Go Back   Mercedes Benz SLK World Forum > Technical Information > DIY Section
DIY Section Step by step procedures for common maintenance and upgrades to your SLK
LinkBack (1) Thread Tools
Old 03-03-2009   #21 (permalink)
Vehicle: 2006 SLK 55 AMG
That's a great idea, didn't even think of it. I notice you're in the UK, are you offering to help a fellow member??
I of course would pay for all bills, misc. charges, and make it worth your while (we can discuss this off line). If it's something you can take time to do just let me know otherwise I will post a separate thread and make the request to see what response I get. Thanks either way for making this suggestion.
View swelsh's Photo Album swelsh is offline
Old 03-04-2009   #22 (permalink)
Donation Level 8
PM UK-C200, he may be able to help.
Pewter(cubanite silber)/Beige, PIII package, Airscarf, Hands-Free Communication System, Lighting package
Bill T), SmartTop v1.0, Kleyman 3BFM (NoRegret Custom), Green Air Filters, Modified R170 ant., Clear sidemarkers & parking lamps w/error-free LEDs, chromed front & rear turn indicator lamps, bilateral rear fog lamps enabled, steel mesh at battery bay cover & cabin air intake.
Old 05-11-2009   #23 (permalink)
SLK World Junior Member
Vehicle: 2006 SLK 55 AMG - Iridium Silver
Other Toys: 1995 Ford Bronco
Hi guys!
I regularly follow this forum. I don't post much but I certainly read a lot. I guess that I have much to learn than to teach. It's great!
For months, I've been planning on replacing my 2006 SLK 55 AMG steering wheel with the 2007 one (i.e. the one with the aluminum shift paddles). I've read so many times Aquascape's initial thread but I was always stopped by the top $$ that a new 2007 steering wheel costs in my country (import taxes are very high). I've asked for a few quotations from local MB dealers and they are all above US $ 4,000. A could buy a car, a high mileage beaten up car for that money ... but still an entire car!
I've tried to find the 2007 steering wheel through EBAY but no luck.
I just read Swelsh's and Etyu's comments in regards to members of slkword that are UK based and that could be willing to help others buy the steering wheel in the UK and then to ship it outside the UK?
Please shed some light on this.
View scocios's Photo Album scocios is offline
Old 05-26-2009   #24 (permalink)
Scocios,
I had found a company in the UK that was selling the wheel for much cheaper than I could find in the US (even with the exchange rate from GBP to USD) but they wouldn't ship outside the UK. So I worked with a fellow member who was going to purchase for me in the UK after I payed them through Paypal and then they were going to ship to me in the US. I of course would pick up all charges and fees for anything.
I ended up not needing to do this because UK-C200 pointed me in the direction of a US based company that had the wheel even cheaper (I think I paid about $1200 total which is still not cheap but much cheaper than the dealer or anything else I found). Here's the web site I used (http://www.trademotion.com/partlocat...89&catalogid=0), not sure if this will help you but I hope you understand what was going on a little better.
By the way ... I love the new wheel and paddles. So much better than the buttons in my opinion. And the installation was easy using this thread. Let me know if you have any other questions.
Old 06-04-2009   #25 (permalink)
Default Thanks Much
Upgrading my SL500 wheel with a wood grain option. Based on what you did, I'll bet my change over is very similar.
To be on the safe side, I'll disconnect the battery for 1hr as well. Thanks you much for your post.
Stephen
View stephenguyon's Photo Album stephenguyon is offline
Old 07-14-2009   #26 (permalink)
aka John
Vehicle: RHD Jasper Blue C200K Coupe, RHD Jasper Blue SLK55, LHD Black SLK350
Donation Level 7
Chats: 1142
So just did the upgrade on my '55, and man, I am happy! Thanks to Dan - as usual - for the advice.
Some comments :
1] The 10mm hex bolt in my car was absolutely tighter than 80nm from the factory. I ended up using a 3" extender on a 16" breaker bar. I didn't have a 10mm hex socket, so I picked up a 1/2" chuck short hex socket. I'd stay away from 1/4" - was fortunate that I had 1/2" for everything else.
2] It's trivial to remove the air bag itself, but the wires are a bit short - take your time and be patient, and make sure you understand how to remove the connectors. REMOVE the battery!
3] Since you are removing the battery, make sure you remove the set-screws holding the air bag / switch assembly before disconnecting power. NOTE that these are on retention clips, so they will not come out of the wheel. This way you can unlock the steering wheel and move as necessary to gain access. The "left" side screw is a bit challenging is get to with levers in the way at "straight up".
4] With a 3" extender on a 16" breaker (90 degree), it's much easier to remove the wheel with the top down. I had an extra pair of hands holding the wheel, but I don't think that's 100% required. As I mentioned before, I was worried I'd not be able to break it loose - it was damned tight.
