Go Back   Mercedes SLK World Forum > General Discussion about Mercedes Benz SLK's > Off Topic
Off Topic any thing but SLK talk. Please Note that religion and politics are not allowed....
Welcome to SLKWorld
Old 07-17-2008   #1 (permalink)
Vehicle: slk55
Default California Do's & Dont's
I ordered some clear side markers for my slk55 and was wondering on its legality in California (what else did you expect given my profession). Read some secondary sources which said yes, others no. Found this site and thought it might be interesting for those in California. Some are obvious no no's (like tinted front windows, front license plate, etc). Thought I'd share.
http://www.chp.ca.gov/community/streetlegal.html
View hairypet55's Photo Album hairypet55 is offline
The Following 4 Users Say Thank You to hairypet55 For This Useful Post:
Old 07-17-2008   #2 (permalink)
Vehicle: slk55
CA vehicle code if anyone is interested for side markers. 25106 & 24003
http://www.dmv.ca.gov/pubs/vctop/d12/vc25106.htm
http://www.dmv.ca.gov/pubs/vctop/d12/vc24003.htm
Old 07-17-2008   #3 (permalink)
Vehicle: 2006 SLK 280 w. 6M
I don't see anything in the code that prohibits the housing of the side lamps in the front to be clear, as long as the lamps themselves emit an amber light.
View Ikarus's Photo Album Ikarus is offline
Old 07-17-2008   #4 (permalink)
Donation Level 6
Yeah, I'm reading it the same way. I also like the "if present" bit - I'd assume that means that removing them completely would be legal!
View UK-C200's Photo Album UK-C200 is online now
Old 07-17-2008   #5 (permalink)
That's how I "interpret" it also, the housing can be clear as long as the lamp or light bulb emits an amber light (in my case, more yellow than orange). I had this set-up in the prior 280 for about 18 months and now 12 months on the 55 and not one instance of the CHP or other law enforcement agency questioning the side markers.
BTW, hairypet55, are you free this Saturday afternoon/evening? http://www.slkworld.com/mb-events/67...drive-pch.html
Old 07-17-2008   #6 (permalink)
Vehicle: slk55
I read the vehicle code and here's my take. Not sure if it’s correct, but in short, if your vehicle came with side makers, then those side markers have to be amber. The CVC uses the term amber side "lamp." I haven't looked thought the entire CVC to look for a clear definition of "lamp" but if you take "lamp" to mean bulb, then you should be able to have clear markers so long as the blub (ie lamp) inside is amber or emits an amber light. However, I don't think this is the correct interpretation as other sections do use the terms "bulb" and even VC 25106 mentions the "light source" being separate from the lamp. So if the drafters meant an amber bulb they would likely have used the term bulb and not lamp. Poorly drafted, yes, but my guess is that lamp means the entire lighting unit or device (as used in VC 24003), which would likely mean the bulb and the lens/maker need to the amber. I think practically so long as the bulb is amber you’re likely OK but I think the CVC is vague enough that an officer having a bad day and nothing else to do can likely give you a ticket….........
Old 07-17-2008   #7 (permalink)
Vehicle: SLK32 AMG
The way I look at it, clear side marker covers are allowable in CA as long as it meets the amber lamp specification. BMW, AUDI, VW, etc. sell them new and used. A lamp is the illuminating source. including the amplifier (reflector).
The BMW side marker cover (clear) is not faceted to redirect and amplify the light.
Old 07-17-2008   #8 (permalink)
The OEM sidemarker is amber/orange in color but the light bulb underneath it is not quite amber, closer to the color temp of the non-xenon OEM headlamps.
hairypet55, can you make it this Saturday?
Old 07-17-2008   #9 (permalink)
Vehicle: slk55
Thanks for the invite etyu...i'm checking for conflicts with the boss (G for sat. The drive sounds great.
Old 07-17-2008   #10 (permalink)
Vehicle: slk55
Sorry, not sure how the happy face got into my post??????
