Go Back   SLK World Forum > General Discussion about Mercedes Benz SLK's > Help and Support
Old 07-06-2008   #1 (permalink)
Vehicle: SLK280
Default what is front bumper made of?
anyone know what type of material the front bumper is made of? eg. is it fibreglass, or just some type of plastic?
reason why i ask is that I managed(stupidly) to drive too far forward while parking in a spot, and managed hit a concrete block and cracked the front bumper a bit. Seeing as its on the underside, I'm not too worried about it, but just want to do a quick DIY repair on it to make sure the crack doesn't get worse. Will probably replace the bumper later, but for now, just need to make sure it doesn't get worse. If anyone has any ideas or products they recommend, would appreciate it as well
oh, its for a 2005 SLK280
View ghostdunks's Photo Album ghostdunks is offline   http://www.slkworld.com/Boss Key
Old 07-06-2008   #2 (permalink)
Sorry to hear Ghostdunks. For sure it's not fiberglass, it's plastic. Most body shops may be able to mend the crack from the inside surface.
View etyu's Photo Album etyu is online now   Boss Key
Old 07-06-2008   #3 (permalink)
bobsquad7's Avatar
Vehicle: slk350
Other Toys: R1200GS, Freightliner Class-8-RV conversion
The bumper is an injection molded semi-rigid plastic.
Go to your local body shop-paint supply store & get a product called Duramix 4040 (aprox $35.00) and a roll of reinforcing mesh ($5.00). (O'Reily's Auto Parts carries it in their paint dept) Also get a dual tube applicator gun ($ ?) - like a caulk gun but has twin plungers. (You may be able to borrow one of these from the store - or a paint & body shop)
Prep the inside of the cover in the cracked/torn area with an 80 grit sanding disc. Rough-up an area a couple inches either side of the crack.
Cut & apply a piece or two of mesh to the area & spread an even thin layer of the Duramix over the mesh. For maximum strength, apply 3 or 4 additional layers of mesh & Dura.
This stuff set's up in a couple of minutes (or less - in warm weather) so get everything layed out & be prepared to work fast.
Also, wear Nitrile gloves or plan on "wearing" the Duramix on your fingers for a week until it wears off. Laquer thinner won't even desolve it once it sets.
View bobsquad7's Photo Album bobsquad7 is offline   Boss Key
The Following 5 Users Say Thank You to bobsquad7 For This Useful Post:
Old 07-07-2008   #4 (permalink)
SLKCop's Avatar
Great description.....sounds like you've done that before!
Mike
2002 Black SLK-230
View SLKCop's Photo Album SLKCop is offline   Boss Key
Old 07-07-2008   #5 (permalink)
Vehicle: SLK280
thanks for the suggestions guys, I might give it a go later. I've heard good things about the Duramix stuff as well(made by 3M I believe) so that sounds like the right thing to use.
Might as well learn to do it myself, I can see myself doing this more than once Now, got to figure out an easy way of taking the bumper off so I can fix it properly.
View ghostdunks's Photo Album ghostdunks is offline   Boss Key
Old 07-07-2008   #6 (permalink)
IIRC, someone in Canada was able to remove the front bumpers while putting in an aftermarket HID. It was stevenlau.
Old 07-08-2008   #7 (permalink)
Vehicle: SLK280
yeah I remember his post as well, I used it a fair bit while putting in my own aftermarket HIDs
Old 07-08-2008   #8 (permalink)
Where exactly is the crack on the front bumper? Is it on the rear-most part of that part of the bumper that tucks underneath the car? If so, this is a rather common problem. I got a very small crack there myself, in the same way. Fortunately, to see it, one had to lay down on the pavement and crawl under the front, face up. I didn't want the crack spreading further, so I cut a small, short strip of sheet aluminum and secured it to the back (inside) surface of the area of the crack with JB Weld. When this was dry, I masked the area while leaving only about 1'4" of area around the crack exposed. I sprayed the crack with some aerosol touch-up paint a local auto paint supplier mixes and sells, and polished it down with a fine polish when dry. If the crack on your bumper is in this obscure area, this may work for you.
The SLK -- What the SL was supposed to be.
View Dolebludger's Photo Album Dolebludger is offline   Boss Key
Old 07-22-2008   #9 (permalink)
Vehicle: SLK280
Yeah, the crack "starts" where it tucks under the car but it ends somewhat high. Its not that noticeable but like I said, just want to stop it from getting worse.
Update on this. Having a lot of trouble sourcing the 3M Duramix(renamed to Automix I believe) in Australia, from automotive stores we have around here(such as Autobarn, Supacheap Auto, etc...). They have stuff like "Plastic Weld" or "JB Weld" instead. Going to try and find some specialised paint & panel beating supply shop and see if they supply it instead,
Failing that, I was thinking of the following. Use either "Plastic Weld" or "JB Weld" to glue the crack together, then on the hidden side of the bumper, reinforce the repair by using a fibreglass repair kit to add some reinforcement behind the crack. Then sand the repaired crack on the front side, and just paint it over. Anyone see any problems with that approach?
I've never worked with fibreglass before, so not sure if it'll adhere to the back of the bumper, etc...how strong it'll be, etc..
Old 07-22-2008   #10 (permalink)
bobsquad7's Avatar
Vehicle: slk350
I don't know how compatible fiberglass cloth/resin or JB Weld would be with the bumper cover material.
If you can't find Duramix at a pro body shop supply, try sending 3M an email requesting a source in Au.
The "mesh" that most pro body shops use is available from home builder or lumber stores. It's also used to reinforce sheet rock (wall board) joints, . . .comes in a roll of aprox 100 feet and costs around $5.00 US.
I don't believe fiberglass resin or JB weld would be flexable enough - not as pliable as the bumper.
amg front bumper iceborne General Modifications R171 4 04-29-2008 03:14 PM
WTT: White SLK55 front bumper+fogs for SLK280/350 front bumper + fogs + cash slktyperice Where to get R171 SLK Items 14 02-12-2008 08:04 PM
Kleeman front splitter for AMG front bumper Vin Where to get R171 SLK Items 20 10-02-2007 12:17 AM
front bumper 2007 no-way Where to get R171 SLK Items 6 09-10-2007 02:41 AM
AMG front bumper project diclehana Ask DansSLK 5 03-28-2007 07:16 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80
