| SLK World Member Join Date: Aug 2008 Location: Abu Dhabi, United Arab Emirates (UAE)
Vehicle: '05 SLK350
| Hi everyone, I am planning to upgrade wheels on my car to 19" (looking at Oz Racing Michelangelo II PL's). Now I am sure I can fit 19 x 8.5" front (with 235/35 tires) and I can fit 19 x 9.5" rears. Now the question is what tire at the rear. The company supplying me the wheels have recommended 255/30. The tire I want is the Michelin Pilot Sports. However Michelin Europe tell us that they have discontinued this size. I really want to stick with the Michelin's, I have had them in the past on other rides and other threads in the forum have all had positive comments for them. Is it possible to fit 265/30's? Or would 255/35's be too big and run the risk or arch rubbing? I have fitted a H&R Performance Coilover kit and the car is sitting now 1.2" lower front and rear. All help is really appreciated! Cheers, Dan. |
| Sponsored Links | |
| Senior SLK World Member Join Date: Nov 2006 Location: Bremen
Vehicle: 2006 SLK 350 AMG Package
Country: Thanks: 10
| Hi Dan, for the 19'' I would only take these combinations: front: 225/35 with rear: 255/30 or front: 235/35 with rear 265/30. Others have a different circumference at the front and rear. At least these combinations are required by German authorities.
__________________ To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. |
| SLK World Member Join Date: Feb 2007 Location: Baytown, Texas
Vehicle: SLK55
Country: Thanks: 3
| I put 19 X 9.5 w/35 mm offset on the rears and 19 X 8 w 32 mm offset on the front. TSW Volcanoes. I ran PS Cups 235 / 35 on the front and 265 / 30 on the rear. 2 problems. Under extremely hard cornering, the fronts would rub the bottom of the spring lower mount. Also, the car seems to be much more unsetteled over uneven pavement. Neither was a problem on the street but I couldn't track the car with this combo. I now run 225 & 255 Goodyear Eagle F1 Asymetrics for my street tires and am much more satisfied with them. I run Hoosier 18" R6s on the track. |
Vehicle: '05 SLK350
| Thanks for the feedback Bernd and RB. I don't plan to track the car with wheels this big so some of the concerns you pointed out RB I hope to avoid. From the general summary though looks as though if I stick to 255/30's on the rear I'll be safe, just a bit unsure as to 235/35's on the front.... Thanks for the advice! Dan. |
| Sponsored Links | |
| What tires should I buy? | mtiede | Help and Support | 40 | 07-24-2008 11:39 AM |
| Help with Tires | noregret4life | SLK R171 General Discussion | 43 | 03-31-2008 11:09 AM |
| tires (again) | V8SLK | General Discussion | 0 | 02-20-2007 04:15 PM |
| Tires | SoCalSLK55 | AMGs | 12 | 02-20-2007 02:56 PM |
| winter tires | bkyc | SLK R171 General Discussion | 6 | 10-11-2006 11:18 PM |