Old 07-17-2008   #11 (permalink)
Vehicle: '07 SLK55 AMG
Other Toys: Honda motorcycle
I strongly doubt you're going to be pulled over for the amber side markers as long as the bulbs are amber. The officer is going to have to *know* that it didn't come that way from the factory- a challenge as more cars are out there with clear lenses for the back and sides now.
You're going to have to be causing a lot more trouble (really speeding, burning tires etc) to get written up for it. If it comes down to them writing you up for just the lenses *assuming* it could be illegal, consider yourself lucky.
They probably did it just to get you for something as they couldn't get you for what they really wanted.
/my car doesn't have the front plate or bracket installed
Old 07-17-2008   #12 (permalink)
Click it or Ticket!
SLKCop's Avatar
Hi there, Hairypet55. We had this discussion in another thread a few weeks ago. Refer to this link: http://www.slkworld.com/general-disc...html#post74437
Mike
2002 Black SLK-230
View SLKCop's Photo Album SLKCop is offline
The Following User Says Thank You to SLKCop For This Useful Post:
Old 07-17-2008   #13 (permalink)
Click it or Ticket!
SLKCop's Avatar
According to section 25106(a), the lamps are not required to be amber. The statute indicates lighted white or amber. So even clear lenses with white bulbs/lamps would be legal.
Mike
2002 Black SLK-230
Old 07-17-2008   #14 (permalink)
-1-
Don
-1-'s Avatar
Live on the edge, go with the clear side marker lights. I feel confident with the amber emitting bulbs, you'll be in compliance.
THE MON55TER ON THE BLOCK
Old 07-17-2008   #15 (permalink)
Vehicle: slk55
Living on the edge.....I might even stoping taking my vitamins....HAHA.
Old 07-17-2008   #16 (permalink)
I'm afraid not. It gives you the choice for the cowl or fender lamps in the front. For the ones "on the side near the front", 25106(a) clearly says they must be amber (if present).
Old 07-18-2008   #17 (permalink)
Click it or Ticket!
SLKCop's Avatar
Ikarus, love ya man, but I have to disagree with you on this one. 25106(a) only states that a vehicle may not be equipped with more than one amber light.
The intent, I believe, of that statute is to prohibit multiple sources of amber lights on the front sides of vehicles. You can have white or amber, but if you have amber, you cannot have more than one.
Has anyone checked California case law for clarification on this? We can all interpret it all day long by reading and analyzing the statute, but unless a judge has made a ruling on it, it's still up for grabs [so to speak].
Mike
2002 Black SLK-230
Old 07-18-2008   #18 (permalink)
I've been driving around with them for a long time now it was the first thing I did to my car. Being a younger driver I have been pulled over many times for exhaust and tints but nothing has ever been said about the reflectors or how low the car is funny enough. Even when I would get the fix it tickets signed off on and they would walk around the car it was never even brought up! I saw go with it worse comes to worse you get a $10 ticket and you swap back.
View IIIMBPIII's Photo Album IIIMBPIII is offline
The Following User Says Thank You to IIIMBPIII For This Useful Post:
Old 07-18-2008   #19 (permalink)
The intent, I believe, of that statute is to prohibit multiple sources of amber lights on the front sides of vehicles. You can have white or amber...
How can they be white? It seems 25106(b) is pretty clear about this not being permitted:
(b) Lamps meeting requirements established by the department for side-marker or combination clearance and side-marker lamps may be installed on the sides of vehicles at any location, but any lamp installed within 24 inches of the rear of the vehicle shall be red, and any lamp installed at any other location shall be amber.
Old 07-18-2008   #20 (permalink)
Donation Level 6
Louisiana law is ever more vague, but I've just had my car pass state inspection with clear sides and amber (sliver) bulbs. Guy didn't even notice as nearly as I could tell - but he was more interested in seeing the top go up and down..
I've passed loads of cops in Texas and Louisiana, and so far not had any problems. I suspect as others have said that this might be something that a cop would add to a ticket if he did you for something else. Then again, I'm a bit past being able to look young, so that may help as well....
