| SLK World Member Join Date: Oct 2006 Location: Washington DC
Vehicle: 2007 SLK350
Country: Thanks: 1
| hey guys, everytime i post something here, I always get a quick response.. ![]() so here goes... when I turn on the fan inside the car, I hear a rattling sound, as if the fan is just getting old and out of alignment or something. thoughts? maybe i should get it checked out at the dealership's service center. thanks, ~shahedc . |
| Sponsored Links | |
| Senior SLK World Member Join Date: Oct 2007 Location: Rochester,NH
Vehicle: 2002 slk230K 2008 Honda CRV
| Not sure what model you have but you may want to pull the cabin filter and check for anything unusual. I had this problem some time ago and found some leaves and pine needles in the fan unit, made a hell of a noise and i thought i needed a new fan unit. |
Country: Thanks: 1
| I have an R171, a 2007 SLK350 to be exact. Took delivery in Oct 2006. Could you please clarify what the "cabin filter" is? Or provide a picture, and drawn an arrow pointing to it? Thanks, ~shahedc . |
| Not sure where its located in the 350 but it filters the cabin air much like the filter in a central air unit in a house. Allot of time leaves and stuff make there way into the duck work and into the fan unit. On the 230's its located under the glove box, your manual should give you the location or someone with more knowledge of the 350's will chime in. |
| Sponsored Links | |
| | #5 (permalink) | |
| Elite SLK World Member Join Date: Sep 2007 Location: Leeds, UK
Vehicle: 05 350
Country: Thanks: 12
Th enoise started on the way to work. We didn't have enough time to turn back home to swap for the sensible saloon, so were stuck with the noise all weekend. It stops when the climate control fan is turned off. Thankfully the weather isn't too hot or cold, so we'll be OK with it turned off for the weekend, but it would be really nice to fix it while we're away. Any more tips on getting to the filter will be appreciated, will I need tools? | |
| | #6 (permalink) | ||
Country: Thanks: 381
May I suggest that you post this query in the ask Dan (premium) section. I am not sure if it is the cabin filter or the fan itself that maybe causing the noise. One may be able to get a glimpse of the "fan blades" by removing the battery compartment cover and see if there's any obstruction or malalignment when the cabin fan is turned on. The fan blades can be observed in the compartment aft of the battery,through a rectanguar opening.
__________________ Eddy To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. Pewter/Beige, PIII package, Airscarf, Hands-Free Communication System, Lighting package Designo Black Leather Cover on e-brake handle, ( To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. Bill T), SmartTop v1.0, Kleyman 3BFM (NoRegret Custom), Green Air Filters, Mod. R170 ant., EuroClear sidemarkers w/PIAA PlasmaIon lamps, chromed front & rear turn indicator lamps, PIAA SuperPlasmaGTX front parking lamps, bilateral rear fog lamps enabled. | ||
| | #7 (permalink) | |
Vehicle: 05 350
Country: Thanks: 12
Made sure the ignition was off (keys in my pocket) before I stuck my hand in the fan! I'm suprised there's not a mesh screen to stop debris entering the fan. Maybe one for a future project. | |
| | #8 (permalink) | |
| The Following User Says Thank You to etyu For This Useful Post: |
| | #11 (permalink) |
| Click it or Ticket! Join Date: Mar 2008 Location: Burleson, Texas
Country: Thanks: 85
| I've got the same thing going on with my 2002 SLK. Guess I need to find out how to access the fan on mine now. Probably a leaf also, since I've got about 20 oak trees around my house!
__________________ Mike 2002 Black SLK-230 To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 5 or greater. You currently have 0 posts. |
| | #13 (permalink) |
| Richardleeds has the right-hand-drive (RHD) vehicle so it's on the left side of his vehicle. It will be on the right side of the R171 in a US spec vehicle (left-hand-drive or LHD).
| | #14 (permalink) | ||
Vehicle: 05 350
Country: Thanks: 12
Good point. It's on the passenger side, wherever you are in the world. Quote:
The links at the top of the thread are for getting to the other side of the fan from the inside. This is how you can remove debris that has passed through the fan blades and is caught between the fan and the cabin filter. Requires tools, patience and draught strips! | ||
| Sponsored Links | |
| a/c heater fan runs all the time | newberd | Ask DansSLK | 9 | 1 Week Ago 05:34 PM |
| cockroach inside the fan system | Nena | Help and Support | 11 | 08-03-2008 04:32 PM |
| Oil cooler fan mod for 55 | DansSlk | Performance MODS for the R171 | 17 | 05-10-2008 06:55 PM |
| Heater fan erratic | bazzle | SLK R170 General Discussion | 6 | 10-30-2007 08:31 PM |
| Engine Fan Replacement | beverage | SLK R171 General Discussion | 11 | 10-05-2006 07:59 AM |
