| | LinkBack (1) | Thread Tools |
#1 (permalink)
| Banned Join Date: Jan 2007
| Kicherer is offering an electronic cable, which is very easy to install under the throttle pedal and is eliminating the "sleeping second" of the throttle. A friend of mine has tested it yesterday and his summary: Good fun! You get the punch of your engine in each 10th of a second. http://www.kicherer.net/all/files/KI...9_93827413.pdf www.kicherer.net Questions to Mr. Florian Herre. |
Country: Thanks: 96
| I thought about making a custom one of these but decided it would make parking and what not more difficult because it basically tells the ECU you are applying more throttle than you actually are. In the end i made a change to the map to remove the lag in M1 and 2 and keep it in S so it could be used by the good lay around town without mounting curbs.
Country: Thanks: 96
| Yep Gero has it right the SLK uses a fully electronic throttle and to a certain extent an electronic brake system also in that brake pedal travel is detected at the master cylinder and from then on the computer takes over deciding how much pressure is to be used and what calipers to activate
| The Power Converter is working equal to the "Sport-Button" of a BMW Z4. I´ve got a special price from Kicherer. If somebody is interested in it, please send a PM. It is not working in a R170. |
| | #8 (permalink) |
Country: Thanks: 96
| Its a small amount of lag built into the first few % of pedal travel by MB the ECU uses this as a dead band allowing you to feather the throttle easy in traffic or when driving around town. Products like this sit on the line between the pedal and the ECU and if we say the first 5% of travel is "mushy" this product watches for anything in this range and tells the ECU your actually applying 6% throttle so it responds instantly this gives the feel of better response but also makes for very hard driving when using your car in traffic situations
| | #9 (permalink) |
| Senior SLK World Member Join Date: Sep 2006 Location: Vancouver
Vehicle: SLK350
| sounds like what i was concern about at the very begining when i bought my car... the lag at launching. I am interested but all depends on if it really works and how much thanks |
| | #10 (permalink) |
Country: Thanks: 96
| Not seen one yet that does not work and Gero's the one to ask about price
| | #11 (permalink) |
| It works really well and the price is about 300 Euro plus shipment. My friend testet the converter in a E500 (Vaeth 5.5) of his father and he did not get it back, because his 69 year old father was delighted. |
| | #12 (permalink) |
| Senior SLK World Member Join Date: Feb 2007 Location: Happy Valley
Vehicle: SLK55 Black Series
| So, what is the difference between this and Sprint Booster?
__________________ *** To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. Extras - Green Filter High Performance Air Filter, Supersprint Stainless Steel Cat. Back Exhaust System, Vaeth ECU Tuning, Vaeth Fuel Cooler, AMS Crank Pulley, Invo Autotec Alternator Pulley |
| | #14 (permalink) |
| | #15 (permalink) |
| Are you able to get it from the producer? Just a request: would you please tell me your prename. It´s much easier for me to talk to a person with a name. (sorry, but I am 46 years old...) |
| | #16 (permalink) |
| I don't know the manufacturer but it supposes made in Germany.
| | #17 (permalink) | |
| Founding Member Join Date: Jun 2006 Location: Northern NJ, USA
| | #19 (permalink) | |
| Founding Member Join Date: Jun 2006 Location: Austin, TX
Vehicle: SLK55 AMG
All it does is "fool" you into thinking you have a faster car, you really just now have a "touchier" (sp?) gas pedal. And if your're not careful your spouse will end up putting your "faster" car into the backend of the garage wall. | |
| | #20 (permalink) |
Vehicle: 2006,slk280,carlsson
Country: Thanks: 1
| could you put it on a switch so as to turn it off in slow traffic? I have personally been frustated by this lag many a times when coming out of corners etc |
LinkBacks (?)
LinkBack to this Thread: http://www.slkworld.com/performance-mods-r171/1964-power-converter.html | ||||
| SLK200,280,350,AMG,nos essais et commentaires - Cabriolets Essais Particuliers - FORUM Cabriolets - FORUM Automobiles mythiques et d'exc | This thread | Refback | 04-16-2008 12:06 PM | |
