| SLK World Junior Member Join Date: Jul 2007 Location: Vancouver, BC, Canada
| Thinking about upgrading from 17" to 19" for the SLK350, 225/45/17 to 235/35/19 and 245/40/17 to 265/30/19. Told that to my friend and he is concern about my ability to stop with bigger wheel. He said that with the bigger wheel, the wheel spin faster and is harder to stop. I will need bigger break to keep the same stopping distance. He also said that the I don't have enough power to take off from standing stop and the car will feel slower. He recommend that I only go one size bigger and not two. I don't see the point of upgrading just one size as I have the 17" AMG RIM. If I upgrade the brake also, how big should I go. 4 or 6 piston? 355mm or 380mm? I know kleemann is the best but they are so expensive. what do you think about these ones? http://www.evosport.com/product/prod...m=RTR.BRK.B101 http://www.autocarparts.com/part/194/589/ Will the car feel slower? Welcome all input........ |
Vehicle: '06 slk55
Country: Thanks: 67
| I think 19's will impact the handling but not to the extent you'll need to upgrade your brakes. It might also slightly affect takeoff but again, not enough to merit going to a smaller wheel. It really comes down to your preference. Unless your driving very aggressive and/or track a lot, I think you'll be fine. SLK brakes are very good. I can't remember any brake fade when I had my SLK350. Either way, first get the 19's and then determine if you need to upgrade your brakes.
__________________ SOLD! 06 Mercedes Benz SLK55 Caspian Blue / Black & Ash To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. |
Country: Thanks: 288
| Make sure you go for lightweight wheels, reduces unsprung weight and braking performance as each wheel is lighter makes the car weightless. Aftermarket brake packages are expensive, it would be best to go for ebc pads as i have heareed they work pretty well and have little brake dust. |
Country: Thanks: 54
| Banned Join Date: Jan 2007
| The break distance is becoming shorter with wider rubber - look for a new friend, he´s telling crap I upgraded from 17 to 19´´ - the only differnce* you feel is in turns: The handling with the wider wheels is much better.* - the car is becoming harder, but that´s a question of the tyres and the air pressure too. |
| | #6 (permalink) | |||
Country: Thanks: 135
My 19"s are noisy and feels rough but I blame it on tire brand not size. Do it, don't worry about what your friend say.
__________________ 06' SLK 350, Iridium/Ash all pkgs. 6-spd, 19" DCR. To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. | |||
| | #8 (permalink) |
| Elite SLK World Member Join Date: Apr 2007 Location: Bay Area, CA
Vehicle: '07 SLK55 AMG
Country: Thanks: 22
| Side Tire Question: Can you go up 1 size of width on the stock AMG55 18" front and rear wheels? Say 225 to 235 or 45? or 255 in the rear? |
| | #9 (permalink) |
Country: Thanks: 96
| Yep mate you can comfortable go up on size both front and back but you don't need to bother on the fronts 225 is sufficient and personally i think 255 is perfect for the rear.
| | #12 (permalink) |
Country: Thanks: 96
| ipsep, With 19's you will reduce your takeoff speed but i doubt you will even be able to tell the difference to be honest with you. If you where to upgrade to 19's and all other variables where to remain the same it would take longer for you to stop but not much longer, however you want to increase tire size and that will increase the rolling resistance that will cause the car to slow faster when the brakes are applied so your probably not looking at stopping faster but you wont take longer to stop either. All modern cars have brakes that can stop the car at full power plus extra so the car cannot ever overwhelm them so if you nail the brake pedal to the floor you will stop very rapidly, if you are still a little concerned however i would recommend a slightly harsher pad something that will bite into the disk a bit more that will reduce your stopping distance but will increase disk wear. And the bigger contact patch will help in corners also
| | #13 (permalink) | |
| | #14 (permalink) |
Country: Thanks: 96
| I have never tested something like this with cars side by side to be 100% Gero mate but it comes down to the weight of the wheel and the size and stickiness of the contact patch. If you apply a certain amount of brake pressure and the standard wheel setup and measure stopping distance then do the same test with 19's and see what you get, its either going to show the rotational speed of the wheel caused it to overshoot or the bigger contact patch provided enough extra resistance to counteract it either canceling the effect out and giving you the same results or being stronger than the force applied by the wheel and reducing stopping distance. At the end of the day the verdict is the same - you don't need to worry about stopping distances with 19 inch wheels on a SLK350
| | #15 (permalink) |
| SLK World Member Join Date: Jul 2006 Location: Germany
Vehicle: '06 SLK55
Country: Thanks: 8
| With ABS, wouldn't the big stopping distance factor be the size and effectiveness of the contact patch? Unless the wheel weight is so great that it overwhelms the brake to the point that it does not engage the ABS function, I would think that the contact patch would be the primary reason why the ABS would allow the car to stop in a shorter or longer distance. With the system engaged, I would thing that the weight would become more as total vehicle weight rather thand the effect of unsprung weight as with accelleration. Over time, the weight would probably add to heat and brake fade but not under normal driving conditions where you'd really need an emergency stop. |
| Who makes this rim? | ppower | Performance MODS for the R171 | 15 | 11-14-2007 02:03 PM |
| Choosing rim size | Otsego | SLK R171 General Discussion | 21 | 10-14-2007 06:27 AM |
| It Had To Happen!! | garyhun | SLK R171 General Discussion | 14 | 09-17-2007 11:08 AM |
| What would happen if... | DesignoSLK | Ask DansSLK | 5 | 08-31-2007 10:40 AM |
| Breaking in my new SLK | JOC | General Discussion | 12 | 06-08-2007 08:37 AM |
