TX
Country: Thanks: 39
| "Porterfield R4-S Carbon/Kevlar Street Brake pads offer these advantages: * 90% Less Dust than OEM * Light Pedal Effort * Rotor Friendly * High Friction, Hot or Cold * Low Wear Rate * Fastest Stopping Road Pad Available!" That is the one thing, the MB brakes leave a ton of dust to clean off all the time. |
| | #13 (permalink) |
| Senior SLK World Member Join Date: Aug 2006 Location: Toronto, Ontario
Vehicle: 2006 SLK 280
Country: Thanks: 36
| Do they have (is it called?) Hawks HPS or HP+?? A lotta track people use it because they're supposedly very good and reduce a lot of brake dust. They're just damm noisy...
__________________ 2006 SLK 280 6MT To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. |
| | #14 (permalink) |
| SLK World Junior Member Join Date: Nov 2007
| DSB 5mm and 8mm doesn't sound so bad. I was told after my service 'D' that I needed to change all four pads as well as the front disc rotors. But after purchasing the OE parts and having a more mechanically inclined friend help pull my car apart, we found all four pads to be quite meaty and only slight grooving on the rotors. This is after 65,000km and a change from the stock 16s to after market 18s somewhere in between (not sure if this is relevant). We decided to leave it as is. Since the pads appeared to be arond 40% - 50% worn compared to the new Textar pads I had, my friend figured it'd be safe for around another 20,000km. any opinions would be much appreciated |
| | #15 (permalink) | |
Vehicle: '06 slk55
Country: Thanks: 67
__________________ SOLD! 06 Mercedes Benz SLK55 Caspian Blue / Black & Ash To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. | |
| Installing non-OEM brake pads | mobidutch | SLK R171 General Discussion | 0 | 10-17-2008 12:36 PM |
| Brake Pads | Dennis | SLK R171 General Discussion | 2 | 07-27-2008 08:12 PM |
| Brake Pads | pawnman5 | Ask DansSLK | 11 | 06-06-2007 06:33 PM |
| Brake Pads | jfsully | Ask DansSLK | 1 | 04-14-2007 10:20 PM |
| R170 Brake Pads | DesignoSLK | Ask DansSLK | 12 | 02-03-2007 09:35 PM |
