Pulley Kit - Page 2 - Mercedes Benz SLK Forum
#21 Old 07-07-2009
Vehicle: 1999 SLK230 R170 / MT-AMG
Other Toys: Honda CR-V, computers, firearms, gadgets, wicked girlfriend
Chats: 3
Send a message via Yahoo to glue_ru
Question, does changing the K pulley put too much stress on the engine parts?
Does it require anything more, cooling, fuel mixtures, etc ?
thanks
glue_ru is offline
#22 Old 07-08-2009
Vehicle: 2002 SLK230 black; ASP crank pulley; LED taillights; Black HID projector headlights
No.
No.
Check the crank seal (~$20) while you are at it. Replace if necessary.
Mantist is offline
#23 Old 07-28-2009
is there anywhere i could get this kit in the uk?
mattyjones is offline
#24 Old 08-27-2009
JFR
JFR's Avatar
Vehicle: SLK 320 BVA red amber + SLK 55 AMG red thulite
Well done Gabus, you explained it all, and you have a brillant car
just to think between 320 and 32AMG, they had to reinforce several parts inside the engine
and when you get this power, you need to work on the breaks and wheels, shock absorbers . . .
JFR is offline
#25 Old 12-18-2009
Vehicle: 2002/3 SLK 230 Black
Originally Posted by Gabus View Post
Not exactly a fan..... It's an air compressor also called a blower or a supercharger
http://tinyurl.com/2vwgsq
By increasing the RPM's of the compressor you force more air into the motor. To get more RPM's you need a smaller pulley on the compressor or a bigger pulley on the crank, or a combo of those two. I've think I read somewhere that the compressor in the SLK 230 can take about 16000 RPM's
By putting a compressor in the SLK320 AMG gained 136PS/140NM which became the 32AMG.......
The ASP pulley for a 230 is a larger diameter pulley then the standard pully. There is no crank pulley in the kit, just one hugh pulley for the supercharger. The kit is designed to take the Supercharger to 12000 RPM giving around 8.5 psi boost. 12000 RPM is well within the design specs of the eaton supercharger in your car.
The pulley also weights more then the original pulley which means when you take your foot off the accelerator, the car does not loose RPM quickly. If you fit an alloy pulley that is lighter then standard, then you end up with a car that will rev quicker, but will also loose RPM very quickly when your lift your foot of the accelerator, which makes the car very hard to drive. This does not happen with the ASP pulley as it is heavier then standard and when you take your foot of the accelerator the car just keep going at the same RPM and there is no sharpe drop in RPM.
I have the ASP pully and love it, and I have had it for over 3 years now. Before I got the pulley, I was always having to press the accelerator to the floor to get the car moving (I have a 2003 model 230) but after the pulley was installed, I almost never need to do this. The increase in power is hugh.
The ASP pulley is done on exchange. It's $US350 + $US300 deposit, which ASP refund to you when they recieve your standard pulley in the post.
This is the only mod I have seen that will give you a hugh increase in HP for a few hundred dollars. you would have to spend many thousands of dollars to get the same result on a non-supercharged car, like the 320.
My car easily leaves a 320 behind, I even took off the SLK230 bagdes so people do not think I am driving a slow SLK230. Let face it a standard SLK230 is a slow car,otherwise so many people would not be interested in modifying it.
Luc
luc256 is offline
The Following User Says Thank You to luc256 For This Useful Post:
#26 Old 01-24-2010
98slk230's Avatar
Vehicle: Silver 98 SLK230 / Salsa Red/Black Interior
Other Toys: Nothing as of now but hoping to add to the collection. Look for updates hopefully.
Send a message via AIM to 98slk230
Originally Posted by Driller View Post
Go to ASP Racing
http://www.aspracing.com/frame.htm
.. and then under 'street pulleys' select 'Imports'. Scroll down to Mercedes and you'll see the kit for a '98 - '00 C230 (includes pulley, MAS relocation pipe, plugs, fuel pressure regulator and belt). It should fit a 98 SLK. I had a similar kit on my '99 (from Linh) and it worked great. A little pricey @ $1,200! Kit #ASP331320
I have to apologize but I am not familiar with the Ps/NM language. How much HP do you think can be picked up by one of these kits? I went to the site and seems like the company's link is not up anymore to the kit's but they are able to be contacted so I am sure they can still get the kits.
Thank You.
98slk230 is offline
#27 Old 01-24-2010
Vehicle: '01 SLK230
Other Toys: '97 328IS
Originally Posted by luc256 View Post
The ASP pulley for a 230 is a larger diameter pulley then the standard pully. There is no crank pulley in the kit, just one hugh pulley for the supercharger. The kit is designed to take the Supercharger to 12000 RPM giving around 8.5 psi boost. 12000 RPM is well within the design specs of the eaton supercharger in your car....
Are you sure about this??? A larger SC diameter pulley will slow down the SC and make you lose power, a smaller diameter SC pulley will increase the rpms on the SC and increase power...
sikdogg is offline
The Following User Says Thank You to sikdogg For This Useful Post:
#28 Old 01-25-2010
Vehicle: '01 SLK230
Ok, according to ASP's website you are buying a larger CRANK PULLEY not a larger SC pulley. This makes more sense... a larger crank pulley and/or a smaller SC pulley will increase SC rpms. A larger SC pulley will underdrive or slow down the rpms on the SC.
sikdogg is offline
#29 Old 01-27-2010
Smile
Hello, i am new to this forum and just with this first search, you guys have answered every question i had concerning the ASP pulley. I just wanna thank you guys for all the detailed information.
