| SLK World Member Join Date: Nov 2006 Location: New jersey
Vehicle: 2006 E 350
| Service E is indicated on instrument cluster, however when I spoke to service adviser and informed him that the vehicle has 17K and that service B was completed at 12 K, I was given conflicting suggestions as to what is actualy going to be serviced, including the possibility brake fluid flush. the vehicle is a 06, SLK 280, does anyone know what service E requires. Thanks RL |
Country: Thanks: 54
| If I remember correctly, Service E, is cabin air filter change. No big deal, but the cabin air filter is expensive at about $180.
Country: Thanks: 376
| IIRC, the brake fluid needs to be drained/flushed and changed every 2 years. Coolant is every 3 years.
| Service B | Dennis | Where to get R171 SLK Items | 0 | 10-15-2008 04:45 PM |
| Service A, B... C? | shahedC | Help and Support | 4 | 07-15-2008 11:57 PM |
| What needs to be done in service B? | jucarbon | SLK R171 General Discussion | 5 | 06-09-2008 01:47 PM |
| Service E ??? | GearHead | SLK R171 General Discussion | 17 | 04-23-2008 11:18 AM |
| Service C | bejak | SLK R171 General Discussion | 6 | 02-01-2008 05:15 PM |
