Go Back   Mercedes SLK World Forum > Mercedes Benz R170 SLK Class Cars > Performance MODS for the R170
Performance MODS for the R170 How member make there SLK perform better
Windrestrictor
Old 09-03-2008   #1 (permalink)
SLK World Junior Member
Default r170 MAF relocate question
I have a quick question....I have a 1998 SLK 230. Ive read about the MAF relocation process, printed pictures and procedures....my question is, can PVC pipe be used to create a new, or possibly a small transition pipe rather than buying the 2002 version pipe?
Thanks, Glen
View Nine's Photo Album Nine is offline
Old 09-16-2008   #2 (permalink)
Heres what I did...I removed the MAF section and the solid plastic pipe. I moved the MAF up to the top, then reversed the solid plastic pipe so the long straight section runs vertically connecting to the lower metal pipe by the radiator.
To get the solid plastic pipe to fit into the bottom pipe I needed to shave the lip off the solid plastic pipe....after doing that it fit snuggly into the lower section. The lower section also has clamps that were used to hold the MAF section in place. I wanted to use those clams with the new setup, so I created two small L shaped metal brackets and used a hose clamp to attach them to the plastic pipe. I was then able to use the clamps, clamping them on to the L brackets.
I know this might be confusing, I appologise for that...but, I didnt understand why you couldnt use the parts that were there to make this change and if so, I didnt want to destroy the old parts just in case I needed or wanted to put it back the way it was.
It seems to be working fine....I dont know I notice too much of a change, but at least I know the MAF is where it should be.
Old 09-16-2008   #3 (permalink)
SLKman's Avatar
Donation Level 5
Do you have pictures of it you can post?
Thanks.
SLKman
View SLKman's Photo Album SLKman is offline
Old 09-16-2008   #4 (permalink)
pictures are worth 1000 words arent they....
I didnt take any but, that doesnt mean I cant go back and get some. I really didnt think anyone would be interested.
Ill probably need some help uploading them....
Old 09-16-2008   #5 (permalink)
SLKman's Avatar
Donation Level 5
That would be awesome!
I would like to see how to do this myself.
SLKman
Old 09-17-2008   #6 (permalink)
Ill get to work on the photos this weekend....
The Following User Says Thank You to Nine For This Useful Post:
Old 2 Weeks Ago   #7 (permalink)
DesignoSLK's Avatar
Vehicle: 2000 Designo SLK230
Donation Level 3
...update? ...pics??
Kevin
An American in Germany...
View DesignoSLK's Photo Album DesignoSLK is online now
maf sensor failure jbanks15 Ask DansSLK 5 07-29-2008 05:29 PM
Another MAF?! FishtailnZ SLK R171 General Discussion 10 07-24-2008 02:05 PM
Larger TB/MAF FishtailnZ Ask DansSLK 2 11-24-2007 08:36 PM
New MAF = New Car for me. SLKman SLK R170 General Discussion 13 08-31-2007 07:43 AM
New MAF FishtailnZ SLK R171 General Discussion 6 07-13-2007 09:20 PM