W202_00 is offline
#30 Old 01-27-2010
Other Toys: 1986 560SL, 2012 VW Tiguan, 2008 GMC Sierra slt
Quoted: 67 Post(s)
Are they still charging $650 with a $300 credit when you send in the old pulley??
#31 Old 02-05-2010
mavrick77's Avatar
Vehicle: 1999 SLK 230 Kompressor
Ok wow, I see a bunch of people who have no clue how a supercharger even works....for thoose of you, I would highly recomend educating yourself with books before you even approach this mod.
the way a blower, i.e. supercharger, works in simple terms.
-the supercharger is connected to your intake to the motor...the supercharger also has a pulley connected to the crank pulley of the car...
the faster the supercharger pulley spins, the more air the turbines force into the motor. you can do this one of three ways....
1) a BIGGER crank pulley will spin the supercharger pulley faster
2) a smller supercharger pulley will spin the supercharger faster
3) a bigger crank pulley AND a smaller crank pulley will really spin the supercharger fastest.
now the down side...when you go very small on the supercharger pulley you tend to get belt slippage because the belt does not have alot of surface area to grab onto. people have gotten around this using extra belt tensioners in their cars.
second problem....the more air you force into the motor, the more gas your motor needs and the more heat is produced...
1) larger fuel injectors or a new map is needed on your computer
2) if going super high in boost you will need to get forged pistons and rods to handle the exta stress put on the motor.
3) in order to handle the extra heat from more compressed air, you will need a larger intercooler, or water methonal cooler as well.
***with the ASP kit, you are only adding a few PSI to the motor and the stock internals should be able to handle this without upgrading the internals, however a new fuel map will be needed, i.e. they provide this I believe.
*****GENERAL RULE OF THUMB for supercharging, for every 6psi added to the motor via supercharger you will gain roughly 50% more horsepower... for example, if your car is making 150HP, if you added 6psi to that motor, you would now be making 225HP.
hope this helps some of you clear things up..
ignore my spelling, i was typing this very quickly
Neilr171 likes this.
mavrick77 is offline
The Following User Says Thank You to mavrick77 For This Useful Post:
#32 Old 02-06-2010
Vehicle: '01 SLK230
Was this comment addressed to me?? I believe i know more about forced induction than most people on this board or anyone who's only read books, including you. I've installed supercharger kits (and turbos) on Integras and Civics and my current BMW where i tuned it myself using an AEM FIC piggyback. I am in the process of buying parts for my next project... to turbo my BMW using a T4 GT35 with power goals of 500+ whp. I have also designed and fabricated a custom supercharger kit on my 86 Jeep CJ7 (using an Eaton M90) and tuned it with Megasquirt.
This is what i stated... and the opposite is that if a larger pulley is installed on the supercharger, it will spin slower and lose power.
sikdogg is offline
#33 Old 03-02-2010
mavrick77's Avatar
no no...was not towards you. After I read it did sound kinda bitchy...but was more addressed to the people who are thinking about messing with their supercharger and really don't even know how it works... its a good way to blow up a mercedes motor. but no, not addressed towards you, or really anyone directly.
#34 Old 03-02-2010
Vehicle: 2003 SLK 230
Chats: 2
I have an 03 230. will that pulley work for this year or do you know if they offer one for this year
elijahjm101 is offline
#35 Old 03-02-2010
Chats: 2
Anyone have any idea how to get more power? Did the Remus exhaust with resonators yanked and cat will be gone this weekend. Removed factory airbox and made my own CAI with a K&N cone. And am going to get this ASP pulley. End of the road?! What about the AEM FIC Silk talked about. Its universal. Anyone tried it on their SLK 230? Need help. I want to max out this little engine that could.
#36 Old 09-24-2014
Vehicle: '02 SLK32 AMG in "naked" MB color that was used for getting a car's weight to be under a HIGH number
Other Toys: bike as in road bike, 13lbs. A beautiful machine!
Quoted: 45 Post(s)
Four years later and a reliable source for a pulley that will hold up and be readily available has not happened, what's up with that? There certainly is a market for these pulleys. So nothing from another application fits. A pulley kit would likely be needed to obtain the correct belt wrap. An SC pulley that is over $500. Does not fit the critteria. Well?
Sweet04 is offline
Human Verification
exhaust and pulley kit sonic02stang Where to get R170 SLK Items 12 09-24-2011 05:02 PM
2005 SLK350 and up HID H7 kit upgrade kit for sale. jkatt SLK Parts For Sale 2 03-16-2009 11:18 AM
expression SLK-R kit or P kit for my 06 350? mrl0n3ly714 SLK R171 General Discussion 13 11-11-2008 11:47 PM
pulley,exhaust myslk230 Where to get R170 SLK Items 2 03-07-2007 03:10 AM
supercharger pulley myslk230 Where to get R170 SLK Items 2 11-10-2006 02:12 PM