5] MY09 / 030 steering wheel is a bit tighter than the old one to wire up - take your time, and the CAN connections are in a bit different position. The shifter connections are labeled on the back of the air bag, make sure you connect violet to violet.
6] There are alignment points on the new wheel - so it's really trivial to insure that it's installed in the proper orientation.
7] I used Loc-Tite Blue on the threads, and as advised from Dan, put a line across the top edge of the head, so that any movement would be easily noticeable. Torqued to 59 ft/lbs, and called it a day.
All in all, this is probably the best looking mod I've done, and most noticeable - and the new wheel feels great. Even makes getting in and out easier! :-)
I'll probably stop at the stationary shop on the way home today and pick up a fine-line sharpie and color the "UP/DOWN" in black - think that's about all that's left to do!
The Following 7 Users Say Thank You to UK-C200 For This Useful Post:
Old 07-14-2009   #27 (permalink)
PropDr's Avatar
Vehicle: 2008 SLK 55 AMG 030
Other Toys: 06 HEMI Jeep, 06 BMW R1200 RT, 72 914
Donation Level 9
It is absolutely beautiful!
Now, how can the rest of us get a wheel like that without buying a 09 with the 030 option?
View PropDr's Photo Album PropDr is offline
Old 08-01-2009   #28 (permalink)
Vehicle: SLK 280 (2008 face lift)
Other Toys: gadgets!
Chats: 12
Originally Posted by HwoALanG View Post
i don't think it's possible in SLK...unless it's factory installed
I looked into this and did read about someone who completed this task successfully (I'll try and find the link), think all the connectors are there, just need to update the cars computer via STAR to set it up.
View True Romance's Photo Album True Romance is offline
Old 03-08-2010   #29 (permalink)
Vehicle: SLK 55 AMG (2005) - Tanzanite blue - Beige Nappa leither
Other Toys: MGA 1500 Coupé (1959) : MGB Roadster (1979) / Jaguar XJS 3,6L (1988)
Can you please give us more details about the wiring modifications needed to adapt the new steering wheel on a 2005 SLK 55 AMG (because on my car I do not have the same connectors ...).
Thanks a lot for you help on this matter.
View LPH59's Photo Album LPH59 is offline
Old 03-08-2010   #30 (permalink)
"Sergeant At Arms"
Vehicle: 2009 SLK 55 AMG
Other Toys: prev 02 SLK320,05 SLK 350
Donation Level 4
Chats: 32
lph59,
And finally, if you find something useful on your visit here today, please consider becoming a donating member or make a one-time donation to offset development and operating costs. Even $5 is welcome! Thanks!
Premium 1, Multimedia, Lighting packages
ClearBra Protective Film
OEM MB Plexiglass Windscreen
Tinted Clear Side Markers (SLK Store) w/LED Bulbs
LED License Plate and LED Parking Light Bulbs (SLK Store)
Kleyman 3rd Brake Light Flashing/Strobing Module V1.5 (Noregrets Custom Works)
View jbanks15's Photo Album jbanks15 is offline
Old 03-16-2010   #31 (permalink)
HwoALanG's Avatar
Vehicle: 2007 SLK 280
Donation Award
please let us know how to do this.
it will be my next mod list!
View HwoALanG's Photo Album HwoALanG is offline
Old 03-16-2010   #32 (permalink)
Finn-SLK350's Avatar
Vehicle: MB SLK 350 7G tronic 2004, smarttop, greenfilters
Other Toys: Seadoo gti
HwoALanG i haven't finished that mod yet but i lett you know, when my car programmin is done.
http://www.slkworld.com/ask-dansslk/...heel-r171.html
View Finn-SLK350's Photo Album Finn-SLK350 is offline
LinkBacks (?)
LinkBack to this Thread: http://www.slkworld.com/diy-section/3216-r171-diy-replace-steering-wheel-one-paddles.html
Posted By For Type Date
DIYs, Documents, Manuals, and FAQ links. Covers roof rattles, and other common issues - Benzworld.org - Mercedes Benz Discussion Forum This thread Refback 07-26-2007 09:33 AM
How to replace SLK steering wheel aquascape DIY Section 20 03-03-2009 09:32 PM
Replace Steering Wheel on 98 230 Mikeyming General Discussion 1 01-05-2009 10:40 PM
Would this steering wheel fit a R171 Trompetas del Infierno General Modifications R171 4 09-06-2008 01:24 PM
r171 steering wheel zxxn SLK R171 General Discussion 20 01-31-2008 01:22 PM
Swapping Steering wheel for one with paddles on aquascape Performance MODS for the R171 15 07-01-2007 02:38 AM
Powered by vBulletin Version 3.8.5
SLKWorld 2006-2010
Design by Fife Web Solutions
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136
