| Performance MODS for the R170 How member make there SLK perform better |
| Elite SLK World Member Join Date: Jun 2006 Location: Melbourne Australia
Vehicle: slk230 1998
| I fitted the ASP pulley and LinH's MAF relocation kit. etc to my pre2000 SLK230 Really worth the $$$ Bazzle |
| Founding Member / Moderator ![]() Join Date: Jun 2006 Location: Rowlett, TX
Vehicle: 2002 C2DSLK32K
| Due that I don't have a 230 or even a 320....does the pulley kit actually make a large difference in your cars????
__________________ C2D 2002 SLK32K C2Design and Kleemann Modified 360.0 rwhp 349.8 rwtq Check My vBGarage for all Modifications |
| | #3 (permalink) | |
| SLK World Member Join Date: Sep 2006 Location: MIA / FL
Vehicle: SLK320
remember that the 230 is a 4 cylinder supercharged engine, so a pulley kit on the 230 is like adding a pulley kit on the 32'..... it increases Boost levels. So a 25-40HP gain is easily obtained. On the V6 320, when adding a pulley kit (i have it...evosport) all you are doing is "underdriving" the crank pulley, alternator & waterpump).... it shows 10hp gain in the dyno in the REALLY low rpms.... (1-3K), so is the kind of power gain that will make a little difference & after that you just get used it... | |
| SLK World Member Join Date: May 2007
Other Toys: '06 Exige, '65 Ghia
| How hard was it to do the upgrade from ASP? any additional costs besides what you get directly from them in the kit? I think the website said about $650 for the kit right? |
| SLK World Junior Member Join Date: Feb 2008
| Is there anyone out there who knows where I might find one of these pulley kits, all the posts are so old and they don't seem to be available anymore at the sites mentioned. (98 slk230 stock presently) |
| SLK World Member ![]() Join Date: Jun 2006 Location: Calgary, Alberta
Vehicle: 2005 SLK 55
Country: Thanks: 1
| Go to ASP Racing http://www.aspracing.com/frame.htm .. and then under 'street pulleys' select 'Imports'. Scroll down to Mercedes and you'll see the kit for a '98 - '00 C230 (includes pulley, MAS relocation pipe, plugs, fuel pressure regulator and belt). It should fit a 98 SLK. I had a similar kit on my '99 (from Linh) and it worked great. A little pricey @ $1,200! Kit #ASP331320 |
| | #9 (permalink) |
| Elite SLK World Member ![]() Join Date: May 2007 Location: Søgne
Vehicle: 96 SLK 230K
Country: Thanks: 14
| Hi Richard In short you put a smaller pulley on the blower to increase it's rpm. By doing that you increase the blowpressure which gives you more omph........ I have a kit on my '96 230K together with some other stuff, and it reads 240 PS/350NM on the dyno ![]()
| | #10 (permalink) |
| Awesome Thanks any idea what type of HP increase one would see with that kit? it doesn't list it on the site.. Either way if it's more than 5-10 it's worth it i figure (and it's an easyish mod to get me started) |
| | #12 (permalink) | ||
Country: Thanks: 14
and a pulley kit can't be used in your 350. But you can get a blower.... http://tinyurl.com/2stuxe ![]()
__________________ Gabus The Rolls Royce is the Mercedes amongst cars To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. | ||
| | #13 (permalink) | |
| Elite SLK World Member ![]() Join Date: Sep 2007 Location: Leeds, UK
Vehicle: 05 350
Country: Thanks: 16
So a "blower" is a fan to blow air into the intake of a normally aspirated engine? A pulley kit is a smaller pulley to increase the rpm of the bower? ![]() | |
| | #14 (permalink) |
Country: Thanks: 14
| Not exactly a fan..... It's an air compressor also called a blower or a supercharger http://tinyurl.com/2vwgsq By increasing the RPM's of the compressor you force more air into the motor. To get more RPM's you need a smaller pulley on the compressor or a bigger pulley on the crank, or a combo of those two. I've think I read somewhere that the compressor in the SLK 230 can take about 16000 RPM's By putting a compressor in the SLK320 AMG gained 136PS/140NM which became the 32AMG.......
| | #16 (permalink) |
| SLK World Junior Member Join Date: Mar 2008 Location: athens greece
Vehicle: slk200k 2001 R170
| I've heard of some stories about kompressors that blow up after using pulley kit since the kit increases kompressor's rpm .Does anybody know anything about it? I don't want to put the kit and after a month to pay for a new kompressor unit! Is there any guarantee from kit providers? |
| | #17 (permalink) | |
Country: Thanks: 14
http://tinyurl.com/2urj72
| Install of aftermarket radio and BT kit to replace Audio20 in the R171 SLK | ghostdunks | General Modifications R171 | ||
