Windrestrictor
Old 06-30-2007   #1 (permalink)
Default New type of KW coilover kit for the R171
KW has now according to CHROMETEC a new type of coilover kit for the SLK R171 available.
The difference to the KW kit type 3 which I have is that both front and rear dampers now are true coilovers instead of rear spring located beside the damper as the original setup. The dampers have now two springs each instead of just one. A smaller softer spring to make slow driving more pleasant, then a stiffer spring to handle harder driving. Both springs are made in smaller diameter than my type 3 kit which allows wider wheels/more lowering than before.
CHROMETEC's price for this kit is 1390EUR.
File Type: jpg kw_gewindefahrwerk_druck_zugstufe_einstellbar.jpg (113.0 KB, 58 views)
View bejak's Photo Album bejak is offline
Old 06-30-2007   #2 (permalink)
Ynot's Avatar
That's about $1,900 USD, not too bad, looks good too.
Aftermarket HID Kit on the R171 ghostdunks Help and Support 45 10-08-2008 07:56 PM
Install of aftermarket radio and BT kit to replace Audio20 in the R171 SLK ghostdunks General Modifications R171 32 08-01-2008 09:00 PM
Oil type for SLK350 dee101 SLK R171 General Discussion 4 01-14-2008 08:10 PM
Type of supercharger Dimitrism SLK R171 General Discussion 0 12-08-2006 02:06 PM
Best type of tire for the money. Baron7700 General Discussion 15 10-13-2006 04:06 PM
