Click Here
Old 08-24-2007   #1 (permalink)
dsb
dsb's Avatar
Vehicle: '06 slk55
Default Changing brake pads
I just had my car serviced and they measured the front pads at 5mm and the rears at 8mm. So, I'm now looking into replacing the pads. I'd like to get something that performs as well as stock but preferably with less dust. I know there's a lot of reputable companies that offer such brake pads. My question is what do you all recommend?
Also, is there another Mercedes Benz vehicle that shares the same brakes as the '05-'07 SLK55? I got to believe there is. It would be easier to search, say a C55, for brake pads vs the fairly new SLK55.
'06 Mercedes Benz SLK55
Caspian Blue / Black & Ash / DPE 19" R07s, Other Stuff
View dsb's Photo Album dsb is offline   http://www.slkworld.com/Boss Key
Old 08-24-2007   #2 (permalink)
Super Moderator
From memory the SL does
Old 08-24-2007   #3 (permalink)
Ynot's Avatar
I haven't change mine but slktyperice said that he uses Porterfield Brake Pads, he said it doesn't fade and has minimum brake dust. Here's what I got from formymercedes.com, they sell pads for both the SLK350 and SLK55.
Porterfield R4-S Carbon/Kevlar Street Brake pads offer these advantages:
* 90% Less Dust than OEM
* Light Pedal Effort
* Rotor Friendly
* High Friction, Hot or Cold
* Low Wear Rate
* Fastest Stopping Road Pad Available!
* Friction Coefficient:
OEM: Between .2 and .3
Porterfield: .4
* Temperature Tolearance:
OEM: 500-700 degrees F
Porterfield: 1,100 degrees F
Here's the link. http://www.formymercedes.com/porterfield.asp
View Ynot's Photo Album Ynot is offline   Boss Key
Old 08-24-2007   #4 (permalink)
Senior SLK World Member
Actually, I went the ceramic route with my first set of new pads with Akebono pads I got from Tirerack. I need to change again, and I'm definitely going Porterfield. I recommend Porterfield if you want the best for your SLK and don't want to gamble about fitment.
View slktyperice's Photo Album slktyperice is offline   Boss Key
Old 08-24-2007   #5 (permalink)
dsb
dsb's Avatar
Vehicle: '06 slk55
I looked into the Porterfield's a while back. Jerry (FMM) gave me some good info but there isn't a pad specifically made for the SLK55. Here's is some copied information from Jerry:
The Porterfield pads would be essentiall hand made. They do not have the "factory metal" backing plate, so they will make one from another large pad. So we can discuss how you feel about having or not having wear sensor connectivity....
Porterfield tells me the pads are cut from a 6 piston GT3 porche racing pad. So the puck is molded on, not riveted. The pads are huge....
Since there is a slot in the Porshe pads for wear sensor connection, I think your sensors will work. What I'm going to do, is send the Mercedes Benz sensors to Porterfield so they can see if wear sensors can be connected for this application. That way they'll know what diameter hole to drill into the pad material, and depth.
That is the last communication I had with him 4 months ago. I guess I should contact him again and try out the front pads. I was just hoping there would be a direct replacement (same size)
View dsb's Photo Album dsb is offline   Boss Key
Old 08-24-2007   #6 (permalink)
Vehicle: SLK32 AMG
Doesn't brake fade have to do with overheating hydraulic (brake) fluid.
Going back to the 2008 AMG brake issue, reducing the surface area of the piston(s) causes the temperature of the hydraulic fluid to increase due to increased PSI required to achieve equivalent force.
View Tslick's Photo Album Tslick is online now   Boss Key
Old 08-25-2007   #7 (permalink)
Super Moderator
Thats one type yeah it and it normally produces the mushy feel on the pedal.
You then have glazing that occurs after active braking and a cooling period where the resin tends to solidify over the pad face in a slick form, the other primary type and common root cause is triggered by the pads overheating and being forced to work outside of the recommended temperature range they then start to lose performance rapidly this itself does not cause a weird feeling in the pedal so can creep up on you but because its temp related it also tends to cause the fluid to boil and give you a warning.
Old 08-25-2007   #8 (permalink)
Vehicle: SLK32 AMG
Dan, brake fade vs mushy pads are separate subjects.
Old 08-25-2007   #9 (permalink)
Super Moderator
mushy pads? thats a new one mate sorry.
Just telling it like its been told me i was taught that brake fade is a term given to anything that reduces brake stopping power.
MB give the main 3 -
Fluid boiling and releasing compressible gas into the system that gives a mushy pedal.
Pad's glazing after a session of hard driving.
And the loss of performance as they overheat during hard driving.
Just how I've been taught but as always open to corrections.
Old 08-27-2007   #10 (permalink)
F111F's Avatar
"Porterfield R4-S Carbon/Kevlar Street Brake pads offer these advantages:
* Rotor Friendly
* Low Wear Rate
* Fastest Stopping Road Pad Available!"
That is the one thing, the MB brakes leave a ton of dust to clean off all the time.
View F111F's Photo Album F111F is offline   Boss Key
Old 08-27-2007   #11 (permalink)
Vehicle: SLK32 AMG
mushy pads? thats a new one mate sorry.....
No biggie, In my neck of the woods, mushy pads (peddle) is due to low hydraulic fluid level or glazing. Brake fade (or loss) is due to overheating hydraulic fluid (boiling).
Old 08-27-2007   #12 (permalink)
Super Moderator
Ah OK i understand what you meant now
Old 10-12-2007   #13 (permalink)
B4TM4N's Avatar
Vehicle: 2006 SLK 280
Other Toys: C300 RWD 6MT
Send a message via ICQ to B4TM4N Send a message via MSN to B4TM4N
Do they have (is it called?) Hawks HPS or HP+??
A lotta track people use it because they're supposedly very good and reduce a lot of brake dust. They're just damm noisy...
2006 SLK 280 6MT
View B4TM4N's Photo Album B4TM4N is offline   Boss Key
Old 03-18-2008   #14 (permalink)
SLK World Junior Member
DSB
5mm and 8mm doesn't sound so bad. I was told after my service 'D' that I needed to change all four pads as well as the front disc rotors. But after purchasing the OE parts and having a more mechanically inclined friend help pull my car apart, we found all four pads to be quite meaty and only slight grooving on the rotors. This is after 65,000km and a change from the stock 16s to after market 18s somewhere in between (not sure if this is relevant). We decided to leave it as is.
Since the pads appeared to be arond 40% - 50% worn compared to the new Textar pads I had, my friend figured it'd be safe for around another 20,000km.
any opinions would be much appreciated
View GAM817's Photo Album GAM817 is offline   Boss Key
Old 03-18-2008   #15 (permalink)
dsb
dsb's Avatar
Vehicle: '06 slk55
Originally Posted by GAM817 View Post
DSB
Thanks for the input. I have since realized that the OE does, in fact, have quite a bit of life left. I've decided to hold out on replacement pads a little longer.
nickoloff
Brake part nos. needed to retrofit '08 to '07 etyu Ask DansSLK 49 1 Week Ago 11:58 PM
Do Brake Rotors Have a Short Life?? gmabli General Discussion 9 10-29-2007 10:28 AM
Brake Pads pawnman5 Ask DansSLK 11 06-06-2007 06:33 PM
Brake Pads jfsully Ask DansSLK 1 04-14-2007 10:20 PM
R170 Brake Pads DesignoSLK Ask DansSLK 12 02-03-2007 09:35 PM
