Go Back   SLK World Forum > Mercedes Benz R170 SLK Class Cars > Performance MODS for the R170
Performance MODS for the R170 How member make there SLK perform better
Visit Autogeek.net
Old 06-27-2006   #1 (permalink)
bazzle's Avatar
Vehicle: slk230 1998
Default Pulley Kit
I fitted the ASP pulley and LinH's MAF relocation kit. etc to my pre2000 SLK230
Really worth the $$$
Bazzle
View bazzle's Photo Album bazzle is offline   http://www.slkworld.com/Boss Key
Old 06-28-2006   #2 (permalink)
Founding Member / Moderator
tungster's Avatar
Vehicle: 2002 C2DSLK32K
Send a message via AIM to tungster Send a message via Yahoo to tungster
Due that I don't have a 230 or even a 320....does the pulley kit actually make a large difference in your cars????
C2D 2002 SLK32K
C2Design and Kleemann Modified
360.0 rwhp 349.8 rwtq
Check My vBGarage for all Modifications
View tungster's Photo Album tungster is offline   Boss Key
Old 01-21-2007   #3 (permalink)
OJC
Vehicle: SLK320
Other Toys: too many to list.
Send a message via MSN to OJC
remember that the 230 is a 4 cylinder supercharged engine, so a pulley kit on the 230 is like adding a pulley kit on the 32'..... it increases Boost levels. So a 25-40HP gain is easily obtained. On the V6 320, when adding a pulley kit (i have it...evosport) all you are doing is "underdriving" the crank pulley, alternator & waterpump).... it shows 10hp gain in the dyno in the REALLY low rpms.... (1-3K), so is the kind of power gain that will make a little difference & after that you just get used it...
View OJC's Photo Album OJC is offline   Boss Key
Old 05-31-2007   #4 (permalink)
Other Toys: '06 Exige, '65 Ghia
Default How hard?
How hard was it to do the upgrade from ASP? any additional costs besides what you get directly from them in the kit? I think the website said about $650 for the kit right?
View Bleu's Photo Album Bleu is offline   Boss Key
Old 08-12-2007   #5 (permalink)
myslk230's Avatar
Vehicle: 1998 slk 230 kompressor
Other Toys: 98 jaguar xj8
how many differnt kits are there?
View myslk230's Photo Album myslk230 is offline   Boss Key
Old 02-21-2008   #6 (permalink)
SLK World Junior Member
Default Can't find any of these kits
Is there anyone out there who knows where I might find one of these pulley kits, all the posts are so old and they don't seem to be available anymore at the sites mentioned.
(98 slk230 stock presently)
View maliqua's Photo Album maliqua is offline   Boss Key
Old 02-21-2008   #7 (permalink)
Vehicle: 2005 SLK 55
Go to ASP Racing
http://www.aspracing.com/frame.htm
.. and then under 'street pulleys' select 'Imports'. Scroll down to Mercedes and you'll see the kit for a '98 - '00 C230 (includes pulley, MAS relocation pipe, plugs, fuel pressure regulator and belt). It should fit a 98 SLK. I had a similar kit on my '99 (from Linh) and it worked great. A little pricey @ $1,200! Kit #ASP331320
View Driller's Photo Album Driller is offline   Boss Key
Old 02-22-2008   #8 (permalink)
Vehicle: 05 350
Apologies for my ignorance... what is a pulley kit ... and what is it meant to do?
View richard_leeds's Photo Album richard_leeds is offline   Boss Key
Old 02-22-2008   #9 (permalink)
Gabus's Avatar
Vehicle: 96 SLK 230K
Other Toys: Volvo L3314N
Hi Richard
In short you put a smaller pulley on the blower to increase it's rpm. By doing that you increase the blowpressure which gives you more omph........
I have a kit on my '96 230K together with some other stuff, and it reads 240 PS/350NM on the dyno
Gabus
View Gabus's Photo Album Gabus is offline   Boss Key
Old 02-22-2008   #10 (permalink)
Default Thanks!
Awesome Thanks
any idea what type of HP increase one would see with that kit? it doesn't list it on the site..
Either way if it's more than 5-10 it's worth it i figure (and it's an easyish mod to get me started)
Old 02-22-2008   #11 (permalink)
Vehicle: 05 350
Originally Posted by Gabus View Post
Hi Richard
aha, so only works on turbo/supercharge/overcharge etc? Not my normally aspirated 350?
Old 02-22-2008   #12 (permalink)
Gabus's Avatar
Originally Posted by maliqua View Post
Awesome Thanks
You would gain over 10 PS easy......... But when you compress air you get heat, so you should also consider a bigger cooler..... Together with a ECU mod, K&N filter I've gained 47 PS. ( or not me, but the last owner of my car)
Turbo's don'thave a pulley... and a pulley kit can't be used in your 350.
But you can get a blower.... http://tinyurl.com/2stuxe
Gabus
Old 02-26-2008   #13 (permalink)
Vehicle: 05 350
Turbo's don'thave a pulley... and a pulley kit can't be used in your 350. But you can get a blower....
oops .. I'm showing my ignorance, that's what I thought you meant by "blower".
So a "blower" is a fan to blow air into the intake of a normally aspirated engine?
A pulley kit is a smaller pulley to increase the rpm of the bower?
Old 02-26-2008   #14 (permalink)
Gabus's Avatar
Not exactly a fan..... It's an air compressor also called a blower or a supercharger
http://tinyurl.com/2vwgsq
By increasing the RPM's of the compressor you force more air into the motor. To get more RPM's you need a smaller pulley on the compressor or a bigger pulley on the crank, or a combo of those two. I've think I read somewhere that the compressor in the SLK 230 can take about 16000 RPM's
By putting a compressor in the SLK320 AMG gained 136PS/140NM which became the 32AMG.......
Gabus
Old 03-02-2008   #15 (permalink)
Vehicle: SLK 200 K
Other Toys: MRV6 SC
Sorry to but in guys, but can this kit be used on the 200K, if not can anybody recommend one?
View jasper's Photo Album jasper is offline   Boss Key
Old 03-05-2008   #16 (permalink)
Vehicle: slk200k 2001 R170
Other Toys: rib550 mercury115
Default pulley kit.What happens to the kompressor endurance?
I've heard of some stories about kompressors that blow up after using pulley kit since the kit increases kompressor's rpm .
Does anybody know anything about it? I don't want to put the kit and after a month to pay for a new kompressor unit!
Is there any guarantee from kit providers?
View yannismd's Photo Album yannismd is offline   Boss Key
Old 03-06-2008   #17 (permalink)
Gabus's Avatar
http://tinyurl.com/2urj72
Gabus
Old 03-12-2008   #18 (permalink)
simple upgrade but more hp that a pulley kit...
The best Truck Parts as I know.
View jahorld's Photo Album jahorld is offline   Boss Key
Old 05-05-2008   #19 (permalink)
Silver230SLKRT's Avatar
is there just a way to buy a pulley? I got a new belt and all the other stuff. I dont wana spend over 100 bc this is my second car (daily driver).
View Silver230SLKRT's Photo Album Silver230SLKRT is offline   Boss Key
Install of aftermarket radio and BT kit to replace Audio20 in the R171 SLK ghostdunks General Modifications R171 32 4 Weeks Ago 09:00 PM
Idler pulley, how many are there? etyu
