Country: Thanks: 291
| The topic is simple, State your next performance modifications? I aiming for the Kleemann Headers as a birthday gift or earlier , Currently I am 1,000 bucks short of the headers and If possible the supersprint X pipe at the same time and for now these modifications are great combined with the Ecu upgrade and the drop in airfilters, I already have.With these mods I am estimating to reach 388hp-393hp depending if the SLK55 is 355hp or 360hp in stock form; I am not sure. Lets say 10hp from the ecu 3hp from the airfilters- euroteckmotorsports dyno sheet of a c55 20hp from Headers , so thats 33hp+355hp on the stock 5.5V8 = 388hp
Vehicle: ///AMG
Country: Thanks: 17
| You'll have to talk at the wheel mate. How will you know the gains if it's all estimated and sales talk. My car was 317tq and 299hp at the wheel. there was also another slk55 at the same dyno stock that got 303hp and 305TQ, so I was quite happy. Have you dyno'd you car yet. I'd do it prior to any mods. but if they vary that much in Tq i'd want to see before and after numbers to be happy with spending that much cash.
__________________ "I'm not a roman mum, I'm a kike, a yid, a heebie, a hook-nose, I'm kosher mum, I'm a Red Sea pedestrian, and proud of it!" Life of Brian To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. Last edited by easty; 11-17-2006 at 03:46 PM. |
| Founding Member Join Date: Jun 2006 Location: Sweden, West Coast
| Is it really possible to gain as much as 20hp when replacing headers? Has Mercedes done a poor job designing the original one? |
Vehicle: SLK55 2006
Country: Thanks: 24
| It's not a 'poor' design, it is a design that is the cheapest to manufacture and most adaptable for emissions controls. |
Country: Thanks: 96
| Like cyberdrakon says mate its not so much poor design as the stupid emissions rules that mean there have to be compromises across the board. Ideally your header would just be a massive tube going in a perfectly straight line from each cylinder to the outside of the car via the shortest possible route so like out the side or something.
| | #6 (permalink) | |
Country: Thanks: 135
Airfilter doesn't do much, there's stories that the filters will let in alot of dirt and will ruin your engine in the long run, it's a cheap mod, but I'm still hestitant and have not purchased one yet. Headers are expensive too and there has not been any dyno results that I've seen, all estimates, so it can be no gain up to 40hp? Who knows, it could loss hp too (not likely) so unless I see real results, I'm not going to consider it. I had a list of performance mod that I wanted to get but the cost of the product itself is close to a supercharger and noone has any dyno results, add installation and it's much cheaper going FI with much more torque and horses. After my research, my only option is to learn to love auto's and trade it in for a SLK55, both cheaper and proven performance.
| | #7 (permalink) | |
Country: Thanks: 54
| | #8 (permalink) | |
Vehicle: SLK55 2006
Country: Thanks: 24
power wise, i think all the SLK 55 needs is a good set of equal length headers, other than that, i'd like to lighten the car. my number 1 mod would be lightweight wheels, as they are the easiest to resell, adds to appearance AND performance, and the least invasive. | |
| | #9 (permalink) |
| For me, performance modifications to the engine should be limited to a pulley set for more boosts to not ruin my economy and hurt the warranty. Other things I'm thinking of are modifying the exhaust for better sounds. Other vice I'm in for weight reducing. I have already reduced 60lbs from the car and I'm only filling the gas tank half which is another 60lbs. Other possible things to do are a smaller lighter battery and a set of racing seats. This could reduce about 60-70lbs. Lighter car should give better handling, braking and acceleration and possible better MPG hopefully. |
| | #10 (permalink) | |
Airscarf is a must for me, I used it everyday commuting to work. That's not an option for me.
| | #11 (permalink) | |
Country: Thanks: 96
They start large and get smaller toward the point they join up just upstream of the exhaust. Thats would be a cool mod for the SLK save some weight on the exhaust system
| | #12 (permalink) |
| Senior SLK World Member Join Date: Sep 2006 Location: Istanbul
Vehicle: 05 SLK 200
Country: Thanks: 3
| I have lots of things in my mind, 2 months ago I changed my stock rims and bought 19" staggered AMG style IV replicas with M PS2 tires that cost me more than 2100 Euros My future modifications 1. 55 AMG rear lights (ordered) 2. AMG illuminated door sills (ordered) 3. Brabus style leds for doors (custom made) 4. Metallic door pins 5. Brabus roll-over bars 6. F1 style front bumper ( I have the AMG kit except front bumper) 7. Comand APS 8. Kleeman m271 kit 9. Turbocharger (still working on the idea) 10. LSD door kit 11. New interior leather (custom made) I wont sell the car till I see a better option, looks there wont be any for a long time . I am not hurrying but Turbo and kleeman kit is still a question in my mind... |
| | #13 (permalink) |
| SLK World Member Join Date: Jul 2006
| 1- the Kleemann supercharger kit for the 3.5L engine once they make it fit the SLK (allegedly the R350 kit was due out by end of 2006). 2- Wheels if I can ever find a set I like that the whole world isn't running already. 3- Breitling Chrono Avenger to upgrade the 'time telling' vs the little analog clock in the dash. |
| Performance parts | mazeka | SLK R171 General Discussion | 6 | 05-12-2008 12:47 AM |
| Modifications for copper colour | snowboardguy989 | General Modifications R170 | 0 | 04-23-2008 04:49 PM |
| SLK 32 AMG Engine Modifications | Wade | AMGs | 5 | 02-12-2008 08:57 PM |
| Performance | Genesis_SLK350 | Help and Support | 8 | 08-20-2007 09:12 PM |
| help and concern!!!!!performance and other | benzosnenzos | Performance MODS for the R171 | 23 | 02-23-2007 02:55 PM |
